03-08-2016, 07:55 PM | #572 |
Got new tires been having a blast running about 18 lbs of boost and all of a sudden it dies on me and wont start seems like it is starving for something but it has fuel and spark. anyone have any ideas it cranks over but i can hear that its not right i can post a video tomorrow. thanks if anyone helps out
03-09-2016, 10:09 PM | #575 |
So was I ... until the motor blew yesterday it shut off and wouldnt start again so i did a quick compression test:
Cylinder 1: 120 PSI Cylinder 2: 0 PSI Cylinder 3: 120 PSI Cylinder 4: 60 PSI So obviously knowing what was wrong today after school i got to pulling the motor out. 4 hours later and its out: [IMG] [IMG][url=https://flic.kr/p/EXw26K] [IMG][url=https://flic.kr/p/F4oPo9] So i already have a built head and it was a stock block, I am debating if i should rebuild the motor or get a new short block or possibly a full motor. The short block will be built to hold 400-500 hp i have been looking at graveyard custom engines if anyone has anything to say about them please let me know? http://www.graveyardmotorsports.com/product_p/gm%2098-5130.htm I am open to all opinions and thoughts on my best option here... Also have a Doc Race bottom mount with ISR 3871 turbo and the AN fittings and a ISR downpipe too .... for sale if anyone is interested i want to go top mount with a gtx. Update to come, might change the bay color. |
03-10-2016, 09:59 AM | #576 |
Anybody have any thoughts on the graveyard motorsports blocks? I am reading to see whats best but id like to get the ball rolling soon so i can get it back in the car as soon as possible.
03-10-2016, 10:36 AM | #577 |
So I've never personally heard of their company or seen their products, but at their prices they're cutting some serious corners somewhere and they have very vague product descriptions. Just to compare our Stage 1 SR20det short block runs a little over $4,000 and is rated to a safe 400hp. Sure it's more expensive but if it's all in the details. I'd advise to do things right and not jump on the cheapest price you can find.
03-10-2016, 12:36 PM | #578 | |
03-10-2016, 12:46 PM | #579 |
No problem man, if you want some more detailed quotes on parts or help possibly putting a block together email us!
03-10-2016, 02:03 PM | #580 |
Do you have a wideband? Make sure you figure out what went wrong before running a new block. Assuming the other one just gave out may be costly.
I don't like how your MAF is right after a pretty tight bend. This can screw up readings. |
03-10-2016, 03:15 PM | #581 |
I do have a wideband, and yes very good point.. I will not be buying anything till i know. I don't have a MAF, the car runs on a GM MAP sensor. What is the easiest way to know what exactly went wrong? I can tear the head off the motor and go from there?
03-10-2016, 05:26 PM | #582 |
Well, no or low compression screams that it's a ring issue in the bottom end. So regardless you'll have to pull the head to check that out. And once you tear everything down and inspect it you'll know what you have to rebuild with.
03-10-2016, 05:28 PM | #583 |
If I had the make a very broad guess and go on the assumption that he car was running 100% before it blew I'd say that you cracked a ring land from your rings not being gapped enough for the boost that you were running.
03-10-2016, 06:39 PM | #584 |
Hmmm. it blowing up because of 18psi doesnt sound right. I can think of 4 locals off the top of my head that run their SR, on 18 with a 3871/2871r would look more into the data log of aem and see if you spiked or something like that. could also be a tune issue. ton of locals use RS Enthalpy ECU, including myself and its great.
03-10-2016, 06:47 PM | #585 | |
03-10-2016, 06:53 PM | #586 | |
03-10-2016, 06:57 PM | #587 | |
03-10-2016, 07:27 PM | #588 | |
03-10-2016, 07:33 PM | #589 | |
03-10-2016, 08:17 PM | #592 |
Ripped the main harness and almost everything else out of the bay to change up the color while i can.
[IMG][url=https://flic.kr/p/F6F3ZJ] [IMG][url=https://flic.kr/p/EFpg79] [IMG][url=https://flic.kr/p/EXuKdW] [IMG][url=https://flic.kr/p/EbgAjb] [IMG][url=https://flic.kr/p/EFpfdf] Major key right here [IMG][url=https://flic.kr/p/EbAYKp] |
03-11-2016, 07:14 AM | #593 | |
03-13-2016, 12:49 AM | #594 |
Making some good progress friday and saturday night working on the car. I am going to have the motor rebuilt at Precision Machine and Balance in NH, so ive been stripping it down getting ready to send it there. I am going to take off the rocker arm stoppers for this next build for sure and lower the rev limiter a little bit. I am going to try to get a Garrett gtx turbo but i'd like to go top mount too so only if i can sell my bottom mount doc race and the ISR 3871.. here are some pics.
[IMG][url=https://flic.kr/p/FbRuuG] [IMG][url=https://flic.kr/p/EgMtG2] Been sanding the bay too.. i plan to respray it a different color while i have the time. I am also looking into Chasebays brake boost eliminator kit... Sanding with 180 grit then 220 to 400 for primer. [IMG][url=https://flic.kr/p/FbRuCs] Also got a chance to bring my front bumper into my school to fix it during shop week. Im a senior now and will be graduating soon but luckily got to do this fiberglass work with my teacher. Will have finished pics monday/tuesday. [IMG][url=https://flic.kr/p/FbRweo] Also never posted much of my tools heres a nice wrench drawer picture i had. [IMG][url=https://flic.kr/p/ELzMiG] |
03-16-2016, 11:25 AM | #596 | |
03-16-2016, 02:17 PM | #597 |
Good for you man, awesome job so far. When I was 16 I bought my first 240sx and riced it up and learned everything on my own as I went, and you know what... do what you want, don't listen to all these expert d1 drift champions on here, chances are more than 50% of them were hardcore ricers back in the day, so either way you look at it you have a head start on them there.
With that said, you gotta stop doing dangerous ish on the motorcycles homie. One slip up is all it takes and bam... brains all over the road. |
03-17-2016, 07:39 AM | #598 |
Got the motor dropped off at the machine shop and out of the way. Been working on the engine bay some more, removed the brake booster, windshield wiper motor, all the brake lines, and i have removed the brackets for the brake line to the caliper because i need to do some rust repair on both sides where the brake lines meet. Going to take care of this rust before it gets worse because its not all that bad yet.
I will post more pictures tonight but im in school and cant access flickr. Getting ready to prime the bare metal spots in the bay and then i can spray basecoat. My Collision repair skills have improved quite a lot and it will show in this paint job. |
03-19-2016, 11:11 AM | #599 |
Been doing some rust repair getting ready to paint the bay, and also went to my local supplier to get some paint to spray.
Quick template i made to get it right. [IMG][url=https://flic.kr/p/EuYunR] [IMG]20160318_215017 by [email protected], on Flickr[/IMG] [IMG][url=https://flic.kr/p/EZYoU9] [IMG][url=https://flic.kr/p/FgRQQh] [IMG][url=https://flic.kr/p/Fj9bC8] [IMG][url=https://flic.kr/p/FswPf8] [IMG][url=https://flic.kr/p/EuYvDt] Some of the stuff i grabbed today. Prepsol, basecoat, reducer, clearcoat, and a high build primer for some bare metal spots. Within the next year or so i am going to respray the outside of the car myself.. need to do some body work on it that i should have before i got it sprayed at Maaco. [IMG][url=https://flic.kr/p/EuYvhM] Last edited by futures14drift; 03-19-2016 at 11:30 PM.. |
03-19-2016, 11:32 PM | #600 |
Tonight i undercoated both wheel wells, and painted the brake lines and clutch line black while i had them out. Tomorrow im going to hit the bay with 400 grit and also paint the brake booster. I dont know if i should re wrap the whole thing in gold heat tape or not.. opinions are welcome.
Just waiting on my spray gun in the mail after this and i can start reassembling the engine bay accessories then i will just be waiting on the motor to drop it back in and start the break in process. Also need to do a few wheel bearings before then. Thanks for reading will have pics tomorrow. |
