Old 06-13-2015, 12:59 PM   #31
alex_s817
alex_s817 is making his/her stupidity well-knownalex_s817 is making his/her stupidity well-knownalex_s817 is making his/her stupidity well-known
Out of curiosity, what radiator/cooling setup are most of you guys running? I'm trying to get an idea of condenser placement as I know some people opt to cut the upper rad support a little bit to help with fan motor clearance. Pics of rads/fan setups are welcome!
alex_s817 is offline
Old 06-13-2015, 02:09 PM   #32
usrocket
usrocket is an unknown quantity at this point
I have an S13 with an RB26. Need AC like a mofo. All I have is a 25 conpressor.
usrocket is offline
Old 06-13-2015, 04:41 PM   #33
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
My RB25 fan/condenser/radiator setup.
Flex-a-lite 432 (dual 12" pushers) trimmed to fit perfectly inside the radiator support. Koyo radiator and stock zenki condenser are mounted on the original brackets. All I need are lengthened lines with the correct fittings to hook up to the RB25 compressor.
dbeiler is offline
Old 06-13-2015, 05:14 PM   #34
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Rb with ac
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline
Old 06-13-2015, 07:36 PM   #35
alex_s817
looks like a clean setup dbeiler! I'm sure any AC shop can help you with the lines, just use some aluminum weld on crimp ends with the oem fittings. You have any issues with the car running hot at higher speeds from that shroud?
Old 06-14-2015, 06:23 PM   #36
laurentj23
laurentj23's Avatar
laurentj23 is an unknown quantity at this point
most the ls swap use mishimoto ka rad. only a fews are using chase bay
'Born Ready!',LJ
laurentj23 is offline
Old 06-18-2015, 06:19 PM   #37
alex_s817
Had some scheduling issues that slowed me down, please stay tuned for completed pics next week! Until then here's a close up of the hydro dip work my buddy Spencer did last year for this car.
Old 06-18-2015, 06:35 PM   #38
l adam l
l adam l's Avatar
l adam l is an unknown quantity at this point
^ thats... So clean. Can't wait to get mine there.
S13 is a sporty garbage can.
l adam l is offline
Old 06-23-2015, 11:34 PM   #39
alex_s817
completed pics will be up tomorrow!
Old 06-23-2015, 11:35 PM   #40
fd94
fd94 is an unknown quantity at this point
Awesome
fd94 is offline
Old 06-24-2015, 09:51 PM   #41
EnemyS15
EnemyS15 is an unknown quantity at this point
I am very excited for this!!!!! Having rhd converted car and sourcing jdm ac condenser is a pain in the ass.
Check out my build thread! http://zilvia.net/f/builds-builds-on...rhd-build.html
EnemyS15 is offline
Old 06-24-2015, 09:53 PM   #42
usrocket
I've been following the updates and it is safe to say that you have a customer ready. I'm using an RB25 Compressor on an RB26 so it'll be interesting to see how this will work. It's just an AC conpressor, so fitting are the only issue. However, I'll keep the thread updated and see how it works. If I'm correct, the compressors for the RB engines are different from the R32 to the R33-34?
usrocket is offline
Old 06-24-2015, 10:35 PM   #43
alex_s817
I'd imagine you can literally just flip these hoses to the other side and everything will work the same, just need to figure out the compressor fittings.
thanks for keeping up with the thread! I have heard that the R32 compressors are different, however I've never seen any of them in person for comparison. If we can get our hands on any of them, there's a good chance I'll be able to cross-reference the fittings with a US compressor fitting of some sort.
Old 06-24-2015, 10:56 PM   #44
alex_s817
Shot some completed kit photos as well as some installed pics today. I know everyone is waiting on pricing, please give me another day or so to get it all figured out. This kit was built on the fly and while keeping costs low was a priority, quality prevailed in a few instances and I haven't crunched the numbers just yet.
Disclaimer: Mounting brackets pictured are "prototypes." They have multiple holes, aren't cut perfectly, and were solely used for mock-up. Production brackets will be water jetted. Thanks!
Details:
-I was able to source a housing with the correct threads so that you may use your OEM Nissan AC pressure switch with no need for modified wiring.
-I made adapter fittings at the evaporator (firewall connections) so that while the chassis may change, (s13, zenki, kouki) the hoses on the passenger side stay the same. (have yet to measure s13 to clarify this)
-Same goes for the compressor fittings, they have standard AC o-ring fittings welded to them now. In the event of a compressor swap, there's a chance the lines wont have to be replaced, just the fittings themselves.
-Kit was designed with specifically RB and JZ swaps in mind, allowing them to be the exact same up to the hoses on the Driver's side. Lengths and fittings on the driver's side hoses are subject to change based on drive train and compressor choice. This is also beneficial when adding the service ports to the hoses. RB exhaust manifolds and waste gates are generally too close to the compressor for us to run the high/low charge ports there and will likely result in melted caps and leaky valves. I located them near the firewall for this reason, however on a JZ swap, especially those running 4" down pipes, I'll feel much better knowing the charge ports are far far away at the compressor.
Old 06-24-2015, 11:23 PM   #45
alex_s817
Modified Evaporator Fittings:
Pass side hose routing:
Modified J30 Compressor Fittings:
Driver's side hose routing:
Front Crossover Hardline:
High press hose routing (under condenser, in front of radiator, connects at lower driver's side fitting, routes to firewall)
Old 06-25-2015, 08:31 AM   #46
Mr.slipngrip
Mr.slipngrip is an unknown quantity at this point
Wow nice work count me in for a rb setup.
Mr.slipngrip is offline
Old 06-25-2015, 04:31 PM   #47
ProjNightshade
ProjNightshade will become famous soon enoughProjNightshade will become famous soon enoughProjNightshade will become famous soon enoughProjNightshade will become famous soon enough
It really looks great.
My only hangup about the system is having the fans still blowing through the condenser. Is there any way you could move the condenser further forward to allow the pusher fans to be mounted directly to the radiator?
Originally Posted by iwishiwas-all* View Post
Unfortunately for you, this is not Darwin vs Christ.
ProjNightshade is offline
Old 06-25-2015, 05:43 PM   #48
projects14zenki
projects14zenki's Avatar
projects14zenki is an unknown quantity at this point
Well I'm sold I'm in for price and eta on the kits
projects14zenki is offline
Old 06-26-2015, 12:46 PM   #49
max1008
max1008 is an unknown quantity at this point
Kit looks sweet. I really do like the idea of using the J30 condenser instead of the rb25. I have the rb25 condenser and mounting brackets. I have the wire specialist wire harness but not sure if it was equipped with AC (bought the car with the RB25 already installed.
So is this with the J30 condenser or Rb25?
max1008 is offline
Old 06-26-2015, 02:44 PM   #50
alexisonfire
alexisonfire's Avatar
alexisonfire is an unknown quantity at this point
Totally interested in buying this also for my rb
alexisonfire is offline
Old 06-27-2015, 12:40 PM   #51
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
Word!!! I'm In....though Mine could be somewhat simple?
You live in Raleigh too. Sweetness!
Z32 w/ RB25:
I'll prob have to ditch the NA low side pipe and swap to the TT line (due to route location is diff) or just make a New one but Should be Very close to the Skyline setup.Gotta Have A/C!
I will Be hitting you up at some point for sure.
Sub'd
z-tERty-2
MrFairlady is offline
Old 06-27-2015, 02:04 PM   #52
Sforteen
Sforteen is an unknown quantity at this point
R32 compressors are longer, and will not fit with FUll Race manifolds and likely others as well.
R33 compressors are at least an inch shorter, and will fit with Full Race manifold.
97-98 S14 koukis have a variable AC compressor and do not have a temp switch in the evaporator to cycle compressor, It will freeze up on you if you put in a normal AC compressor.
I have AC in my car and my car runs hot with it on, i still have stock radiator and RB clutch fan. I would like a condenser that fits on the other side of core support so u can run a thick Dual pass radiator and a good shrouded electric fan setup..
Sforteen is offline
Old 06-27-2015, 05:23 PM   #53
alex_s817
UPDATE: System vacuumed down and held vaccuum no problem, however the car is currently having an ignition issue and will not start so I have yet to charge it with refrigerant. Before I post any sales info I need to be able to provide you guys with pressure readings and vent temperatures. Sorry for the delay, something like this always happens, but as with most swapped cars and modifications go, I know you all already know that haha.
I appreciate it! will keep you posted!
In most factory configurations, the fans/condenser placement is set up like this. The condenser needs airflow too if there's any hope of having cool air coming through the vents at idle (traffic, stop lights, etc). I understand your concern, especially because we all know that these engines tend to run hotter than others. I will log the coolant temps once I get this car charged so I can give you guys an idea of what to expect. Ideally, I would love to do a tucked radiator/AC condenser combo that tucks up under the rad support and allows users to run a large fan/shroud setup. The only issue with this is cost because custom radiators are pretty pricey to have built.
Glad you like it! Pricing will be up within 2 days, still working to get it as low as I can. Thank you
thank you! Are you meaning to say "compressor"? this is with a J30 compressor, custom condenser/bracket. As for the wiring, I am not sure. There are a few potential wiring configurations from all the different swap harnesses and I am unfamiliar with that so I cant really give you a definite answer, however I know the guys at wiring specialties can help you out if you give them a call.
Thanks for your interest, please stay tuned for updates soon.
Z32 w/ RB25:
Sub'd
Yes sir sure do! I'm in Garner, about 20 min from DTR. Shoot me a PM and we can get something squared away for you no problem! I dont have an issue with building one off hose/line set-ups given I have access to the car, its actually so much easier than a production version haha.
Thanks for the info! I have been reading about the koukis and that potential issue. Either an evaporator swap from a 95-96, or a modified compressor bracket to use the KA compressor on an RB could be a thing. Haven't checked into that yet.
Old 06-27-2015, 05:32 PM   #54
fd94
As long as there's a solution everything will be good
fd94 is offline
Old 06-27-2015, 08:24 PM   #55
Sforteen
I just installed the Evap temp switch in my Evaporator and had it control the ground side of the compressor clutch relay.
I used a temp sender from a honda cause i had it laying around, but from the looks a factory Nissan one from a Zenki should work fine, it just sits in the fins of the Evap coil.
How long are you letting it sit in a vacuum? Tig welding those damn fittings is tricky, there so damn dirty!! i have a small leak somewhere on my car just havent had the time to mess with it, i tig welded my setup as well.
what Turbo manifold is that guy using and how much clearance is there with the J30 compressor.
Sforteen is offline
Old 06-27-2015, 09:13 PM   #56
alex_s817
oh okay cool, not too difficult then. Sat in vacuum for an hour.
The fabricator who does the fittings is no joke, plus a good bit of scotch brite and acetone prep goes a long way for sure.
turbo kit is from Raw Brokerage, twin gates fit fine, it's a little tight but could be tighter and still work. I had to turn the dump tube a few degrees but that was it.
Old 07-01-2015, 08:57 AM   #57
max1008
Yes I meant J30 Compressor...Can't wait to see the pricing...I'm dying out here in this Florida Heat Thanks for all your hard work and fabricating!
max1008 is offline
Old 07-01-2015, 06:40 PM   #58
alex_s817
I appreciate the kind words! What cooling setup are you running right now and what kind of temps do you see? Just curious as the owner of this blue s14 is looking to upgrade.
Old 07-01-2015, 06:40 PM   #59
alex_s817
So for what everyone is waiting for, PRICING.
The kit is going to be priced at $599 shipped. Now I know everyone was really hoping to keep it under $500, and that was my main goal as well. However I just cannot afford to make them that cheap at this time.
Now what I would love to do is a group buy with pricing at $499 + shipping with a minimum of 10 buyers. The larger quantity of buyers allows me to cut both water jetting and welding costs. If anyone is interested in doing so please let me know. As you already know, these kits are going to be shipped with all the necessary hardware, condenser, o-rings, hoses, fittings, and mounting brackets. After it's installed just run the car up to your local AC guy and have him vacuum it down and charge it up.
Old 07-01-2015, 06:51 PM   #60
max1008
I am currently not running anything. Past owner ripped everything out except behind the dash...so it will be a complete fresh build.
max1008 is offline
