11-05-2013, 07:24 AM | #5941 | |
Depending on exactly what you're shooting for, it seems like the rear roll center is best corrected in the same way as the front, with that being a drop/modified knuckle. It's a lot easier to hold the desired geometric constraints at the knuckle because it's a single self contained unit and then use the various links as simple pivoting arms with adjustment for alignment. Although, with all of the above being said, if you were to use GK Tech's Knuckles with their LCA, you could play with shank lengths all you want (within reason) and then use their adjustable toe arm mount/pivot to dial in the desired toe curve in the rear. From there, it seems that the only concern would be with your dynamic camber gains, which may be corrected in the knuckle already. |
11-05-2013, 05:54 PM | #5942 |
^ fook ya bro! Wtb moar angle, roll center correction, and 335's up front!
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
11-05-2013, 09:01 PM | #5943 |
I had to cut my wheel wells out today. Even after I raised it 15mm it still rubbed at full lock at the top of the left wheel well.
11-07-2013, 10:56 AM | #5945 |
Poorman, please make your front end max tire compatible when you finalize it - so I'll know what to do in the future.
11-07-2013, 11:05 AM | #5946 |
The coolest part is the cluter-less engine bay. Hope the finished product will stay 'tucked' in similar fashion.
How close to stock rear geometry do you gentlemen think one could get with shorter RLCA and drop knuckles (most likely GKTech RLCA and MAX knuckles) on an excessively lowered car? My end goal is to figure out a setup where I can switch back to factory non-adjustable links while retaining reasonable camber and toe. |
11-07-2013, 01:39 PM | #5948 | |
11-07-2013, 02:29 PM | #5949 |
Does droop effect spring rate? I'm on 9k/8k and it feels softer than my grand am.
Edit: I asked in small questions, and google is giving me formulas. I'm not a genius, really looking for a yes or no answer. |
11-07-2013, 02:48 PM | #5950 | ||||
As far as your question goes, you're going to need more knuckle drop if you want to use stock arms. Driftworks would probably work. Quote:
Nope, but it does change how the damping and spring react to each other if there is no preload on the spring. If your car rides nice with stiff springs, it basically means you have properly valved coils.
11-07-2013, 03:41 PM | #5951 |
The Brill Steel Motorsports S14.5 rocks this tubular rear subframe, I thought it was interesting because you don't see a lot of these due to rules. Looks like driftworks knuckles out back, and TDP stuff up front.
11-07-2013, 05:25 PM | #5952 | |
Now imagine the spring rate as a line on a graph, with the slope corresponding to the spring rate. Pre-load and/or droop will effect where you start on that line, but not the rate at which the line changes (assuming linear spring). So basically, when you preload the spring, you're applying more force to it, causing it to compress more. This means that it won't move until that force is overcome. So basically, preload does not effect spring rate, as a spring rate is a set constant according to the spring. (Technically, a progressive spring rate is also 'constant' although it varies, but the variation will happen at a specific rate in a repeatable fashion) Now to answer your question, removing preload from the spring will make it feel softer (easier to compress), but spring rate hasn't changed. Basically what you're noticing is that spring is more likely to compress at lower force since less is applied via preload. Just playing with numbers, but if you compressed an 8kg/mm spring about 10mm via the adjusting collars, it'd be preloaded with about 180ish lbs of force, give or take. You'd have to over come that 180lbs of preload to get the spring to even move at all. Remove 50% of the compression (5mm) and now the spring only requires half as much force (90lbs) to move as before. As Poorman said in the post above, damping as a big effect on how a spring feels too, so your issue could have something to do with how the entire system is working together. |
11-07-2013, 06:16 PM | #5953 | |
I'm surprised there isn't an off the shelf "kit" that has a tubular front subframe for s-chassis.
11-07-2013, 07:04 PM | #5954 | |
Looks sexy though and TDP knuckles look sexy, I will definitely have to save for those instead of wisefab replicas.
S14 KA NA two cylinders, 75whp limper |
11-07-2013, 08:34 PM | #5955 |
I did an internal thread search but didnt turn up what im looking for...
Im about to have my LCA's extended... I was thinking 2 inches, but someone told me that is too much, what is the "optimal" amount of extension for S14 LCA's on a s14? I dont want -24858 degrees of camber... somewhere between 4-6 degrees, which i would assume would be achievable with 2 inch extension still? If it helps my setup will be: tien tierods Abercrombie Motorsports outer tierods 2 inch (or less?) extended LCA's with new bumpstops welded on most likely Modified knuckles with ackerman correct new balljoints |
11-07-2013, 08:47 PM | #5956 |
I have -5 degrees of camber with my stock arms and Ksport coilovers. Rest was stock.
Normally everyone goes by mm instead of inches. 1.5 inches would probably be enough for what you are asking to do.
11-07-2013, 08:56 PM | #5957 |
Yeah I mean I can get plenty of camber on my stock arms as well haha, what I meant by that is with a 2 inch extension, would I be able pull enough camber out of the front end (coilover notches and camber plates) to reach 4-6 deg camber, if that makes any sense at all?
11-07-2013, 10:27 PM | #5958 | |||
Haven't had these issues with my PBM rear knuckles... Quote:
11-07-2013, 11:03 PM | #5959 |
20mm gives roughly 2.5* more camber.
11-08-2013, 01:27 AM | #5960 | ||
Unfortunately turbular subframes are illegal in basically every racing series besides unlimited time attack and drag racing. Brill's version looks like it's mostly for weight reasons, as the factory geometry looks mostly intact.
11-08-2013, 07:13 AM | #5961 |
Also probably because it was smarter/more beneficial to remake the whole sub frame instead of only modifying the stock one to mount that dif to.
DLG - DIRTYLOVE |
11-13-2013, 02:56 PM | #5962 |
Anyone have input on what spring rates I should run? I'm kind of stuck on deciding.
I'm know with the roll center correction in the front I won't have to run anything too crazy, but I also don't have a swaybar at the moment. I do plan on grabbing a Cor Integration one eventually, as I'd like to use one on a few road course days, and possibly drifting. The car is 50% drifting, 40% street, and 10% road course use, and is pretty dang low. I'm thinking something like 9/8? I want the car to be balanced well on the street. I know it'll change once I get a rear suspension setup that has roll center and camber curve correction, but that'll be a little bit too.
11-13-2013, 03:01 PM | #5964 |
11-13-2013, 03:26 PM | #5965 |
I wanted to move to a 9/7 setup from my 8/6 but When I did my roll center correction, the car was transformed and haven't really put any other thought into it. In all honesty the car performs so nicely I haven't seen any limits I haven't really had any reason to adjust my dampening or anything else. So I'm happy with my 8/6... But I want swift springs now.
Sent from my iPhone using Tapatalk |
11-13-2013, 03:29 PM | #5966 | |
I've driven several S-chassis with different rates, but I only have a lot of time in my old personal cars with 12/10 and 10/8, neither of which had any roll center correction and had front bars. No body roll was great, but the 12/10 Megan tracks were just far too stiff for the chassis, and the Tein Super Drifts just rode terrible. I had Fortune Auto Version 1's with 9/8 springs but I drove the car once before I sold it . That's why I ask, I don't have much experience with the new, much better valved coilovers that are available now.
11-13-2013, 03:43 PM | #5967 |
Yeah I do have a factory sways. I also don't have the huge desire to upgrade them anymore since RC correction.
I really love my Fortune Autos.. granted the low speed dampening is ishy, they really shine where they where designed to at high speed dampening. Is that the digressive valving? I know they aren't high quality coil overs but I think they are the best of its price range. (Anything below 1500 dollars) Sent from my iPhone using Tapatalk |
11-13-2013, 04:26 PM | #5968 |
start with 8/6. you already have roll center correction up front so it's going to help keep the car from rolling as much. i'd get some swifts and call it a day. if you want anything crazier you could go to like a 5k in the rear for more grip but anything softer than that will suck.
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all |
11-13-2013, 06:19 PM | #5969 | ||
You hit the nail on the head. I forget sometimes about regulations, etc. Anybody got any input for me on the gktech knuckles? They have opened the preorders and I can't decide what options to get: s13 or s14 spindle, which brake caliper mounts, which steering arms, which balljoint inserts etc. http://www.gktech.com/index.php/s-ch...nuckles-1.html I have an s13 (5lug) currently, but my coilovers can accommodate s14 mounting holes also.
11-13-2013, 07:59 PM | #5970 | |
You'll just need arches bigger than these:
