Old 11-20-2015, 02:31 PM   #6901
2_Liter_Turbo
2_Liter_Turbo's Avatar
Trader Rating: (28)
2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough
Feedback Score: 28 reviews
Originally Posted by GKTECH View Post
We may have not had another set at the time as during the first few batches they were all sold out pre buy.
The V3 does rotate the caliper further around. Send me an email to [email protected] with the specifics on your setup and we'll see if they'll assist however either way swapping them over is no issue at all.
Regards,
Greg
Will do Greg, thanks. You guys have always been excellent with communication.
96 S14: Grip Track Car
90 R32: Bucket List Car
92 S13: Just for Fun Car
Instagram: @SS.Maxey
2_Liter_Turbo is offline   Reply With Quote
Old 11-21-2015, 02:49 AM   #6902
sr vegas 240
sr vegas 240 is an unknown quantity at this point
So i just put the gktech roll center correction kit on and have few issues the bottom bolt on my pillow ball style outer tie rod hits the flca. I already cut off the bump stops. Should i be using oem type outer tie rod? Other not really an issue but i know for sure its not installed right offset rack spacers. Which way should they be pointing towards front of the car or towards the rear? i will cut the tabs off and line it up straight. Pictures will explain better what i am talking about.
sr vegas 240 is offline   Reply With Quote
Old 11-21-2015, 09:45 AM   #6903
PoorMans180SX
PoorMans180SX's Avatar
This is the roll center, suspension pickup, and steering angle modification t...
The offset rack spacers point towards the front. Yours are just on the wrong sides of the rack. Switch them around and they should fit fine.
I would use an oem type tie rod end. Those that you have are famous for breaking shanks, and you don't need the bumpsteer correction.
Old 11-21-2015, 11:15 AM   #6904
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
On my gk tech rc correction I used the non offset rack spacers, is there a big benefit to the offset rack spacers instead of the non offset ones?
e30gangsta is offline   Reply With Quote
Old 11-21-2015, 11:18 AM   #6905
PoorMans180SX
Just that you can run more caster without overcentering if that's what you're into.
Old 11-21-2015, 11:21 AM   #6906
sr vegas 240
I have tried them every way possible they either point towards the ground or up in the air it's an s13 so I got the s13 spacers but turns out someone put s14 rack in it. So I will have to cut the tabs off.
Old 11-21-2015, 12:22 PM   #6907
derass
If you cut those tabs off they will not keep their position once tightened. You would have to weld the spacers to the rack to keep them in position. A friend of mine did the same when he ripped the threads out of the rack at at track day.
Old 11-21-2015, 12:35 PM   #6908
sr vegas 240
Ok will weld them back on and thanks for the heads up.
Old 11-21-2015, 01:12 PM   #6909
PoorMans180SX
Actually my offset tie rod brackets don't have tabs on them, and they've held fine, you just need lots of red loctite. The rack only gets damaged when the bolts come loose.
Old 11-23-2015, 06:27 AM   #6910
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
Seconded. There was a minor mix-up with my order and Greg was in constant contact until it was resolved
My S13 SR Street Mod Build
LuckyX2 is offline   Reply With Quote
Old 11-23-2015, 08:16 AM   #6911
e30gangsta
Yea, im already at the max caster on my arms anyways. Unless I go and pull off the nuts which Im not going to do. Thanks for the explanation.
Old 11-23-2015, 04:55 PM   #6912
GKTECH
GKTECH's Avatar
GKTECH is making a name for him/her selfGKTECH is making a name for him/her self
Looking at your photos I can see a few more issues. You have used the washer for the ball joint between the tie rod shank to mount on the knuckle. This washer is for the top of the ball joint. I can also see that presumably as a result of this that there is not enough thread engagement of the nut holding the tie rod shank in.
See the attached and if you have any questions, please feel free to contact us directly at [email protected]
USA Warehouse now open
www.gktech.com.au
GKTECH is offline   Reply With Quote
Old 11-23-2015, 06:07 PM   #6913
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
Anyone else have to notch the steering rack where the offset spacers go? I contacted Greg he said just to notch them with a grinder so they can point horizontal
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 11-23-2015, 06:09 PM   #6914
PoorMans180SX
I had to do this with the PSM ones. Moving my rack forward soon so I don't have to worry about it anymore.
Old 11-23-2015, 08:24 PM   #6915
sr vegas 240
Yes I noticed That I had to put that spacer in there because there was a gap . I may possibly have different knuckles not stock s13 ones but I have sold the kit no longer have it getting some drop knuckles any recommendations
Old 11-23-2015, 08:29 PM   #6916
GKTECH
GKTECH's Avatar
If there was a gap it would be because you had S14 knuckles and your RC correction kit was the S13 version. The tie rod mount on the knuckles differs slightly between the 2 different models (hence we make 2 different models).
Are you only using the car for drift? What you plan on using the car for will help determine what knuckles best suit your car/setup.
www.gktech.com.au
Old 11-23-2015, 08:31 PM   #6917
ka-titties
ka-titties is an unknown quantity at this point
Hah that was fast.
ka-titties is offline   Reply With Quote
Old 11-23-2015, 09:01 PM   #6918
sr vegas 240
yeah figured it's different knuckle. I only use it for drifting.
Old 11-23-2015, 10:31 PM   #6919
GKTECH
GKTECH's Avatar
We will have our V3 front knuckle available from the US warehouse in around 3 weeks time which has a shorter steering arm over our V2 for faster steering aswell as less ackerman. The V3 will max out at around 70 degrees (V2 maxed out at around 65). The V3 is specifically for drift cars where as the V2 is perfectly fine for either drift or grip.
www.gktech.com.au
Old 11-23-2015, 10:42 PM   #6920
sr vegas 240
That sounds good what will the price be any other parts required
Old 11-28-2015, 07:42 PM   #6921
Bnr32gtr
Bnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enough
So today I removed the helper springs from my coilovers fronts worked out as planned. I had high hopes of tucking rim in rear and failed terribly! Rear is now higher than what it was with out the helper spring!??? I have hks hyper max 3 coil overs,gk drop knuckles,and sub frame risers wtf I was 1 1/4" from tucking now at 2" I pretty shore its because I pre loaded the spring? When I droop the spring car will go lower till I hit on pich weld with ruca. I have shitty ones do better ones have move clearance somehow? Or cut the pitch weld or what am I doing wrong?
Bnr32gtr is offline   Reply With Quote
Old 11-28-2015, 07:44 PM   #6922
PoorMans180SX
Cut the pinch weld out and droop the spring.
Old 11-28-2015, 08:34 PM   #6923
Bnr32gtr
Thanks man I'm gonna cut it out in the morning. Do better arms have more clearance? When I was out there I Measure looked like Id still be like 3/8" to the top of rim. I see folks tucking with 18s and -1* camber but now I don't see how it is possible.
Old 11-28-2015, 08:39 PM   #6924
sr vegas 240
Any more info on this price? When it will be available?
Old 11-28-2015, 08:49 PM   #6925
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Just cut slits in it and hammer it flat then hit it with a little paint to keep it from rusting. Pretty much anyone that's low has to do this with S14.
Old 11-28-2015, 08:55 PM   #6926
PoorMans180SX
Yeah better arms are bent for more clearance.
Old 11-29-2015, 09:13 AM   #6927
Bnr32gtr
Thanks for the help boys! Tucking like a boss and going to buy some better arms tonight ether gk tech or voodoo 13 Prob gk tech cuz of cost but they don't seam like they have lot adjustment. Any input?
Old 11-29-2015, 02:47 PM   #6928
az_240
az_240's Avatar
Trader Rating: (41)
^I'll find out soon enough.. replacing my PBM RUCA's with GKtech since they rub on the axle boots a little with the PBM rear knuckles. RUCA are a tricky thing with drop knuckles. I've had a few that just didn't work out for various reasons.
Old 11-29-2015, 02:56 PM   #6929
dazed
Trader Rating: (37)
dazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the rough
Feedback Score: 37 reviews
I should have waited for PBM's new forged rear knuckles. They finally support drum e-brake. They basically did it how the Driftworks/Era 1's are, how they mount on opposite sides and are flipped upside down.
dazed is offline   Reply With Quote
Old 11-29-2015, 03:18 PM   #6930
az_240
az_240's Avatar
Trader Rating: (41)
Looks like they updated a few things including their RUCA... The toe control bracket is interesting.
http://www.partsshopmax.com/page.php?39
anti-squat, best thread ever, kpi, roll center, steering angle, suspension
