#7233 |
![]() Join Date: Jun 2007
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
You have a OBD II which means they will have to hook up the machine to scan for codes as well. OBD I don't put a check engine light for knock sensors. Make sure you also test the wiring also.
#7234 |
![]() Join Date: Apr 2010
ok so it appears as if my rear main seal is leaking
and it leaks a fairly substantial amount of oil.. however after checking my oil levels it does not appear to be low... any suggestions on what is leaking? |
#7237 | |
thank you very much. untill i fix this i can just add more gear oil through the shifter? p.s. is this easier or harder or the same to fix as the rear main? |
#7238 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Equal job. Yank trans out, replace seal.
#7240 |
![]() Join Date: Aug 2005
After I changed out my power steering rack. I noticed my steering is stiffer than usual; I have Isis power steering line and Energy Suspension bushings. Is this normal or would I still need to bleed the system?
#7241 |
![]() Join Date: Feb 2010
Mine was a little bit "stiffer" as well. Fill up the PS reservoir and turn the car on. Turn the wheel lock to lock a few times and keep refilling the reservoir. Drive it around the block and fill it back up. Mine took about a day of regular driving to settle down.
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3 |
#7243 |
Alright guys so i'm looking to buy an s14 97 or 98 kouki and i was wondering if you guys could give me an opinion on what price i'm looking at. I'm looking for something mostly stock and 5-speed with miles anywhere between 150-200k Any ideas on the price?
#7244 | |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
![]() You realize the prices of cars change depending on condition, not just miles? And who knows what you consider "mostly stock". Also, depending on the area, the price of cars is different. So the only way you can find out the price is by looking for yourself.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#7245 |
Been on craigslist for a while. I posted a WTB add for 6k i was just in need of some opinion of whether or not this would be a good starting price for what i am looking for. Not asking to be spoonfed...... Also because of the lack of koukis on craigslist i'm looking for a reasonable offering price. Feel free to give me your opinion on my price
#7246 | |
![]() Join Date: May 2010
![]() Feedback Score: 10 reviews
#7247 |
#7248 |
Car has been hesitating lately. At first id only notice it shortly after starting the car up and driving. Now when it happens I can hold the accelerator pedal down in the same position and the rpms go up and down up and down. Then the car will rev up but my speed doesnt increase like I'm in neutral then finally the engine turns off. If its hesitating and i come to a stop the engine will turn off just leaving my lights on.
Would you say maf or tps? I was able to test the power and ground side of the tps and the checked out. The power side should show approx 5v, i got 5.13v. The ground side has continuity. With the throttle wide out and engine off it showed 4.5 ohms of resistance the fsm calls for approx 4 ohms. I didn't get a chance to test the input signal or the maf as I don't own a multimeter and I hear the cheaper ones are no good and money is tight. Does it sound like the tps, maf or possibly something else? '96 stock engine..
Almost there. Last edited by Mangudai; 08-14-2011 at 01:23 PM.. |
#7249 |
![]() Join Date: May 2011
just looking to clean up the engine bay a little since i have no money to buy parts, need to keep busy lol. ive heard people taking out the charcoal canister, is this ok to do or is it going to hurt anything? what other stuff can i remove/relocate to make the bay look cleaner without getting into wiring yet. and what does this line go to? because in the bay mine isnt connected to anything Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
#7250 | |
You can move nearly everything out of your engine bay. look at the engine bay thread and wire tuck thread, you should get some good ideas from those.
#7251 |
so can i like cut the wire where it starts to go under the car to get it out of the way but still vent? also, does the battery ground below the injectors? cause theres an old wire that looks like it goes on the battery but since its in the trunk now its just kind of laying there but its bolted below the injectors
#7253 | |
#7256 |
Can anyone tell me how to contact BN... i just want some damn front fenders and i emailed Hiro and Chuck who work there but havent gotten anything back yet. Dont know if they even work there anymore. Let me know please! Thanks in advance!
Adam |
#7257 |
Trader Rating: (58)
nope, stock will be fine
#7258 |
AFC #1
![]() Join Date: Oct 2003
Yeah, you don't need to adjust anything. But, you way want to buy a new FPR if you are still on the factory one.
#7259 |
the more i look at my bay, the more i hate the wiring done. wires hanging that go to nothing, plugs that arent plugged in, etc. what kind of work am i looking at if i buy a second harness, remove useless wires i wont use, extend ones i need to, etc, and label every plug and wire. what kind of work am i looking at if everything is all labeled correctly?
#7260 | |
Trader Rating: (58)
