#7441 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
sup dudes? im sick of dealing with my shitty harness.
well im a noob when it comes to electronics, i only know the basics. So my question is where can i learn about how to make my own harness(engine,body, etc..) online? is there any good sites that you know? i would like to learn because im planning to redo my own.
REVIEW |
#7442 |
![]() Join Date: Dec 2003
Painless Performance: The Official Home Page For The Best In Automotive and Diesel Performance Products
thats all you need.
![]() **CoUpe LOve** Member #00 |
#7443 |
From my original post
"Hi I own an s14, and have purchased 17X9 +18 wheels. My question is would 245/45 tyres fit with just rolled guards? I'd like camber settings up front to be no more than -2 degrees or so and the rear no more than -1 thanks " It wont be too low looking at going a bit above the tyre |
#7444 |
Your question was answered on the last page.
or search your tire size here: http://zilvia.net/f/chat/166563-maxi...nt-thread.html
#7445 |
![]() Join Date: Feb 2007
Trader Rating: (66)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 66 reviews
Hey guys. Previous owner cut the head unit harness out of my S13. I went to the junkyard and snagged a pigtail. I soldered everything color for color, but the chassis side has a left over black wire, pigtail does not. Anyone know what this is for or what I should do with it? Thanks
#7446 |
![]() Join Date: Dec 2004
Trader Rating: (58)
It's probably a ground, so connect it to a metal spot on the dash.
#7448 |
Trader Rating: (24)
i have an S13 with S15 lights. on the driver side everything works but the signal light stays on all the time and when i put it on high beam the low beam stays on with the high beam but low beam kinda dies a lil. for the passenger side nothing works but the parking light.
is this just some ground issue?
REVIEW Last edited by killer240; 08-28-2011 at 01:28 PM.. |
#7450 | |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#7451 |
![]() so after about 4 or 5 hours of searching i still have a few question. i have a 93 ka n/a auto and i want more low end power and it looks like to me, please tell me if I’m wrong, that i need to go with the 248/232 cam swap. now i know i have to do the "3 or 4" tooth ccw on the intake side (248 cam) but do i just install the other one straight up (dot to dot) or what?
#7453 | |
![]() Join Date: Feb 2010
Can someone shed some light on this please? |
#7456 |
Trader Rating: (58)
Is somethign broken in the mechanism itself? Did you take it apart to see yet?
#7458 |
![]() Join Date: Nov 2003
So I've got a stock block S13 Blacktop SR, 740cc Injectors, Walbro 255LPH fuel pump, S14 T28 turbo, Z32 MAF, all supporting bolt-ons, and a greddy-style intake manifold.
If I get a JWT ECU tune for my setup, how much boost can I run safely? And how much power can I make, roughly?
-Kyle ![]() |
#7461 |
Zenki dudes, im putting an aftermarket HU in my 95 SE. It powers on but i cant get sound out of any of the speakers, i know it has to do with the factory amp, and i dont have the time to run new wires to bypass it. Anyone know what color wire i need to hook up to get it to work? Im using an aftermarket harness for the radio.
All i have left on the radio harness is the blue/white wire labeled system remote control. The aftermarket harness has blue/white, blue, and orange left. |
#7466 |
![]() Feedback Score: 11 reviews
I'm not sure that would work. I know to fit a Q45 diff in an S-chassis you need the driver side axle from a TT Z32 and a driver side axle from a Q45. That kind of implies they aren't all the same.
#7469 |
Trader Rating: (58)
I'd get Altima fans or Taurus fans, or be be prepared to spend big bucks on an aftermarket fan capable of keeping it cool in single 12" form.
#7470 | ||
Trader Rating: (58)
You'd be able to max that turbo out for sure...probably 265-285 whp Quote:
Carbotech Performance Brakes: Products-Nissan Brake Pads & Shoes
