Old 09-07-2011, 10:13 PM   #7591
Wake
Wake's Avatar
Depends on what you mean by plug and play, if the silvia headlights still have the little harness on the back then yes.
No subharness, then no.
Harness: Plug n play, except the yellows. Bricks are plug n play.
No Harness: not Plug n play
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 09-07-2011, 10:36 PM   #7592
VENICE_DRIFT
VENICE_DRIFT's Avatar
VENICE_DRIFT is an unknown quantity at this point
depends on how low you are.
And what size wheels.
And tires.
the wheels are 18x9.5+12 with a 225/40 and
i wanna go about 3/4 of an inch lower than what i have now
VENICE_DRIFT is offline   Reply With Quote
Old 09-07-2011, 11:33 PM   #7593
DriftN00b
DriftN00b's Avatar
DriftN00b is an unknown quantity at this point
ah, thanks alot. thats helpful. This is coming straight off another s13 so assumming the harness is there it would be the same as changing a flip up headlight? (simply unplug old plug in new?)
DriftN00b is offline   Reply With Quote
Old 09-07-2011, 11:37 PM   #7594
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
pretty much. even if the harness isnt there its simple as hell to make if you have a basic grasp for wiring. high beam, low beam, 2 wires from each bulb to the ground wire on the stock headlight harness.
TLDR
Cliff notes: Florida
sr20sean is offline   Reply With Quote
Old 09-07-2011, 11:41 PM   #7595
Wake
Wake's Avatar
Leave the 3 prong rubber boot connector that plugs into the pop ups. The silvia headlight will plug directly into that.
I use this write up to wire up my yellows.
Projector Wiring Detail (fog lights w/ lowbeams)
If you need help let me know. Or if your not comfortable cutting and soldering yoru harnesses, I can send you a conversion harness I made that wires your yellows the same way as that write up. Just send me your harnesses off your headlights for a core and we can work out a price.
S.P.P.S. Member #00
Old 09-07-2011, 11:46 PM   #7596
DriftN00b
DriftN00b's Avatar
awesome! thanks alot guys. I think Im going to try and do the wiring for the fogs by my self just as a learning experience. If not Ill def. contact you wake!
Old 09-08-2011, 12:09 AM   #7597
s14j
s14j's Avatar
Trader Rating: (72)
s14j is an unknown quantity at this point
Feedback Score: 72 reviews
Originally Posted by codyace View Post
Is the code for that sensor?
yes sir! thats why i wana get it so i can fix that but idk if another nissan could do or so
95 s14 ka DD
s14j is offline   Reply With Quote
Old 09-08-2011, 12:14 AM   #7598
Wake
Wake's Avatar
swear to god that looks exactly like the single cam one.
did the move it back to the airbox on s14's? s13 dohc's its on the intake mani and its just a little thermistor looking thing, like the ect, but tiny.
S.P.P.S. Member #00
Old 09-08-2011, 12:24 AM   #7599
sr20sean
sr20sean's Avatar
Trader Rating: (25)
b14 sentra/200sx should work. iirc the part numbers were the same when i replaced one for my 200sx when i had one. (if it makes any difference it was a 96 se-r) if you go on rock auto and look it up you should be able to find a whole list of applications that use the same sensor.
TLDR
Old 09-08-2011, 12:51 AM   #7600
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
does anyone know if Z32 and S13 interior lock/door handle are interchangeable?
REVIEW
killer240 is offline   Reply With Quote
Old 09-08-2011, 12:53 PM   #7601
chrisjakcj
chrisjakcj's Avatar
chrisjakcj is an unknown quantity at this point
Does anyone know what type of springs these are?
chrisjakcj is offline   Reply With Quote
Old 09-08-2011, 02:01 PM   #7602
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
So my cylinders compression is 170,170,153,170. Wiseco pistons, strong bastards.
Could a headgasket issue cause that dip in compression? I doubt my rings are going bad on just 1 cylinder.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 09-08-2011, 03:20 PM   #7603
S14DB
AFC #1
S14DB's Avatar
Hard to make out, Is that the one on the intake or bellow the hood latch?
If you detonated on that cyl you could have only cracked that one ringland. Pull the spark plug and shove a bore scope in there have a look.
Old 09-08-2011, 03:28 PM   #7604
chiboy002
chiboy002 is an unknown quantity at this point
Does anyone have a JWT "adjustable" cam gear (for KA), that I can borrow so I can copy it?
I dont have photoshop so I cant get the template I have to the right size.
I will pay shipping both ways and wont need it for more than a week.
i can get you photoshop if you want lol
street dancer.
GLEAM
Old 09-08-2011, 03:30 PM   #7605
chiboy002
Originally Posted by fckillerbee View Post
find out what the contact patch is of your current tire (measured new) and the one you are replacing with. Most accurate for switching it out.
Dunlop Star specs
Azenis 615k
Federal RS
and there are others. start there. sidewalls are only as big as the aspect ration given. example 215(width measured in mm)/ 40 (percent of width)r17 (rim diameter in inches)
good luck.
yeah but its like the same thing as feddy 595s, they have beefier sidewalls even though its 40%
anyways, thanks hammy
street dancer.
GLEAM
Old 09-08-2011, 03:50 PM   #7606
EsChassisLove
Trader Rating: (26)
Shit I hope not. I'm not in the mood to rebuild again lol. I'll check it out tmorrow and if i dont see anything I'll ask more questions haha
Old 09-08-2011, 04:26 PM   #7607
iveexcaped3
iveexcaped3's Avatar
iveexcaped3 is an unknown quantity at this point
put a little oil in the cylinder and retest that cylinder if it raises your rings need to be done if no its possible to have the head gasket go out but slim chance. if the headgasket was to go then chances are it would be between 2 cylinders more than just on 1 cylinder. the other possiblity is that its a sticking valve.
iveexcaped3 is offline   Reply With Quote
Old 09-08-2011, 06:24 PM   #7608
Origin
Origin is an unknown quantity at this point
Why did my oil pressure valve assembly for my KA come with two shims? What are the advantages of increased oil pressure? And how on Earth am I supposed to tighten that assembly to 45 lbs.?
Origin is offline   Reply With Quote
Old 09-08-2011, 06:39 PM   #7609
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Any of you guys ever rebuild a OS Gilken twin disk, is it complicated or easy? Google didn't help much.
SLiDe_WaYz is offline   Reply With Quote
Old 09-08-2011, 06:58 PM   #7610
chiboy002
from what it looks like, its pretty complicated
contacting OS Giken themselves would be the best option but from a quick search most people had theirs rebuilt by a shop. someone said it cost him $1130 lol
azn_doc sells em but i dont know if he knows anything about rebuilding em, ask him.
street dancer.
GLEAM
Old 09-08-2011, 07:27 PM   #7611
SLiDe_WaYz
SLiDe_WaYz's Avatar
its a Super Single* not a twin disc sorry for the confusion.
I'll send him a PM thanks for the response.
Old 09-08-2011, 07:36 PM   #7612
Wake
Wake's Avatar
Just ordered em from JWT.
Thanks anyway.
S.P.P.S. Member #00
Old 09-08-2011, 10:26 PM   #7613
WERDdabuilder
WERDdabuilder's Avatar
has anyone replaced the springs that are on the flip-up head lights? i think thats what causing my headlights to bounce up/down when im on bumpy roads.
When the power of love overcomes the love of power, the world will know peace
Old 09-09-2011, 03:36 AM   #7614
Jonathong
Jonathong's Avatar
Jonathong is an unknown quantity at this point
So just recently installed my j30 diff on my s14 and I hear a clunk sound come from the diff when I shift quickly but when I shift slow I don't get that clunk. Do I need to put washers anywhere or something on the diff?
Sent from my HTC Vision using Tapatalk
Jonathong is offline   Reply With Quote
Old 09-09-2011, 11:25 AM   #7615
G240
G240's Avatar
G240 is on a distinguished road
While idling either with the a/c on or a/c off, i hear a click from the dash and my idle jumps up and then falls. the cycle is every 10-15 seconds. It doesnt do it everyday but its often enough to become annoying. Anyone have an idea of what it could be?
A/C blows cold when on if that helps any. Just odd that it does it when the a/c is off as well.
Thanks!
G240 is offline   Reply With Quote
Old 09-09-2011, 01:51 PM   #7616
GL Chrillz
GL Chrillz's Avatar
GL Chrillz is an unknown quantity at this point
looking to get powered by max subframe risers, and was told ill need to adjust my rear coils and get an alignment? just looking for conformation on this, and possibly an estimated cost of an alignment if ones necessary? also, is there any other solid bushings for like the diff or anything i should also replace while the subframe is out?
GL Chrillz is offline   Reply With Quote
Old 09-09-2011, 03:53 PM   #7617
chiboy002
my alignments cost $75-$120 depending on the shop i take it to
yes you need alignment and to adjust the coilovers after install
street dancer.
GLEAM
Old 09-09-2011, 05:21 PM   #7618
GL Chrillz
GL Chrillz's Avatar
not terrible. is adjusting the coils something i do, or the shop does? i bought my car with them on, so i dont know how to adjust them but im sure i can find someone who can.
Old 09-09-2011, 06:15 PM   #7619
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
s13 z32 hub questions
Is anyone using circuit sports 60mm Long Wheel Studs : All New Carbon Steel, if so how long and what if any abuse have u placed on them?
Next question can 350z lug nuts fit z32 hubs?
lewisfk is offline   Reply With Quote
Old 09-09-2011, 09:50 PM   #7620
chiboy002
if you didn't get spanner wrenches i suggest you buy them from the company who made your coils. its a tool you will always want
they CAN adjust coilover height depending on the place you take it to, i take mine to specialty alignment shops so they know how to actually do stuff instead of Just Tires guys, but its always better to do it yourself.
Only you can decide how you like your car to sit, they can only guess for you. Adjusting coils, given they arent seized, takes like 45 minutes. When you do do it, put some antiseize on the shock thread and spin the collar over the antiseize to get it nice and in there otherwise it can rust and be impossible to move.
street dancer.
GLEAM
