02-03-2009, 03:41 PM | #31 | |
Still hear motul is one of the best out there though. Made my tranny feel new again. |
02-03-2009, 04:23 PM | #32 |
it has aids... I put it in my old civic and I couldn't even drive it until it warmed up and it just felt like I poured butter in my transmission and not butta!!! it made me cringe to change gears, i went right to the dealership and bent over for 3 quarts and changed it ASAP!
02-03-2009, 04:36 PM | #33 | |
Turn and Burn! |
02-03-2009, 09:28 PM | #34 | |
So what would you guys recommend?
The AMSOIL Syncromesh 5w30 or there Synthetic 75w90 GL-4 Fluid?
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
02-05-2009, 10:49 AM | #40 |
Ive tried RP, Redline, Mobil 1, and some other shit. Mobil shifts like shit... it's horrible. Royal purple was ok. Can't remember any details.. so it wasn't shitty, or great. But I have tried Redline shockproof and MT90. Both were amazing. If you complain about how hard it is to shift, grow a set of balls. It's supposed to protect your tranny. By the time your engine warms up, the trans fluid should be warmed up too.
-Bart |
02-05-2009, 07:23 PM | #42 |
Just an FYI, you're not supposed to use GL-5 in our KA/SR/CA/whatever transmissions
FSMs all call for GL-4 Most people already know that, because they say they're running MT-90. Which is GL-4. Mobil/Valvoline/Pennzoil that you get on the shelf is all GL-5, which is a different mix of additives than what we need, and (apparently) cause issues with the synchros. So don't use it. People have wasted a lot of time on the Internet arguing about whether it's safe to use GL-5 in our transmissions, so not really going to beat a dead horse. Just play it safe and stick w/ GL-4. Reason I say all this is because I had a transmission leak and decided to fix it, so I had to drain out my old MT-90 and search all over town for a GL-4 fluid. Eventually found some at NAPA, plain old non-synthetic stuff, made by Sta Lube. It's 85W-90 which is a little thick but shouldn't be an issue in TX. Redline MT-90 is ideal for our transmissions, I just couldn't find any locally and I gotta have a car to get to class tomorrow. Sucks living in BFE sometimes... |
02-05-2009, 10:19 PM | #44 | ||
02-06-2009, 08:37 AM | #45 | |
02-06-2009, 08:58 AM | #46 | |
The GL-5 has additivites that are not good for yellow metals (eg; brass which our synchros are made of) |
02-06-2009, 09:57 AM | #47 |
AMSOIL - Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 (MTG) <---You guys can run this stuff,
http://www.amsoil.com/storefront/svg.aspx <--- but I run this stuff. So if you really wanna bitch at labels, then go do research and not speculate. It supports GL-4 and Gl-5 But like I said, if you want run the MT and Transaxle Gear Lube....
Turn and Burn! |
02-06-2009, 10:34 AM | #48 | |
intresting read: Gear Oil Selection Oils are made from base stocks, refined and then mixed with additives to improve their performance. GL-5's incompatibility is due to the extreme pressure (EP) wear additives. To give the gear oil its EP rating, it's easiest to add a sulpher based additive like MoS2 (molybdenum disulphide) but the sulphur present in the oil (you can smell it) is responsible for eating the copper alloy used to make the synchros. GL-4 differs from GL-5 by the amount these chemicals are mixed into the oil (1/2 to much less in GL-4). Since the same additives are present in GL-4, they will eat the synchros as well but at a point in time that is beyond the expected service life of the gear stack. To get the GL-4 rating, the oil has to pass the ASTM D-130 test. This test determines how reactive the sulpher is against a polished copper strip. The strip is also subjected to heating to simulate the running conditions in the gear box. To obtain GL-5 certification, the manufacturer does not have to pass the ASTM D-130 test. This is the main reason why you should avoid GL-5. So, if you put in a call to a manufacturer about their GL-5, that test result is what you want to verify.Some people will claim that using GL-5 in a GL-4 spec transmission doesn't apply when the GL-5 is synthetic. This depends on the oil and cannot be generalized. However, it should be noted that many GL-5 synthetic gear oils do not use sulpher in their EP additive package and can pass ASTM D-130.Even if the ven if the manuacturer states the gear lube is "non-corrosive", its viscosity index may be too slippery for the VW style synchros. This means that while the syncros won't corrode, the oil is not designed to grab the hub the way GL-4 does and the transmission will wear out another way.As a final caution, some GL-5 formulas have been known to permanently coat the synchros in a VW manual transmission reducing its life by 50%. GL-5 MT-1: In recent years a new gear lube rating has appeared: API GL-5/MT-1. MT-1 all by itself is just as non-suitable as GL-5 can be but in combination some manufacturers when asked are now stating that formula is ok to use in place of GL-4. It is hard to verify if these gear oils are suitable for the transmission. Certainly, they have not done as much research as VW has done but at the same time VW is no longer testing new transmission oils with their obsolete models. What is clear is that the oil has to pass ASTM D-130 to get the MT-1 rating. This will determine if their EP additive package is non-reactive with copper. However, until you try shifting the gears you won't be able to confirm if it's got the proper viscosity. For that reason, sticking with GL-4 is simply the best course of action for long transmission life unless you can verify mileage and shifting performance with another owner.
02-06-2009, 12:23 PM | #49 |
Awesome thanks for the post.... I will probably switch to GL-4 later.... Probably by end of 3 months..... Blah.... Amsoil makes great GL-5 oil... I will test the GL-4 in a couple of months no biggy, unless someone wants to test it for me and let me know. I am sure its really good either or..
Turn and Burn! |
02-06-2009, 02:35 PM | #51 |
That's the bottle I have 3 of. Same thing that went into my buddy's S2000. He said that shit is the bomb, and in the S2000 community they pretty much said it's the best for their tranny. [shrug] I'm gonna switch out my like, 2 or 3 year old Redline MT-90 or MTF (whichever one was slightly thicker) that's in my tranny now for the Amsoil stuff probably next time I'm under the car. |
02-06-2009, 08:59 PM | #54 | |
You can get it from the website or one of their dealers that is local to you. |
02-07-2009, 09:56 AM | #56 | |
Don't forget the calcium twins!
02-08-2009, 06:42 PM | #58 |
Here's my mix for my KA-T.
1qt Royal Purple 75-90 1qt Royal Purple 10-30 1/2qt Lucas Transmission Fix Call me crazy but before this I used to replace the tranny every 6-8 months. My current one has lasted almost a year and isn't showing any signs of giving up.
2010 R35 GTR 600whp @21 PSI (E85) 1998 RB26DETT 240SX 810whp@28lbs |
02-08-2009, 06:46 PM | #59 |
I'm definitely a fan of the Amsoil stuff, I'm running the 75w-90 gl4 in my transmission, and 20w-50 high zinc Amsoil in the engine, and everything is running great.
