06-18-2011, 07:05 PM | #6542 | |
AFC #1
06-18-2011, 08:20 PM | #6543 |
Just bought a set of NGK BKR7E11's from napas and the gap is at .47 what should i do? Ive looked and the gap is supposed to be pre set to .44. Should i re gap them or is this normal?
06-18-2011, 11:17 PM | #6545 |
Trader Rating: (58)
Feedback Score: 58 reviews
?What Engine do you have
06-18-2011, 11:18 PM | #6546 |
Trader Rating: (58)
Ever tried google?
The answer is yes.
06-19-2011, 12:00 AM | #6547 |
Does the rb25det shifter assembly use the same clips to hold it in place as a ka? I have one clip on my tranny and i dont see any other grooves for more clips, shifter wont stay in place. Try
Nothing says racecar like a stock car with no interior. |
06-19-2011, 01:36 AM | #6548 |
how hard would it be to replace the valve seals on an s13 ka-de without pulling off the head. I just took it off and don't wanna have to get another gasket set if i dont have to
street dancer. GLEAM |
06-19-2011, 11:23 AM | #6554 |
so i'm going to be swapping in a new clutch in my redtop this week.. do i need anything else besides what comes with the clutch (alignment tool, pilot bearing) and some fluid?
i guess i'm trying to ask.. do i need anything small like new flywheel bolts or anything of that sort? i do know that i have to get my flywheel resurfaced.. |
06-19-2011, 12:33 PM | #6555 | |
Trader Rating: (58)
Clutch kit should come with it all, don't forget some anti seize for the pivot ball/input shaft/throw out bearing slide.
06-19-2011, 01:40 PM | #6556 |
Hey guys I've got an odd question. I've searched and can't seem to get any info on it so...my question is. Is there any way to increase the tension on my trunk lift rods? This is for an S14 with SE wing. When I pull the lever in the car the trunks clicks and is able to be opened. It just doesn't lift up. It doesn't really want to stay up very well either. Thanks!
06-19-2011, 01:59 PM | #6557 |
is it a trunk that didn't have a wing on it before? Or is the car not an SE? The pistons may be valved for a wingless trunk and the extra weight from the wing might be just enough to make it not want to pop up and stay up.
Other than that, I would try replacing them. They're probably blown out or something. How does it sound when you open the trunk? |
06-19-2011, 05:24 PM | #6558 |
they aren't gas struts he's talking about, they're the metal tension rods under the rear deck from what I'm reading. Not sure about how to adjust those though... If I had my car handy I'd try to figure it out for you.
My question is kinda random, but does anyone know if Nissan dealerships still sell the rear 'NISSAN' vinyl for the S13's? Mine just got out of paint, and I can't seem to find an OEM decal. (again, not looking for the 240SX or Silvia badges, just the "NISSAN" decal under the tail light) Thanks in advance. |
06-19-2011, 05:35 PM | #6559 | |
06-19-2011, 05:43 PM | #6560 |
are 180sx and s15 turbo elbows the same as s14 turbo elbows?? i understand s14 and s14a elbows are diffrent but what about 180sx and s15 elbows?? would they fit my s14? im also talking about uprated ones!
oh and engine im talking about is the sr20det
on s-body no.4!!! |
06-19-2011, 05:48 PM | #6562 |
Trader Rating: (68)
Feedback Score: 68 reviews
Some turbos have built in divider plates, make sure your elbow doesn't have a divider plate built in, or vice versa.
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! http://zilvia.net/f/private-sellers/...meistah21.html |
06-19-2011, 05:59 PM | #6563 | |
It's a base with SE options. The wing being one of them. Ya no pistons here. Just simple metal tension rods. If you have any ides on how to adjust the tension on them I'm all ears. Thanks for replying so quickly though Last edited by Import Convert; 06-19-2011 at 08:13 PM.. Reason: typo |
06-19-2011, 10:25 PM | #6564 |
Came across some 5zigs on the cheap, only problem is one of em is all fucked up, big ol chunk outta the rear.
Found a thread regarding cracked 57D-fixes? Based on that gramlight it's defiantly repairable lmao Anyone have a legit wheel repair shop they cam reccommend ? Link also describes Brian Hop as being the go to guy, anyone have an email or contact info? Otherwise I'll just take it to a local shindig that does warrenties Last edited by towlie; 06-19-2011 at 11:13 PM.. |
06-20-2011, 12:11 AM | #6565 | ||
Trader Rating: (58)
06-20-2011, 12:35 PM | #6567 | |
fine
06-21-2011, 07:52 AM | #6570 | ||
Ramonesfreak2010, The wires that are connected to the positive terminal? Trace them back. If they don't go anywhere, take them out. If they go to something, connect them to power. |
