Old 10-03-2013, 01:07 PM   #721
S14kouki_10
S14kouki_10's Avatar
S14kouki_10 is an unknown quantity at this point
yes updates plzzz
S14kouki_10 is offline   Reply With Quote
Old 10-03-2013, 10:33 PM   #722
C-unit
C-unit's Avatar
C-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to all
I am away from home now..lol. all i know its the car runs but runs like shit. My tuner is trying fix it at this moment.
C-unit is offline   Reply With Quote
Old 10-03-2013, 11:41 PM   #723
Oakville
Oakville's Avatar
Oakville is an unknown quantity at this point
Charles! he lives!
I've gotta ask, how are you able to spend so much time in HK....
BNR32 connoisseur // 1990 GT-R
Oakville is offline   Reply With Quote
Old 01-17-2014, 02:59 AM   #724
[email protected]
sooorad@aol.com's Avatar
sooorad@aol.com is an unknown quantity at this point
Any Updates?
sooorad@aol.com is offline   Reply With Quote
Old 01-23-2014, 07:32 PM   #725
C-unit
C-unit's Avatar
i need a new throttle body and a cam angle sensor plug.
IT DOESNT START!!! I am no clue why.
Old 01-23-2014, 11:53 PM   #726
[email protected]
This might sound dumb but do you have fuel in tank?
Sent from my DROID RAZR using Tapatalk
Old 01-24-2014, 12:02 AM   #727
C-unit
C-unit's Avatar
yes..full tank haha
Old 01-24-2014, 12:03 AM   #728
[email protected]
Ok lol. Well good luck man...
Old 01-24-2014, 12:30 AM   #729
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
thread now ruined
#0191 "Lin'da" 2AMR>2AMR>
Originally Posted by Bambi View Post
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 01-25-2014, 09:10 PM   #730
mkpoto
Trader Rating: (-1)
mkpoto is an unknown quantity at this point
Feedback Score: -1 reviews
dam, i went through all the pages and was hoping it would be all done!
mkpoto is offline   Reply With Quote
Old 04-03-2014, 12:35 PM   #731
smokescreen240
smokescreen240's Avatar
smokescreen240 is an unknown quantity at this point
just read this entire thread.
subbed. loving the car OP!
smokescreen240 is offline   Reply With Quote
Old 04-03-2014, 06:10 PM   #732
C-unit
C-unit's Avatar
We can't really get the car running properly.
The shop suggested to go with a standalone viper i88. Not sure if it will solve the issue.
The car is running lean at idle and run super rich once it have loads. I am using up rev right now.
Old 04-03-2014, 06:47 PM   #733
smokescreen240
Have you considered going haltech? I've heard nothing but good out of them as far as hr's go.
Old 04-05-2014, 04:48 AM   #734
psi999
psi999 is an unknown quantity at this point
Haltech platinum pro plug-in is what I'd be putting on it, just have to confirm it'll run the HR.
I have a Haltech platinum sport ecu on my vq30det, no complaints
VQ30DET S15 Silvia
1UZFE Datsun Bluebird
psi999 is offline   Reply With Quote
Old 04-07-2014, 01:40 AM   #735
C-unit
C-unit's Avatar
the platinum pro does not support HR, this is why I am going with the new vipec.
Old 04-07-2014, 02:21 AM   #736
psi999
Haltech Elite will be out in the next couple of months. VQ35HR will be supported and similar money to outgoing platinum sport 2000
Edit:
http://www.haltech.com/the-haltech-e...-introduction/
Features:
• Waterproof Case
• 8 x Fuel Injection Outputs
• 8 x Ignition Outputs
• 28 x Digital Outputs
• 10 x Analogue Voltage Inputs
• 6 x Engine Position Inputs with extensive trigger type support
• Oscilloscope - view and save crank and cam sensor waveforms
• Programmable Injector Peak and Hold Currents with open/short circuit diagnostics
• OBDII Capable - set and clear diagnostics trouble codes
• USB and Dual CAN Bus communications OEM and Haltech CAN expansion
• User definable 5D Tuning - ultimate tuning flexibility
• Drive By Wire (DBW) Throttle Control
• Cruise Control – Requires Electronic Throttle Control
• Quad Cam Control - Independently Variable
• Dual Channel Knock Control - With FFT analysis
• Auto Tune – Short and Long term fuel and ignition learning
• Staged Fuelling - Up to four stages of injectors
• Multi-fuel Support- Independent fuels can be used at once
• Multiple Profile/Calibration Tuning Up to 4 separate vehicles on the one ECU
• E85 Flex Fuel Ready - With additional boost tables
• Closed Loop Boost, Idle and 02 Control
• Anti-Lag and Launch Control
• Data logging - Internal memory & external laptop logging
• USB data logging- Log direct to USB Flash Drive
• Black Box Logging - Additional logging that is always active
• Engine Protection - Set limits for sensors and protect the engine
• Multiple User Login - Restrict areas of the ECU based on passwords
VQ30DET S15 Silvia
Old 05-27-2015, 08:10 PM   #737
koshin
koshin is an unknown quantity at this point
What ever happened to this build?
Did you get the tuning issues sorted out?
Did you get a chance to drive it?
koshin is offline   Reply With Quote
Old 05-28-2015, 09:07 AM   #738
C-unit
C-unit's Avatar
I guess kinda good news and bad news.
I did get the car running perfectly back in december. However, the engine ran for 2mins and the thrust bearing slipped and jammed the crank.
Since then the car has been sitting around in pcs. I probably won't get back to it until later summer.
Old 05-28-2015, 02:27 PM   #739
OBEEWON
OBEEWON's Avatar
can we see pictures of it sitting?
Sorry to hear the bad news brew.
Old 08-13-2015, 03:46 PM   #740
Kingbaby
Kingbaby's Avatar
yes please
Old 02-07-2018, 06:16 PM   #741
Corbic
Corbic's Avatar
fuck you photobucket
