03-05-2010, 08:10 AM | #752 | |
For the same-ish price, go with Nistune. Reprogrammable, fuel and ignition tuning, lots of support, AND not a piggyback. Nistune is a full programmable stock ECU essentially.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
03-05-2010, 12:55 PM | #753 | |
Anyways, now I got a new problem. When I put in the in the first on (intermediate - adjustable), it really on the 2nd on (constant -slowish), and the wiper won't stop if I put it back on the on position until I turn the car off. This is a s14 btw. Would this be the amp? If so, where is it in the s14? |
03-05-2010, 03:10 PM | #754 |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
whats the the most offset size rim i can run on a HB with no fender pull (just folding in the top lip...? im asking just for offset...the biggest rim ill consider running is a 17 incase info is needed
same question for the front, just hammered down lip, and with out needed modded wheel tubs...? thank you in advance...
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
03-05-2010, 07:49 PM | #755 | |
I am not an S13 fitment pro but I think like 17x9+15 would get you to where you want to be in the rear. Front maybe the same? Did you look through the wheel fitment thread?
BRICKHOUSE PRODUCTS
03-05-2010, 08:03 PM | #756 |
Trader Rating: (54)
Feedback Score: 54 reviews
Damn Steve, you failed hard on that question. lol
Folks run 17x9 +30 (R33 GT-R Wheels) like cake. 17x9 +20 is pretty much perfect in my opinion, though it also depends how wide of a tire size you plan on running and how low you plan on being.
- Jimmy Wanted: TBD For Sale: TBD |
03-05-2010, 09:16 PM | #757 | |
not giving a fuck
17 is the biggest rim size ill go... pretty much looking for a flush look, a bit on NEEDED camber on the rear...i dunno wat tire size would look good, not down for stretch
03-06-2010, 06:22 AM | #759 | |
Right. You said that in your last post. Offset has no bearing on the diameter of the rim. Its directly related to the width. So again, how wide of wheel are you looking at? For example, a 17x9+12 will have the same look from the outside of the car as a 17x8+0. They will both have the same flushness and stance. You dig?
BRICKHOUSE PRODUCTS
03-06-2010, 06:25 AM | #760 |
They mount vertically on the core support (front thing that the radiator and headlights mount too). They bolt right in. Once you have it apart, it looks a bit more obvious since you need them for the headlights to mount properly.
BRICKHOUSE PRODUCTS
03-06-2010, 08:39 AM | #761 |
can you run a z32 26mm caliper on a q45 rotor on s13?
also, where can i get a sticker of the engine fuse box diagram to stick on the lid of my repainted box? thanks dudes
03-06-2010, 08:41 AM | #762 | |
03-06-2010, 01:29 PM | #763 | |
Bandwagon.
im running 17x9+22 front with 215/40 w/o a pull just rolled fenders. |
03-07-2010, 02:52 PM | #766 | |
Trader Rating: (53)
Feedback Score: 53 reviews
Anyone know if an 18x10 +18 will clear PBM coils on the front? |
03-07-2010, 10:48 PM | #768 |
Trader Rating: (36)
Feedback Score: 36 reviews
gonna put this thread to use!
what size tires should i run on my s13 hatch. lookin for flushness but i also want traction, if thats possible.. wheels are 17x8.5+22 and 17x9+22. i was thinking 225/45/17 and 235/40/17 ? i dont mind rolled fenders and a pull |
03-09-2010, 12:33 AM | #769 | |
Another question I need a coolant temp sensor for my blacktop sr20 will a redtop one fit? I am going standalone so it does not have to be ecu specific just need to know if it fits. |
03-09-2010, 10:11 PM | #774 | |
Trader Rating: (31)
Feedback Score: 31 reviews
use a heat gun and just pull on it a bit, then send it to me haha
Slip Gypsies Blog Quote:
03-10-2010, 04:30 PM | #779 | |
steve you noob. lol jk. Here is a simple solution. Take a tape measurer, and measure where your wheel bolts up to-to your fender. in a strait line. However many in inches, will be the width of your rim x(times) 2. so if the hub to the fender is 4 inches, you will need a xby 8inch wheel with a zero offset. Now when you choose your wheel (based on that) the ofset is just the center point of the rim. So if it's plus 25, the barrel goes towards the shock tower 1 inch, now you need a 1 inch spacer to make that room up. Let me know if that is too confusing, I can break it down a little more simple than that. |
03-10-2010, 07:28 PM | #780 | |
Trader Rating: (31)
i acquired some rc engineering injectors 440cc with the part number of SL9-440 does anyone know what impedance they are. will they drop right into a dual cam without resistors? They came with clips too.
