Old 06-25-2011, 02:57 PM   #6601
kolson
kolson is an unknown quantity at this point
i know this might be dumb but i want'ed some opinion's first, has anyone tried an sk2 front end conversion yet? i've seen a ton of conversions but no s2000 and wanted to know what you guys thought before i even thought more of it
kolson is offline   Reply With Quote
Old 06-25-2011, 03:15 PM   #6602
Mesarina
Mesarina's Avatar
Mesarina is an unknown quantity at this point
is this normal? The pad sticking out too much with spacers to put 350z track rotors on a s13?
Mesarina is offline   Reply With Quote
Old 06-25-2011, 03:29 PM   #6603
Origin
Origin is an unknown quantity at this point
Originally Posted by jdmjap808 View Post
A hotpipe is for turbo cars. its the ic pipe from the turbo to the intercooler which may or may not have a bov
That's good to know, I'm told for a sr20 swap the vacuum signal line must run from there to the wastegate.
Origin is offline   Reply With Quote
Old 06-25-2011, 04:50 PM   #6604
jdmjap808
jdmjap808's Avatar
jdmjap808 is an unknown quantity at this point
Well the vac line goes from the waste gate to a nipple on the throttle body. But look it up on google for better directions on the right place to put it. Google saved me from making a lot of mistakes..
jdmjap808 is offline   Reply With Quote
Old 06-25-2011, 08:56 PM   #6605
Origin
Wow, read the link someone just posted me before.
Old 06-25-2011, 09:12 PM   #6606
jesse_s13
jesse_s13's Avatar
jesse_s13 is offline   Reply With Quote
Old 06-25-2011, 09:23 PM   #6607
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I got ngk bkr7e-11's for my sr gapped at .47. Is this the right gap size for 14lbs?
no, drop that down to .025 to .030
Old 06-25-2011, 09:36 PM   #6608
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
S14 with S13 SR engine.
Which OEM Fan Shroud for the clutch fan should I get. Engine Match or Body match??
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 06-25-2011, 09:51 PM   #6609
KA-T Hatch
KA-T Hatch's Avatar
KA-T Hatch is an unknown quantity at this point
Need some help with alignment/suspension stuff.
I have coilovers w/ a camber kit in the rear. I just need to clerify some things.
How do I adjust the camber in the rear. I have the driver side at -5 and the passenger side at -3. I have a blown coilover in the front on the passenger side which has thrown my alignment off. I know that I need a camber kit in the front, but is that just two adjustable bolts that I can get for $25/each?
KA-T Hatch is offline   Reply With Quote
Old 06-25-2011, 10:45 PM   #6610
codyace
codyace's Avatar
Trader Rating: (58)
Most of the Cobra/G35/Z33 rotor conversion brackets have this issue...however that is REALLY large overhang. Mine was roughly 1/16th of an inch at most.
With a larger oerhang like that, you're going to have some noisy brakes.
To adjust camber in the rear, you're going to need to use the factory eccentric bolts on the upper control arms. Your best bet would be to buy a replacement set of aftermarket ones. ISIS and Godspeed make entry level ones that will work for you.
Old 06-25-2011, 11:05 PM   #6611
chiboy002
chiboy002 is an unknown quantity at this point
i would most likely say go with body match for mounting points and then trim to fit engine
but isn't it radiator specific?
street dancer.
GLEAM
Old 06-26-2011, 12:09 AM   #6612
boatboytm
boatboytm is an unknown quantity at this point
transmission
if my transmission is leaking would that mean I would have to buy a whole new transmission. I bought the car from my friend and he said it wasn't leaking before
boatboytm is offline   Reply With Quote
Old 06-26-2011, 12:13 AM   #6613
codyace
codyace's Avatar
Trader Rating: (58)
No, you'd just need to fix the leak/seal
Old 06-26-2011, 12:15 AM   #6614
Steinkrunk
Steinkrunk is an unknown quantity at this point
are you sure it's your trany leaking? What color is the fluid? If it is in fact trany fluid you could just replace the seal that's leaking and that would fix the issue. If it's motor oil it could be your rear main seal or valve cover. Sometimes both of those end up running down the trany and make it look like a trany leak.
Steinkrunk is offline   Reply With Quote
Old 06-26-2011, 12:18 AM   #6615
Mesarina
Mesarina's Avatar
Well, I took it for a "spirited drive" and actually, the noise from the hawk pads went away, I should be because of the slots... tomorrow Im racing, so hopefully it will brake better with less pad surface but more leverage... Ill chime in my review... Thanks
Old 06-26-2011, 09:20 AM   #6616
codyace
codyace's Avatar
Trader Rating: (58)
The slotted rotor isn't going tomake any difference on noise/squeling...the only thing those rotors will do are chew down your pads.
What compound are you using as well? May take a while to bed the new compound into the rotors as well before they squeak.
And your 'swept area' is what is increasing, not your hydraulic leverage.
Again, I used this setup for 2-3 years, worked great for me. Problem is the cost of good rotors is crazy nigh, and the pad selection (at least in good compound) is expensive as well.
Old 06-26-2011, 10:07 AM   #6617
Persona
Persona's Avatar
Persona is an unknown quantity at this point
I got my greddy intelligent informeter today and I'm having some issues.
The car is a OBD2 1997 S14
When trying to hook it up to the OBD2 port I get communication error, and when using the nissan consult plug it hooks up, but doesnt read any incoming values. (IE: everything is blank.)
Anyone who has used this unit have any advice?
Persona is offline   Reply With Quote
Old 06-26-2011, 10:57 AM   #6618
S14DB
AFC #1
S14DB's Avatar
S14SR shroud. You have to match the Radiator AND the Engine.
Old 06-26-2011, 03:06 PM   #6619
bluuuurr
bluuuurr's Avatar
bluuuurr is an unknown quantity at this point
Does anyone know who forges JIC Magic wheels? I'm assuming their made for JIC by someone else..
bluuuurr is offline   Reply With Quote
Old 06-26-2011, 04:00 PM   #6620
SaNTi
SaNTi's Avatar
SaNTi is an unknown quantity at this point
What front bumper is this? Can anyone link me to the whole kit? Thanks!
SaNTi is offline   Reply With Quote
Old 06-26-2011, 06:01 PM   #6621
Origin
Is it really necessary to have a BOV with an sr20 swap?
Old 06-26-2011, 07:06 PM   #6622
irax
irax's Avatar
are those s14/z32 calipers or are they r33 or somethine else?
irax is offline   Reply With Quote
Old 06-26-2011, 07:57 PM   #6623
codyace
codyace's Avatar
Trader Rating: (58)
POst in the 'identify this' thread
Technically no. Eventually the turbo will surge itself to death though.
Z32 calipers with 13" cobra rotor
Old 06-26-2011, 08:52 PM   #6624
Origin
I should have entered more. I meant an atmospheric one. I want a sleeper. I assume stock it has one just recirculated?
Old 06-26-2011, 09:12 PM   #6625
dillardkid121
dillardkid121 is an unknown quantity at this point
I found a set of Work emotion XD9s for a great deal. They are 17x7.5 +42 offset. Is it worth it for my S13 or is the offset to crazy?
dillardkid121 is offline   Reply With Quote
Old 06-26-2011, 10:23 PM   #6626
codyace
codyace's Avatar
Trader Rating: (58)
If you want a sleeper, you will not want an atmospheric BOV no matter what the car. With that said, you should recirculate the BOV at all times on a MAF car, especially on your Nissan.
Those are way to small, and the offset is kinda weak. I'd say let the deal go, as they'd look better on something else.
Old 06-26-2011, 11:45 PM   #6627
Edwin562
Edwin562's Avatar
cluster is acting weird..... i know speedo dont work cuz it wont read actual speed... it only reads 2 spots... at 0mph and 40mph... it jumps randomly... my tach as well.... are these signs of VSS or cluster going bad or is it something else??
Old 06-27-2011, 12:07 AM   #6628
codyace
codyace's Avatar
Trader Rating: (58)
I'd venture to say it's the cluster more than anything, as if the tach reads funny, and the VSS reads funny...both of those are sourced from seperate sources.
Old 06-27-2011, 12:12 AM   #6629
Edwin562
Edwin562's Avatar
thank you sir... +1 for a helpful dude
Old 06-27-2011, 12:15 AM   #6630
Schassis707
Schassis707's Avatar
Trader Rating: (18)
Schassis707 is an unknown quantity at this point
Feedback Score: 18 reviews
So i have a quic random probably really stupid question but, here it goes.
So im about to do my j30 brakes and was wondering, Would the stock front s13 brakes work in the rear? would a custom bracket be needed to work?
Originally Posted by eddieflo View Post
use paint colors from other vehicles on your 240 too bolts right on
Schassis707 is offline   Reply With Quote
