#6631 |
dented oil pan
just bought this oil pan and noticed a dent that i've circled in red. the dent is not visible from the bottom of the pan. i'm 99% sure it wont affect shit, i just want peace of mind before i install it. so, think any harm will come from it?
![]() p.s. cool points for you codyace, members like you keepin this site alive and well. ![]() Last edited by nep; 06-27-2011 at 01:54 AM.. |
#6633 |
was just about to order my driveshaft from shaftmasters.com and i was looking and unsure which one i should get. I have a S13 with a S14 rear subframe....should i still get the s13 drive shaft? also this is for a rb25det
Thank you!! |
#6634 |
question about overfenders
i noticed that some models have it where the fender stops just above the body line where as other models go all the way down to the edge of the body.
i haven't found a consistency between different brands whether one brand does it, or doesn't. or if one model is wider or not. whats the difference and what brands usually run their fender all the way to the bottom of the body?? this, going all the way to the bottom of the body: ![]() VS this, stopping right above the body line: ![]() |
#6635 |
I have metal shavings in my oil pan, there are some bigger about half a cm, but most are sand sized shavings, there are some markings on the inside of the engine but not much.
What does this necessarily mean? Spun bearings are something worse? |
#6639 |
![]() Join Date: Sep 2009
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
![]() You are going to need to take out the bottom nuts on the motor mounts. Then get a cherry picker and lift the motor up a couple inches to be able to slide the oil pan out. The oil sump will make it feel like it won't come, but just do some wiggling and it will slide out.hope this helps!
WASTED I AM! |
#6642 |
i'm trying to figure out if i need a new steering coupler. I rotated my u-joint (the one that connects the steering shaft to the rack), and I hear a grinding/clunking kind of noise. I have bad vibrations/shaking in the steering wheel past like 55/60 mph. When I downshift at those speeds and the rpms increase, so does the shaking (even if I'm maintaining the same speed). does it sound like a bad coupler? and would it be screwing up my alignment?
#6645 |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
What is the bolt size/length for the 3 bolts that attach the brackets on the s14 core support to the bottom section?
Ignore the top arrows. At the bottom of those 3 front horizontal brackets, those are the bolts I'm talking about Pm me if you know, thanks ![]() |
#6646 | |
![]() Join Date: Mar 2005
#6647 | |
#6648 |
or stick the gap tool to into it and then hit it on a desk or table so that it gaps to that size lol
street dancer. GLEAM |
#6651 |
![]() Join Date: Dec 2003
LOL how is that even an acceptable user name? Fucking dumb
Anyway, no nobody knows that shit off the top of their head. search
![]() **CoUpe LOve** Member #00 |
#6652 |
if your referring to my name, i couldn't get any of the ones i tired to work so I am using an Xbox name which i figured no one would have.
#6653 |
Smelt something funny, took my ecu apart and saw this D418. anyone know what it is? Btw it's a 5 speed kade ecu
![]() Last edited by buku_points; 06-28-2011 at 09:57 PM.. Reason: Picture size |
#6654 |
guys i have a s14 with a sunroof and i want to remove it. is it possible to remove the sunroof rails and motor and just leave the glass have it tinted and buy a non s14 headliner + dome light?? I was thinking about just welding a piece and having it painted but this could be easier and i would get the necessary head room.
l 2011 C63 AMG l S-14.5 l 2009 Dodge Ram l |
#6656 |
isnt it the same for almost all the nissan motors?
you need the one to the gauge(1 wire) or ECU (2 wire)?
#6657 | |
#6660 | |
Same.
