02-28-2013, 05:49 PM | #31 |
Wow! I just picked up a 90 hatch rolling shell clean title, and I need to do all of this interior work...now you have shown me what im getting into lol. Nice build looking forward to seeing that Ka-t soon!
more tax returns = more car parts |
03-03-2013, 01:48 AM | #33 |
Trader Rating: (71)
Feedback Score: 71 reviews
not much update! talked to my machinist and went over few stuff on whats going to be done to block. head and crank. im not used to having someone do the work for me but machining is abit much too to get into...lol
anyways.....spent my thursday and rest of fridays electroplating tons of oem nuts, bolts, brackets. im using a caswell copy cad this my 1st electroplating and im very pleased how they came out! 1st thing i do with the nuts and bolt are bead blast em with either aluminum oxide or glass bead. i degreased em using caswell sp degreaser powder mixed with distilled water and heat up to 140-160f then soak 5-10mins. then they go on acid bath till the fizzing stops. heres some nuts and bolts soaking on distilled water before plating to prevent rust flash. my setup. using an ebay 10amp max rectifier adjustable. the bath! where magic happens! lol you get a bright zinc finish. still need to dip em on either yellow iridescent or black chromate(which im going to nxt day off) |
03-03-2013, 08:41 AM | #34 |
Trader Rating: (50)
Feedback Score: 50 reviews
holy shit, taht is clean, can you make me a list of what you are using so that i can look into possibly getting this setup as well.
FS: DSS 1pc Steel Non ABS, 6bolt axles WTB: Boost Gauge, Hatch Roof Wing |
03-03-2013, 10:30 PM | #35 | |
Trader Rating: (71)
have their 1.5g kit plus youll need an rectifier cc/cv at least 10amp higher the better |
04-01-2013, 01:27 AM | #38 |
Trader Rating: (71)
finally got the block, head and crank frm the machine shop! they charged me 382.
hottanked, magnafluxed, decked and bored out .020over resurfaced, pressure tested, hotanked, exhaust guides, valve seats grinded polished only decided to ruan aem fuelrail. has 11mm holes for injectors went ahead and bought me an ATI super damper frm summit got to file fit the top rings @ .018 although, i wanted the bottom ring to be at .020 well that isnt the case. unfiled 3 of the rings had ring gap of .022 & one was right fileable. any thoughts why this would be? could wiseco sent me the wrong rings???or my machinist bored it out too much but i doubt it. i moved the rings around to see if they made any difference but it was the same 3 rings @ .022 and 1 @ tight cant remember exactly. Last edited by hpipro4; 04-02-2013 at 12:34 AM.. |
04-01-2013, 01:52 AM | #39 |
Really great work you're doing my dude, I love seeing a KA-T done right!
P.S. you have alotta potential man, so did you have any mechanical experience before this or did the S13 force it? You gotta try to get in a shop if you already don't work at one.
Haters gonna hate |
04-01-2013, 02:02 AM | #40 | |
Trader Rating: (71)
had a few experience during highschool then went to wyotech then more experienced working on my car. my 1st time building an ka engine tho. ya i work at a shop but not high performance stuff! |
04-01-2013, 02:11 AM | #41 |
Great stuff man keep it up you will go places. I took autoshop in highschool too, my dad had a bunch of mud trucks growing up we always worked on as well. I only worked in junkyards and a shop that installed stereos, systems, big rims and lift kits. Hopefully after my KA-T build I can use it as a driving billboard of my work and get in a performance shop. Anyway you're doing it right man you get props bro!
Haters gonna hate |
04-04-2013, 12:35 AM | #45 |
Trader Rating: (71)
thanks yall
trouble with the wiseco rings!!! guess got bad batch of 2nd compression rings their pre-gapped too much cept one. their customer service is kinda crap over email they wont reply back guess ill have to call tmr and be on hold forever....lol |
06-01-2013, 01:09 PM | #53 |
Damn, it's looking so nice. The yellow chromate really pops against that flat black, why did you decide to stick with stock valve train with such great machine work?
06-01-2013, 10:35 PM | #54 |
Trader Rating: (71)
thanks! with my hp goal i should be fine with stock but eventually, i will upgrade later on. that was my plan but wasnt too sure which cams, springs or valves to go with.
06-04-2013, 12:28 PM | #55 |
Wow! Your interior looks 150 times better now! Its amazing to see the transformation from doodoo brown to slick black! My friend just put a new carpet in his MR2 and its so much fresher now!
Keep up the good work!
Project cars: "Fail to plan, plan to fail" |
06-06-2013, 07:45 AM | #57 |
Such an amazing thread. Your attention to detail makes me super jelly lol. Love it though man, keep up the amazing work! I dont know how you put up with all that wiring lol, but props to you for doing so!
NAVY |
