09-18-2011, 12:47 AM | #7712 |
Tried two different ignitors so I can rule that out, also popped off my ecu cover it's not fried/burnt...
When the weather isn't shitty (tomorrow please) I'll attempt my cas if it doesn't work then I'm officially STUMPED Any other ideas/info/suggestions/tips/hints?? I just wanna drive my car lol |
09-18-2011, 10:56 AM | #7713 |
still no luck trying to pound out the ball joints on my flca. should i take off the knuckle so i can get more room to hit it? the only thing i can think is that its rusted on and i just need to hit it harder...
09-18-2011, 11:22 AM | #7714 | |
Trader Rating: (58)
Feedback Score: 58 reviews
It's a press jobber, and yes taking it off the car helps 100 percent
09-18-2011, 12:10 PM | #7716 |
13-15 ft-lbs ^^
No offense but I dunno how people have "built SRs" and cant find a fsm or figure it out for themselves. Who "built" your SR?
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
09-18-2011, 12:26 PM | #7717 |
Trader Rating: (26)
Feedback Score: 26 reviews
Justin @P1 in Port Orchard, WA built the internals, put in the Powerfc. Now I'm building everything on the outside.
I torqued them at 15 before I asked. Looked like I was right. Lol I do need a damn FSM though. Edit-And ftr, i think googles search engine is jacked for the last few days. Every search I do on my phone or laptop yields 0 results. I did the ultimate test and googled "titties" and still got nothing. So obviously something is wrong lol.
IG/TikTok-ThatS14_Z06guy |
09-18-2011, 12:46 PM | #7718 | |
I'll try that, thanks for the suggestion |
09-18-2011, 12:55 PM | #7719 |
Why did my oil pressure valve assembly for my KA come with two shims? What are the advantages of increased oil pressure? And how on Earth am I supposed to tighten that assembly to 45 lbs.?
Will someone answer this, I've asked it 5 times. |
09-18-2011, 01:26 PM | #7720 |
Trader Rating: (58)
google.com search for the manual you need. s15 manual works best.
09-18-2011, 01:41 PM | #7721 |
In time-out for misbehaving.
anybody know wehre to get a water pump gasket for s13 sr20det?? cant find that shit anywhere and where i see the waterpump, most say does not include water pump.. let me know thanks
09-18-2011, 03:46 PM | #7724 |
Can somebody help me get my headlights on my s13 to flip up and down again? Is it just a fuse? They light up but to get em up or down, I have to do it manually.
09-18-2011, 09:32 PM | #7731 | ||
the holes to put the zip ties through come out of the top of the fender rail, so its really hard to reach its possible just really hard, plus you don't get as much room to stuff it. With it off you can hammer it flat with a mallet and then put shrouding over it and then the fender, whereas with the fender on you have to stuff it in there and it won't go very high.
street dancer. GLEAM |
09-18-2011, 10:43 PM | #7732 |
Wondering if someone could help me out. I was looking to order an Apexi ECV to quiet down my exhaust (ISIS Dual 4"), but I'm not sure what to order. I've read all about it; people arguring about the flow of the exhaust, back-pressure, and that it is installed at the end of the cat, or test pipe.
The ISIS piping is 3 inch, until the tips. Obviously, where it is going to be installed the, the piping is 3 inches. Do I order the 80mm version here: Apexi APEX'i 155-A023 ECV Exhaust Control Valve Silencer 80mm 80mm comes out to 3.14 inches, which is a bit bigger. Otherwise, all I can find is a 67mm version or bigger. Seems like the 76mm aren't sold anymore. Any help? Thanks |
09-19-2011, 01:43 AM | #7735 |
I am interested in picking up a seat rail, Nagisa or Bride FG (since they sit the lowest), and I am wondering if it will work with my F1Spec Type 5/4 bucket seat that I picked up from a friend.
I read about the the Recaro bucket seats being in a "Pole Position," which will not work with the Bride FG since the seat is wider (unless I make brackets). Any information would be great or had/have experience with the F1Spec bucket seat.
09-19-2011, 09:32 AM | #7736 |
Will someone answer this, I've asked it 6 times. |
09-19-2011, 10:40 AM | #7738 |
Trader Rating: (31)
Feedback Score: 31 reviews
How does the Heater Box Hose Routing go on a S14? This is my First route of 1 of these cars with the crazy Cock on the hose? I am Familiar with S13's but they don't have this Part. Which Hoes on a SR goes to which??
z-tERty-2 |
09-19-2011, 10:44 AM | #7739 | |
Trader Rating: (31)
I placed mine at the rear Axle back section due to ALL the damn cable to run or you have a bunch of slack. Works good for early morning Work Schedule. Don't Boost hard while using it though.
z-tERty-2 |
