06-12-2008, 01:54 PM | #31 | |
Did you forget about velocities? Plus hotter air flows faster. |
06-13-2008, 01:06 PM | #32 | |
AFC #1
Header Main and Secondary sizing is important cause you want to create a scavenge effect to pull the exhaust out of the cylinders. Making it flow faster then an open head. To small and it will restrict. To big and the gases will stall out negating any gain over open head. After the header collector, bigger is better. As long as the exhaust stays the same size or steps bigger as it gets further. You should see gains up to a point. should never loose anything. The gains from 2.5 to 3" for me was 4~5hp. Tq was the same. I also replaced the factory "fake" cat with a resonated test pipe. I think this is a bigger problem on the S14's cause the fake cat is a hollow case 6" across and 4" high. Big area for exhaust to stall out and possibly cause backpressure. The gains being negligible 2.5" vs 3" on the KA. It comes down to there being more 3" exhausts on the market for the 240sx. IMHO and others that have heard my car with the 2.5" and the 3" said the 3" is lower toned and better sounding overall. I dunno about DBL arguments cause I don't care down here and both my exhausts were JASMA cert for sound level. Exhaust leaks and obstructions will make you lose power. Make sure you get new gaskets and use coper sealant on the flanges. I would rip out S14 fake cats and replace them with (resonated) test pipes. Think it was stupid of them to place that there when the real cat is in the DP. Odd shape allows for turbulence and going from a larger diameter to a smaller creates a pressure differential which results in back pressure. Cliffs: It's all about flow. You want to get the exhaust out as fast as possible.
06-16-2008, 09:21 PM | #33 | |
Basically there is a lower velocity travelling through the exhaust which is disrupting intake velocity in the higher RPM range. In refrence o KA's using a 3" exhaust pipe. It would be more for KA24de's rather than KA24e's. KA24e's have one less exhaust valve per cylinder and the CFM rating on the SOHC head is about a 1/5th less in flow to the DOHC head. Timing on the KA24e is slow too, you negate power losses with a large pipe and that kind of timing, with CFM rate.
06-17-2008, 08:09 AM | #34 |
I blame it on the old muscle car guys that created this idea that back pressure in awesome. No. It's all about flow. Picking the proper diameter for the exhaust gases to travel while still maintaining a good velocity will give you the best results.
S13 Coupe SR20DET |
06-20-2008, 09:36 PM | #35 |
http://en.wikipedia.org/wiki/Backpressure
http://auto.howstuffworks.com/muffler5.htm and the best so far: http://www.flowmastermufflers.com/backpressure.html Maybe that might help? I do need a little backpressure for my go-ped, (a 2-stroke though.) |
06-21-2008, 03:47 PM | #36 |
This will put this issue to rest definitively.
I have a Chevy 350 V8 with carb. I'm running custom headers, Y pipe, Magnaflow cat, and stock S13 catback. The red torque curve is on stock exhaust. The Edelbrock was dialed to the leanest setting and AFR was only 11, which is extremely rich for an NA. The blue torque curve is on open catback. Notice the huge jump on power. AFR was at a healthier 13.2, not perfect but almost ideal. Now I realize that this doesn't apply to KAs, but it shows how restrictive the stock exhaust is. There is too much back pressure and the cylinders can't clear exhaust gas = incomplete combustion = rich. |
07-30-2008, 03:43 PM | #39 |
I also have a 3" exhaust on my KA. Right off the down pipe, cat deleted, through a magnaflow resonator and an a-spec exhaust.
Its fucking crazy deep but also crazy fucking loud when I stomp on it. I went from stock exhaust to this one and could noticibly feel a difference down low. Butt dyno ftw. Tons of people have shown that the KA loves a 3" exhaust. Cops, your mom and old people may not.
1982 280zx Turbo |
08-03-2008, 02:41 PM | #40 |
Theres more to finding the "perfect" exhaust than most people even want to think about. I can get pretty technical with this if somebody really wants me to. I have formulas and in depth explanations of the exhaust pulses, blowdown, Header size, collector size, between unequal length and equal length headers, optimizing valve events, reversion, etc, etc, etc. I can go on. We can figure out the exact size a stock 240 would like but even if we do theres still gonna be the jag offs that say "Oh i got X inch exhaust and i can go sideways or beat a civic on the freeway or i made more power with this size and blah blah blah" I can do that all in my frickin Ford Contour. So i am gonna see if there is somebody who would actually like to find it out let me know and we can get into it. Gonna need some info as far as when the exhaust valve lift reaches .050" and some dyno sheets to give us a good idea of stock max power RPM n shiz.
So if we want to make a nice research project out of this or we can keep arguing between 3 inch cat backs or not where most thought shouldn't even be put if you want to make a true "Tuned" exhaust system. Oh and G6civcx. What are you trying to show that that graph. The graph doesn't make any sense at all. Maybe that was the point? |
08-03-2008, 02:49 PM | #42 | |
edit: just for fun, explain why you need more backpressure
Engrish is funny in Japan. In America, it's for stupid fanboys. |
08-03-2008, 03:26 PM | #43 | |
"I am Norwegian, and are not familiar with your urban words :P" |
08-03-2008, 03:38 PM | #44 |
All I Want to see is some one in these forums to beat my stock block and stock cam dyno of 162WHP and prove to me that a 3" exhaust is better than a 2.5" exhaust. That way I know for sure that I would want to upgrade from my 2.5" to 3". I'V chosen to stay with a 2.5" exhaust because it seems to prove that equal balance between high power and still allows me to pass my smog emissions.
08-03-2008, 04:17 PM | #47 | |
the curves just don't look right. At 5252 RPM torque and HP will always cross. Doesn't look like it will happen with accurate numbers. Plus in the passed 3 weeks i've physically looked at at least 20 dyno pulls on 350 chevy motors a day. Its what we have been doing at school. Those curves don't even closely resemble what we've been seeing. Not necessarily calling you out, its just they don't look right. |
08-03-2008, 04:29 PM | #48 | |
08-03-2008, 04:39 PM | #49 |
Never said it was. I said that it doesn't LOOK like the tq and hp will cross at 5252 with accurate numbers. As in following the curves direction and just estimating the number it would be at at 5252 RPM. Thank you for giving me a red box for no reason. |
08-03-2008, 05:02 PM | #50 |
My mistake . I read the "doesn't look like..." sentence as just a typical internet opinion masquerading as fact.
08-03-2008, 05:26 PM | #51 |
awww teehee the kiss smiley made it better. lol
Those stupid internet opinions are what i try to correct. Being new on here and having my age show i expect some flame when i post things so don't worry about this. But being ASE certified and in school for this shiz i am pretty knowledgeable and i just want to pass on what i know to people cuz remember kids...KNOWLEDGE IS POWER!!!! |
08-03-2008, 06:54 PM | #53 |
98 Kouki Slicktop. Tip Dealer!
I agree. Its not like you were making crazy power before the exhaust anyway.
For KA's I would go with a custom exhaust and a muffler of your choice. I had a custom 2.5 catback made with minimal bends and a tsudo n1 muffler or some bs like that. It looks nice and sounds great.
08-03-2008, 10:03 PM | #54 | |
I hate dynapack, I find it to be a mis calculated dynomometer. But like any dyno at least there is some truth to what is seen in statistical averaging.
My Mustang dyno test report doesn't show the cross over at 5252 (EXACTLY) and I find it to be more accurate. Every engine has a different boreXstroke which will always make the RPM cross over different. 5252RPM is just an AVERAGE that puts all engines into a ballpark figure so to speak.
08-03-2008, 10:58 PM | #55 |
AFC #1
I think the fake cat gives a hollow resonance to the exhaust tone. I replaced with a resonated test pipe and it went away. Also the area that it gets to expand in stalls out the exhaust velocity.
08-06-2008, 12:07 AM | #56 |
when has ur car ever been fast?!! slow ass KA!!
and take that FLCL off ur plate!! u dont deserve those letters!! and dont forget! words going around about ur shitty welds!!! i bet this makes u wanna throw a hammer at sum1 huh? o yea.... lol..... idk who said this!!! but u cant beat geo metros? is this true? for sum reason i believe this?! hahahaha |
08-06-2008, 08:14 AM | #58 | ||
I am going to kill your MX6 at the track today.
08-06-2008, 09:12 AM | #59 | |||
The only thing that matters is the volume of exhaust gasses being moved. Not the straight-line velocity at which they're moving. Think about it this way. If you have 5 seconds to get the air out of your lungs, are you going to do it faster through a coffee stirrer or a jumbo straw? Or without a straw at all? The air will be moving faster through the coffee stirrer - that is, at a higher straight-line velocity - but it'll take you a LOT more time and your cheeks are gonna be burning. It's not rocket science.
My seller review thread |
08-06-2008, 11:33 AM | #60 |
But you have forgotten all about the scavanging affect. Basically you want your exhaust gasses to move fast enought to create a vaccuum condition that is going to pull more gasses. To slow and you dont get that. This is really helpful in lower rpms where there is not as much flow. According to your theory, everyone should be running open downpipe. Have you ever driven a car with an open down pipe and then put an exhaust on there? A similar concept would be siphoning. Not the same thing, but similar principles. Void created needs to be filled, motion of water keeps creating a void that keeps needing to be filled. Motion of water is aided by gravity.
