Old 09-19-2011, 01:40 PM   #7741
Wake
Wake's Avatar
Suggested for what dude?
Come on, this isnt the "read my mind and tell me what my car should look like thread".
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 09-19-2011, 04:14 PM   #7742
GL Chrillz
GL Chrillz's Avatar
GL Chrillz is an unknown quantity at this point
my drivers side control arm bolt that goes thru the metal sleeve on the bushing is seized to the sleeve to where it moves the whole control arm if i try to take the bolt out. i cant hit it out with a hammer because the steering rack is there. how should i get it out?
GL Chrillz is offline   Reply With Quote
Old 09-19-2011, 04:19 PM   #7743
Jonathong
Jonathong's Avatar
Jonathong is an unknown quantity at this point
So, im awaiting my clear headlight covers for my zenki s14, which seal is the best to use to seal it back up?
Jonathong is offline   Reply With Quote
Old 09-19-2011, 06:43 PM   #7744
niscur29
Location: Back IN FL, bring nice cars to the fail state!
niscur29 is an unknown quantity at this point
Originally Posted by lightsource View Post
Suggested size spacers for Work VS-XX +35mm, 17x8Fr, 17x9Rr
on a S13 Hatback?
Thank you
Depends what you are going for...I went for some beef for tires so Im running 17x8 +25 235/40/17 and 17x9 + 25 255/40/17 with no spacers and it sits flush with the outside of the body with rolled fenders all around. Im not slammed either. But search the two wheel threads man theres plenty of info in there.
niscur29 is offline   Reply With Quote
Old 09-19-2011, 06:51 PM   #7745
Wake
Wake's Avatar
How did that help at all?
he meant to say if you use the same specs and a 10 mil spacer, your car will look like his. Which he didnt post any pics of so you still dont know what it looks like.
S.P.P.S. Member #00
Old 09-19-2011, 06:52 PM   #7746
new dood s13
new dood s13's Avatar
new dood s13 is an unknown quantity at this point
Ok so i have a random stupid question.. Im new to the nissan scene ive always been a mustang guy but got tired of being beat by tuner cars so i sold the mustang bought a rb25 drop out from a local jdm dealer and bought a s13 hatch. A nyways im building this for drag racing In the bottom end of the rb im going to run the stock crank with the larger snout and i have crowler rods my question is what pistons should i go with and what bore should i go with?
new dood s13 is offline   Reply With Quote
Old 09-19-2011, 08:11 PM   #7747
Origin
Origin is an unknown quantity at this point
Originally Posted by Otto347 View Post
I would imagine in/lb and not ft/lb, you need a torque wrench to measure inch or foot pounds.
Maybe you're right, I can;t find it in the FSM anymore. But the point being at 45 lbs. it would have snapped in a vice or whatever. Since 45 in/lb equals somewhere around 4 ft/lbs that shouldn't be a problem but still feels too little.
Origin is offline   Reply With Quote
Old 09-19-2011, 10:18 PM   #7748
Prime
Prime's Avatar
Prime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the rough
I'm doing the same thing at the moment. It's 29-43 ft/lbs. As for the shims, I have no idea. FSM doesn't call for them, but I'm going to measure what's going in versus whats coming out, and if there is gap I'm shimming.
Prime is offline   Reply With Quote
Old 09-19-2011, 10:26 PM   #7749
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
I switched from the Greddy manifold which has tons of nipples for vacuum sources to the stock one since I'm not going to be making 350+ hp.
So:
Wastegate - Weld on nipple on hot pipe.
BOV - bottom of throttle body
FPR - top nipple to the right on the TB.
Boost Gauge - ??? to Last vacuum source on manifold which would be right above the TB on the left.
Is this correct ? The GReddy manifold makes it so much damn simpler.
I was told earlier today that I should T off a fitting on the manifold above the TB for the boost gauge and wastegate, but personally im not into T'ing anything off.
SLiDe_WaYz is offline   Reply With Quote
Old 09-19-2011, 11:50 PM   #7750
WERDdabuilder
WERDdabuilder's Avatar
kouki 180sx Type X front bumper Cover side extensions/Chuki bumper side extensions same shit?
When the power of love overcomes the love of power, the world will know peace
Old 09-20-2011, 12:00 AM   #7751
harrypotter
harrypotter is an unknown quantity at this point
Upgrading to GT2871R on redtop in s13. I looked at the inlet/outlet adapters for the hotpipe. I think they look ugly as fudge! Anyone have a good solution for hotpipe? Maybe I can use a s14 hotpipe, but hoping a company sells a fmic for that configuration.
http://imageshack.us/photo/my-images/842/zilviasig.jpg/
harrypotter is offline   Reply With Quote
Old 09-20-2011, 12:05 AM   #7752
lg54
lg54 is an unknown quantity at this point
WHAT MOTOR PARTS ARE NEEDED FOR A MOTOR REFRESH?? ex: head gasket, water pump etc???
lg54 is offline   Reply With Quote
Old 09-20-2011, 02:05 AM   #7753
Wake
Wake's Avatar
No
What exactly is your question?
Full gasket kit is only $100 something bucks, do it.
and add water pump, timing chain, and get all your valves properly adjusted or replaced to stock spec.
S.P.P.S. Member #00
Old 09-20-2011, 03:23 AM   #7754
lightsource
lightsource's Avatar
Trader Rating: (41)
lightsource is an unknown quantity at this point
Feedback Score: 41 reviews
Send a message via AIM to lightsource
Isn't it? I want a flush look, rolling fenders, no pull (1-5mm max), just want a subtle tuck and don't want the wheels sticking out or in too far. Thinking of running 225/45/17 FR 235/45/17 RR
Wont be slamming the vehicle, just want it to look nice. Is that specific enough?
lightsource is offline   Reply With Quote
Old 09-20-2011, 04:50 AM   #7755
GL Chrillz
GL Chrillz's Avatar
how to get a control arm bolt out thats seized to the bushing sleeve?
Old 09-20-2011, 06:48 AM   #7756
Origin
How are you going to measure if it needs a shim or not?
And how on Earth are you going to tighten that down?
Old 09-20-2011, 07:10 AM   #7757
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
So:
This stuff is old news dude. Unless you're going to be putting more nipples on the hotpipe or running some kind of vacuum block, you're going to have to T.
Have you taken the wierd washers out yet? If you have, you can try any of the penetraters (pb plaster, liquid wrench, aero kroil to name a few) on the bolt/sleeve. When I was doing my rear upper control arms, I eventually had to saw mine off because the penetraters didn't work for me. I didn't need the eccentric bolts anymore and went with lockout bolts from SPL. Otherwise you may need to buy new eccentric bolts from nissan if you have to cut them off.
VNG704 is offline   Reply With Quote
Old 09-20-2011, 08:10 AM   #7758
GL Chrillz
GL Chrillz's Avatar
I've used pb blaster multiple times, it doesn't seem to penetrate into the sleeve. I was actually looking at the lockout kit. Does it come with bolts for front and rear arms? Because I'm doing the rear arm bushings and subframe risers next. Also, when I take the rear arm off, can I re use the ball joint as long as i don't damage it? The previous owner replaced them so they're fairly new.
Old 09-20-2011, 08:18 AM   #7759
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
So:
Get a vaccuum box. They are dope
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 09-20-2011, 09:51 AM   #7760
VNG704
VNG704's Avatar
You should try to look at their parts from their site. I only ordered the rear set for the toe and camber arms. As far as reusing ball joints, if it's not damaged and it's recently been replaced, I don't see why you wouldn't be able to reuse it.
Old 09-20-2011, 10:28 AM   #7761
GL Chrillz
GL Chrillz's Avatar
I'm on their site right now, they only have one eccentric lockout kit. It has 4 bolts, so I'm assuming that's for front and rear? or does the rear have 4 bolts? If that'll work for the front and rear arms I'll order it right now.
Old 09-20-2011, 10:32 AM   #7762
VNG704
VNG704's Avatar
Looking at it now.... rear only.
Old 09-20-2011, 10:43 AM   #7763
GL Chrillz
GL Chrillz's Avatar
So is there one for the front or should I just head to nissan for that? And with subframe risers, you need to readjust the coil overs right? I'm looking on ksports website, the tool I need is a spanner wrench, correct?
Old 09-20-2011, 10:46 AM   #7764
VNG704
VNG704's Avatar
front, not that I know of...Nissan, go for it. I don't have subframe risers, but considering the suspension is on the subframe I would assume so. Maybe someone can chime in. And yes, spanner wrenches are used to adjust coilover height.
Old 09-20-2011, 11:35 AM   #7765
axiomatik
axiomatik's Avatar
From what I remember, the FLCA doesn't have any eccentric bolts. You are talking about the bolt that attaches the FLCA to the front subframe, right? Find something that you can use as a punch on the end of the bolt and hammer it out.
Old 09-20-2011, 01:27 PM   #7766
GL Chrillz
GL Chrillz's Avatar
i cut it out with a sawsall, so that part is taken care of. and now that i know there's no eccentric bolts for the front i'll swing by nissan on my way home from class tomorrow. i'll still probably grab the eccentric bolts for the back since they'll be out i might as well put those in. to know how to adjust my coils do i just use a tape measure or what? lolol
Old 09-20-2011, 01:29 PM   #7767
WERDdabuilder
No
Old 09-20-2011, 02:11 PM   #7768
Prime
Prime's Avatar
Calipers, vise, torque wrench. Haven't gotten around to it yet, but I'll probably finish it up sometime tonight. I've got two of everything, so if I break something I'm not terribly concerned. I just try again.
Old 09-20-2011, 02:32 PM   #7769
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
what are those pieces right at the top called that mount it to a bracket and where can i get them? completely slipping my mind right now. i just need to find some so i can weld them to my intercooler and mount it.
TLDR
Cliff notes: Florida
sr20sean is offline   Reply With Quote
Old 09-20-2011, 02:40 PM   #7770
Wake
Wake's Avatar
here you go^^
weldtab.com
S.P.P.S. Member #00
