11-10-2015, 07:44 AM | #6871 |
I did adjust the upper lengths. I began with OE lengths, then adjusted the camber, toe and traction rods accordingly. I supported the bottom of the LCAs to simulate the 90* static stance. Per GKtech's instructions, I adjusted the camber and toe rods for near 0*. I do not have a specific measuring device to I had to use tape and string as best I could. The ideal length for the traction rod on a S13 subframe is 212mm ~ 8.35" which is what I came out to be. All of these measurements will be checked once its under the chassis during final assembly.
11-10-2015, 08:07 AM | #6872 |
11-11-2015, 11:15 AM | #6873 |
So what's the Ackerman curve like on the new revision of the GKTech knuckles? It was posted for the billet Al ones, but I don't recall seeing anything for the steel.
Just wondering if I should get eccentric steering rack bushings or not, to put some more positive Ackerman back in (assuming the GKTech's are reducing it for drift applications)
My S13 SR Street Mod Build |
11-13-2015, 12:35 AM | #6874 |
I just purchased s13 gktech roll center correction kit shill haven't received it and now wondering should I have just gotten the their knuckles or pbm knuckle I paid 230 and for 200 more I could of had the knuckles. I know this is the cheaper way to go to correct roll center and it gives you up to 60 degree of lock. Am I missing anything by not getting the knuckles or will this do the trick?
11-13-2015, 01:09 PM | #6875 | |
I cannot recommend staying away from eccentric rack bushings enough. I know guys run them but any parts that doesn't allow the bolt to seat all the way on a steering rack mount makes me nervous. So much so I sold my PBM rack bushings for the offset ends from GKTech. Wisefab and other top end companies use this type of setup. Ultimately moving the actual mounts forward would be the best solution but not all competitive series will allow it. Plus you may not clear your oil pan depending on the motor you use. |
11-13-2015, 01:20 PM | #6876 | |
Do the offset tie rod spacers change Ackerman? I thought they just corrected overcentering and to affect Ackerman you have to actually move the pivot point of the tie rod which is at the rack.
11-13-2015, 01:49 PM | #6877 | |
You change the ackerman curve of the steering when you add offset rack spacers or move the rack forward.
11-13-2015, 02:00 PM | #6878 | |
What PoorMans180SX just stated, both will affect Ackerman. My understanding from Greg is his latest knuckle can be used both Drifting and Circuit racing which leads me to believe it isn't designed for 0 Ackerman (both wheels turn same amount). Greg states his knuckles do not increase scrub radius. I wont know for sure until I install my entire setup and take measurements. Of course this gets further complicated when you introduce longer lower control arms, extended tie rods and no sway bars for further turn in. |
11-13-2015, 02:37 PM | #6879 |
I know the new GK knucks have lower ackerman than driftworks geomasters.
11-13-2015, 06:33 PM | #6880 |
This is the roll center, suspension pickup, and steering angle modification t...
I guess I could post this.
Rack moved forward on crossmember. 25mm extended flca and inside bushing replaced with heim joints and boxed. Passenger Maverick rack extension, driver side PBM tie rod spacer, oem s13 inner/outer tie rods lifetime warranty. VooDoo13 tension arms. GKTech 40mm roll center knuckles. 17x10 -4 225/45. On my Instagram @sylas_g there's video of lock-to-lock. ImageUploadedByTapatalk1447464937.516089.jpg ImageUploadedByTapatalk1447464954.263136.jpg Sent from my iPhone using Tapatalk |
11-13-2015, 06:51 PM | #6881 | |
11-13-2015, 07:36 PM | #6882 | |
Sy, are you rubbing anywhere? With my setup, I found wide wheels and big angle difficult to get right. |
11-13-2015, 11:50 PM | #6883 |
My setup doesn't rub anywhere no. For mine the increased scrub radius is the main thing that helps clear everything. Otherwise I'd be hitting the frame rails and sway bar.
11-14-2015, 08:52 AM | #6885 |
Why are you so concerned about the scrub radius? Buy wheels with a higher offset and boom you're back to the same scrub radius. It's not a big deal until you get an extremely positive one anyway.
11-14-2015, 11:21 AM | #6887 |
Yeah, you'll be just fine.
11-14-2015, 11:58 AM | #6888 |
Awesome I'll go and put them on. Main reason for getting them is I had bad wobble at full lock while drifting. My mods are touge factory inners phase 2 pillowball outters circuit sports offset rack spacers stance coilovers.
11-14-2015, 12:16 PM | #6889 | |
Reduce your static caster a bit. Try 6 or 6.5*. Caster wobble + old rack can make the steering feel like that.
11-14-2015, 12:26 PM | #6891 |
Get an alignment for sure, and stress that you want the caster set to 6*.
11-19-2015, 12:25 PM | #6892 |
Sounds like a common problem the company doesn't care about, I don't know what they are using to machine the spindle but the tooling is not accurate at all. Having to modify something you paid good money for is BS in my book. No issues with Wisefab, PBM or TDP
[SIGPIC][/SIGPIC] |
11-19-2015, 12:39 PM | #6893 | |
I've seen a few issues with Parts Shop Max limit break stuff, but not the normal ones.
11-19-2015, 01:43 PM | #6894 |
alternatively maybe it's just S13 vs S14 ball joint supplied with the LCA's? Either way it's not right and I wouldn't modify it before speaking to Orange Tree about it.
11-20-2015, 09:21 AM | #6895 |
Or follow Def's guide to rebuild them with better hardware
http://www.nissanroadracing.com/showthread.php?t=1407 Also, holy hell, that write-up was posted 6 years ago today. Time is flying by.
11-20-2015, 10:42 AM | #6897 |
Trader Rating: (28)
Feedback Score: 28 reviews
This is how much they were off on my coilover: This is the OEM strut: Here's the knuckle before I modified it:
96 S14: Grip Track Car 90 R32: Bucket List Car 92 S13: Just for Fun Car Instagram: @SS.Maxey |
11-20-2015, 12:56 PM | #6898 | |
Teething issues with a new design is certainly not an excuse but we do stand by our products 100% and if there is an issue we will fix it. Both myself, our engineer and Dan in the US warehouse all have S chassis' and run all our gear on our own cars so constant improvement to us is imperative. |
11-20-2015, 01:21 PM | #6899 | |
Trader Rating: (28)
I was told to modify them by you guys though, and wasn't offered an exchange at the time. These don't work with my brake kit either, which is why I haven't fully used them yet (still sitting on my desk). I thought I saw somewhere that you guys were doing a V3 version that moved the brake caliper mounting points back to the factory-ish location, is this true? I would definitely be interested in an exchange for that!
11-20-2015, 02:04 PM | #6900 |
We may have not had another set at the time as during the first few batches they were all sold out pre buy.
The V3 does rotate the caliper further around. Send me an email to [email protected] with the specifics on your setup and we'll see if they'll assist however either way swapping them over is no issue at all. Regards, Greg |
