#5911 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
I figured this would be well placed here...
What is the best way to achieve a LITTLE bit more angle, without having to get knuckles? I have an S14, and I plan on getting the LCAs extended 25mm hopefully in order to give me a ridiculous amount of camber, but will that also improve my angle at all? Can I get the bump stop removed if I plan on retaining OEM knuckles? I also plan on getting tie rods that are a little extended, and possibly the Godspeed rack extension. (Because the guy that originally designed them no longer makes them). Also, I want to get the PBM rack relocating solid rack bushings... Will all of that increase my angle at least a little bit? I'm not looking for anything crazy, nor do I want to spend a bunch of money on it, however, I do want to do it right, and not get shitty parts.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#5913 | |
![]() Join Date: Nov 2005
I'd get rack spacers and call it a day. You'll probably want more, and if so, you can look into knuckles next.
#5914 |
^Problem is finding longer inner tie rods with rack threads long enough to handle those spacers. PBM is out of theirs at the moment.
I noticed certain retailer brands have a longer thread length going into the rack... so using something like longer i30 inners from Napa/OReilly/Autozone won't be an issue with those spacers. Will look into this in the next week or so when I install the PBM front knuckles I just received. Edit: found out PBM has a few of their inner tie rods in stock... they just haven't updated their site yet so will just get those. Last edited by az_240; 10-31-2013 at 05:46 PM.. |
#5915 |
I would be interested in a set also.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
#5916 |
![]() Join Date: Oct 2010
SO...pbm knuckles & lca, rack moved forward 25mm and sikky sway bar. so much lock lol
I'm rubbing the wheel wells at full lock and seriously thinking about cutting it. Does anybody know if the wheel wells have ANY structural integrity? without a tubed front end, is it safe to just cut them out? Also somebody had mentioned on here that with the steering rack moved forward, accompanied with modded knuckles, it will actually lower your ackerman? So if the PBM knuckles are spec'd at around 8 degrees of ackerman; does anybody know the approximate ackerman with the rack moved 25mm? |
#5917 |
Wheel wells are structural in a stock unibody car, but with a tube front end it won't matter. I'm in the same boat btw.
#5918 |
I'm going to go half tube front also.
Decide on how much lock, etc you're going to have and then use the biggest wheels and tires you'll ever have up front, then tub or tube it based on that.
#5920 |
What is the stock travel distance of the steering rack?
I know it has been posted plenty of times before, but for some reason I am having quite the difficult time finding the information. On another note, I am excited for these GKTech rear control arms and the shim-adjustment, especially since I am obsessive about making sure both sides are adjusted the same and thus hate adjustable parts. ![]() |
#5921 |
Super strut vs macpherson strut vs double wishbone:
http://www.caranddriver.com/features...ined-tech-dept Nissan Road Racing Forums - View Single Post - Bumpsteering An S13 @ Multiple Steering Angles
#5923 |
Woah, cool. But what's the price? The whole purpose of me avoiding knuckles is to save some money lol
#5924 | |
The nice thing is that you will not need to have your LCA's extended, since they already push the knuckle out 20mm. |
#5925 | |
That's a pretty good price though, I'll have to look into those a bit.
#5926 | |
![]() Join Date: Sep 2009
![]() Feedback Score: 23 reviews
Thought they were closer to 300 shipped with a prebuy..... |
#5927 | |
Here is the post from page 179: Quote:
300$ would be almost a knuckles price, which would defeat the purpose. Though to be honest, I would still prefer these over knuckles since they incorporate the added track width, and I am not trying to do anything crazy with my car. I am guessing that is the same reason why GKTech seemed a bit reluctant to work on them, as many potential knuckle buyers will probably end up choosing the adapters instead. |
#5929 | |
I am going to go with their knuckles as they actually are drop knuckles. |
#5930 |
There are so many cool/random parts to collect from GKTech. Cannot decide whether to keep procuring them one by one or risk waiting to order everything together.
Just bought their camber/castor tops. ![]() If only those were 162$ as well. ![]() I really only want them to run them at the shortest setting. Is it true that S13 RLCA are about 10-15mm shorter than S14 ones? If so, having an S14 subframe would be nice, then I would just try using the S13 RLCA. Are there any compatible OEM RLCA even shorter than the S13 ones? I have tried looking up every plausible RWD Nissan/Infiniti, though it does not appear so. |
#5931 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Pretty sure the s13 and s14 rlcas are the same length, the difference in width comes from the subframe itself (thus the required use of offset bushings).
#5932 | |
EDIT: Note on rear lower control arms. If you start extending them with GKtech or any aftermarket arm you have to be careful with your axles overextending. This is specially true if you also are running dual caliper add-on brackets that also space out the rear hubs.
S12 || KN13 || S13 || B16 |
#5933 | |
Where can I pre-buy those knuckle extension/drop thingies? I can't seem to find them on GKtech's website. I love how they have a bunch of cool little parts like this and that they are still developing and producing many of them. As for the castor top hats, can I run those in conjunction with my Stance camber top hats? I know Stance actually offers the castor top hats, they just don't seem to market them very much. I'd love to be able to control my caster from there as well, but I also want to be able to adjust my camber via the top hats.
#5934 |
TDP kit is on sale this month.
#5935 | |
Check their FB page for up to date release info or join the mailing list on their website, those knuckle extension and spacers should be available soon, within a few weeks last time I asked them!
#5936 | |
With our knuckle & LCA & 35mm forward inner tie rod offsetter and a decent amount of caster we measured 3* of ackerman at lock
#5937 |
![]() Join Date: Sep 2010
Alright this maybe very simple problem but to be honest is it's driving me crazy. I have a 13 hatch. On coilovers, all suspension arm are adjustable, except for the lowere control arms front and back. Cars pretty low but not ungodly scrape in everything low. Now I when it replaced all the suspension arms I "eyeballed it and it turned out pretty decent. No weird characteristics anything like that just a little bit of a left pull. No big deal. I've been ridin around everyday like this for a couple years. So this past weekend I went to get tires put on and I figure why not throw it on the alignment rack and have em dual it in. Now the car has an extreme right pull. As far as the printout I have everything looks copacetic but it's not. My wheel bearings are good, we tried switching the tires around to see if they were worn funny nothing changed. And now my power steering pump sounds like it has air in it and it's harder to turn than it was. I'm wondering if anyone else has had this problem or if they could point me in the right direction. Does the rack develop a dead spot where over the years where center would be? I don't know what to do he put it back on the rack like 5 times and could not get it straightened out. I also replaced the inner and outer tierods pretty soon after the suspension as well... Any help would b greatly appreciated, sorry for the novel lol
#5938 | ||
We are also compiling a comprehensive list of axle lengths over on NRR. Quote:
You can see why LH Q45 with LH Z32 TT axles are the choice for 6x1 stub flange diffs in a s-chassis.
#5940 | |
The GKTech RLCA come with two different shank lengths for the ball joints, so I have been curious about it. I suppose I know how they would change the geometry, so my question should actually rather be, would they be beneficial/not beneficial for drifting and how/why? I know what they are good/bad for in the front, but I am unsure about the rear. |
