Old 04-17-2012, 07:52 PM   #31
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
my little bro n i went to nismo fiesta. Saw some really nice rides out there n had a chance to dyno my car. Got almost exactly what i expected. This was on a mustang dyno too, which i heard always gives results a bit lower than the actual ones:
i did 243ft-lbs n 269whp at 8-9psi(the way i daily drive)
then i tried to turn up the boost to about 11 and my car started acting up at mid rpm range....again... I was still able to do 255ft-lbs n 279whp at 11psi
http://www.youtube.com/watch?v=http://www.youtube.com/watch?v=wUmklYylwhM&context=C4b4d43dADvjVQa1PpcFN6DN-GjabQWVnGhuZmZcLJ8h9VSt3D1lE=
i also got to do a simulated 1/4 mile pull which wasnt very successful. Keep in mind that this was my very first time on a dyno n i was very distracted..I DIDNT LAUNCH IT HARD alm
Got 13.5s @107mph
http://www.youtube.com/watch?v=http://www.youtube.com/watch?v=lNxNCt_80LM
feito is offline   Reply With Quote
Old 04-17-2012, 08:15 PM   #32
feito
feito's Avatar
^fixed, kinda..
Old 07-19-2012, 06:09 PM   #33
Superaison
Superaison is an unknown quantity at this point
I just completed my RB swap, how did you manage the clutch fan? is your engine just sitting that good lol
Superaison is offline   Reply With Quote
Old 07-19-2012, 09:51 PM   #34
feito
feito's Avatar
mount it behind the clutch rather than the front (in between engine and clutch rather than between clutch and radiator) and shave the blade fins on the back enough to clear the crankshaft damper.
Old 07-19-2012, 09:54 PM   #35
Superaison
any better pics ? so did u unbolt the actual plastic blade and put it on the back side?
Old 07-19-2012, 10:18 PM   #36
feito
feito's Avatar
yeah, just remove the 4 10mm bolts (i think) and bolt it on the back of the clutch, shave the fins to clear the crank and wallah!!.... bro i got so excited when i saw your pm, i though i had found a stock fan shroud haha
Old 07-19-2012, 10:19 PM   #37
Superaison
I was just looking in a b/s/t thread that had one for sale.. I was just thinking about using the fan I already switched it around I said fuck it I wanted to know, brings it .75" or so closer to the engine.
edit:
here they are
http://zilvia.net/f/sale-items/46545...ard-parts.html
http://zilvia.net/f/sale-items/46428...-ka-sr-ca.html
Old 07-24-2012, 09:04 AM   #38
feito
feito's Avatar
I meant an rb25 fan shroud, i have the stock ka24 shround (which btw im selling $20) n theres no way in hell u can make that fit with the rb. But thanks!
Old 08-19-2012, 04:35 PM   #39
feito
feito's Avatar
ok so i got some work done to it.
first i got my nismo 2 way installed along with new urethane bushings. I gotta say, those bushings werent as easy to install as i expected....
removing the old oem bushings from the subframe is kinda hard, just as hard as the removing the subframe main bushings but on an uncomfortable position, having a lift would've really helped... i also put some redline in it, good stuff.
little harness tuck to allow for more lowering...
then came the suspension. Spl arms on back and tension rods upfront.
pretty simple but time consuming stuff. I also removed my coils to inspect them and clean them up. Turns out one of my fronts is on its way out, it should do it for a while thou...
So this is how i spent a couple of afternoons including my b-day
Old 08-19-2012, 04:39 PM   #40
feito
feito's Avatar
so today i took my car to get it aligned, wasnt very far off but had to be sure and wanted to straighten my steering wheel up haha
Now i just need a good fender roll (made an ugly gash on one of my fronts) and i should be good to go. I am driving the car but im afraid im gonna make another gash any second...
We got plenty of rain yesterday so my love is all dirty, it's ok thou cus we both like it dirty
Old 08-19-2012, 05:30 PM   #41
smartoss
smartoss is an unknown quantity at this point
Are you still running spacers with the mustang rims?
smartoss is offline   Reply With Quote
Old 08-19-2012, 06:09 PM   #42
feito
feito's Avatar
yes, the ones pictured, dont know what size they are but i bealive they're some vatozone ones...
Old 08-20-2012, 02:59 PM   #43
Yellow4g63
I just did this last month, coilovers and spl arms in the same day.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 08-28-2012, 10:20 PM   #44
feito
feito's Avatar
That's good! Did u tuck your body harness, do the diff bushings and fully disassembled the coilovers for cleaning and inspection too?
I've been thinking a lot about my intercooler and piping setup. I really hate my intake manifold but have decided to keep it for a better mid range power. i really wish they'd make an affordable front facing intake with long runners, but it just aint happening.. I'm also having second thoughts about my fmic. i've been wondering about going back to a smic setup this time using an aftermarket/bigger core and at the same time shorten my piping for better throttle response. Either way, i think im gonna be getting one of these kits:
Then im gonna get the pipes welded together so it can only be one coupler on each intercooler side.
So now im trying to score a good deal on an r34 smic or an arc smic and a rb25 stock fan shroud.
Old 08-28-2012, 10:25 PM   #45
Yellow4g63
Didn't tuck the harness car won't be that low, The coils were brand new out of the box . You can try a TT Supra sidemount. The core is thicker than the stock RB cores but It will prob still get heat soaked. The Fan clutch is a huge + for cooling.
91 Nx2000 VVL yo
Old 09-01-2012, 07:49 PM   #46
nu_born
nu_born's Avatar
nu_born will become famous soon enoughnu_born will become famous soon enoughnu_born will become famous soon enoughnu_born will become famous soon enoughnu_born will become famous soon enough
^^what in dafuq
Nice build you've got going here man; really itching to get started on my s13 now lol.
nu_born is offline   Reply With Quote
Old 12-23-2012, 10:34 PM   #47
feito
feito's Avatar
started working on my new fmic set up today. Removed everything and started working on the charge pipe. Should come out pretty nice and the new greddy v-spec ic i'll be using should help a lot.
One last look at my old fmic setup before removal. Keep in mind that i always considered this setup to be temporarily
cut and tacked part of the chargepipe. Hopefully I'll work on it some more tomorrow
Btw, Im working on another major project. Should be making a new build thread soon..
Old 12-24-2012, 12:20 AM   #48
RastaS14
RastaS14's Avatar
RastaS14 is an unknown quantity at this point
Diggin the build and all the fab work! Good stuff!
RastaS14 is offline   Reply With Quote
Old 12-29-2012, 07:14 PM   #49
feito
feito's Avatar
finally got some work done:
going from like 10 couplers to only 4. Tacked the charged pipe with my arc welder (stainless steel). I got me an eastwood 175 for xmas, i should have my 220 power hooked up in a couple of weeks and will be able to weld it. Cant wait!
Old 03-04-2013, 06:55 PM   #50
feito
feito's Avatar
finished the new fmic setup:
Can anybody guess what my next upgrade will be?
Old 03-20-2013, 08:12 PM   #51
feito
feito's Avatar
so i got one of these, got lucky at a local yard and couldnt let it pass. These things are freging huge, i have even read about guys running them having problems with their oil temps being too low at the track, with the stock thermostat in it. Anyway, i live in texas, and the car is mostly daily driven, but when u drive hard in temperatures above 100 im sure temps cant be too low...
I took it apart and checked the thermostat and it opened up, i just didnt have a thermometer and couldnt check what temp it opens at. So i'll check it again after i buy a thermometer.
The cooler plus the oil filter stud i got the hardest parts covered, just need the sandwish plate and hoses and hardware, yeah i find that to be the easiest part. But i wont be installing a cooler until i buy an oil temp gauge unit, that way i can compare the temps before and after.
btw, it wont be installed on front of intercooler
Old 04-13-2013, 08:59 PM   #52
feito
feito's Avatar
so i sold the oil cooler. I coulndt fit it anywhere, it was either gonna have to seat on top of the intercooler, but then the intercooler was gonna seat too low, or on front of the intercooler, which would affect my intercooler's temperatures very drastically i think.
Putting the oil cooler setup plan aside for a couple of months.
I did however replace my worn out subframe bushings with ES polys.
Old 08-13-2013, 11:02 PM   #53
feito
feito's Avatar
what's going on here
Old 08-14-2013, 09:39 PM   #54
smdodgers
smdodgers's Avatar
smdodgers is an unknown quantity at this point
i see you have an deep fuschia kouki!
me too
nice build, will subscribe!
A drift a day keeps the Hondas away.
smdodgers is offline   Reply With Quote
Old 08-27-2013, 09:30 AM   #55
soundboy
soundboy is an unknown quantity at this point
Pimp
Sent from my GT-P3110 using Tapatalk 4
soundboy is offline   Reply With Quote
Old 08-28-2013, 09:35 AM   #56
seagrasser
seagrasser is an unknown quantity at this point
Looks like it is getting serious now. Want to know spec on exhaust manifold.
S14 RB25
seagrasser is offline   Reply With Quote
Old 09-27-2013, 05:55 PM   #57
feito
feito's Avatar
i kinda wrote a review of it on here http://zilvia.net/f/z-chassis/461047...ml#post5369034, last post. More parts keep arriving every week, but i wont start working on it until i have every single part for the upgrade and until im done with my little bro's car, very soon.
Old 10-25-2013, 09:06 PM   #58
feito
feito's Avatar
close to surgery
Old 10-25-2013, 10:25 PM   #59
canasion35
canasion35's Avatar
canasion35 is an unknown quantity at this point
Hell yeah man I cant wait to see how it looks afterwards!!
R.I.P Joe Alverez
You will never be forgotten "Sky Zero"
canasion35 is offline   Reply With Quote
Old 10-26-2013, 09:17 PM   #60
40craz
40craz's Avatar
40craz is an unknown quantity at this point
What exhaust manifold is tht
40craz is offline   Reply With Quote
