04-29-2011, 12:12 PM | #5821 |
your question actually wasnt as bad as some of the others but can still be easily answered with a google search.
What do you need an o2 adapter for?
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
04-29-2011, 05:03 PM | #5822 |
I was wondering if anybody knew of a company that made front bumpers for an S13 that is made out of polyurethane bc I live in NY and you can't avoid EVERY pothole.
Thanks |
04-29-2011, 05:06 PM | #5823 |
I believe chaser, shine, and extreme dimensions all have urethane versions of certain bumpers.
05-01-2011, 12:56 AM | #5824 |
crankcase vent ??? im lost
well im gona add a catchcan to my redtop sr and i was wondering where does the back of the T connect too i have read that it goes to the crankcase vent but where is that at im lost? i have seen pictures of catch can setups that jst plug the backside of the T fitting, but i also hear thats bad.. any help would be awsome thx guys or girls
05-01-2011, 05:42 AM | #5825 |
Sup guys, real quick question.
So I just installed my new coil overs yesterday. Ran fine. Decided to lower it quite a bit today. Drove around I would hear some grinding noise sometimes. I knew what it was and checked and yup! My wheel was slightly hitting my springs. Now I'm wondering, this is only happening on the driver side. After trying to camber it out, it happened less frequently but still happened. So my question is, is this mainly because since new suspension/lower, my alignment is all messed up, thus my toe is probably all fucked? Making it so that my driver side touches the coils and the passenger side doesn't? I'm aware some spacers would help that out. I have 10mm in the front now, 15mm in the back and may swap em around real quick but I figured my toe may be messed up and causing this. If so I am going to raise it and drive to the alignment shop and lower it there. Or figure something out. Thanks |
05-01-2011, 09:34 AM | #5827 |
Yes I understand that but my question is do you guys think it's my toe that's fucked up? I'm going to try to adjust it myself today so I can make it to the alignment shop but that's what I was asking before Hand
05-01-2011, 12:53 PM | #5829 |
I did it at the top hat yesterday, was looking into other ways to do it since when doing it by top hat it wasn't going to change much in my mind but would definitely help if done by the knuckle. I'll go look that up in a bit unless someone doesn't mind telling me how since I never have before.
05-01-2011, 12:59 PM | #5830 |
finally got my 18s orderd and need help trying to figure out what size tire to run on them
i wanna run some what of a stretch and go 30mm widebody in the rear. im going to be running s13.4 so the front will have wider fenders then stock the wheel size are 18x8.5+35 and 18x9.5+36 also wondering what is a good brand of tire to stretch thanks |
05-01-2011, 01:36 PM | #5832 | |
I'd say get some Powered by Max coilovers. They're a site sponsor, so you can find a link on the home page. They're good, affordable coilovers with a sweet warranty. 8/6 kg spring rates are going to be best for a daily driver. |
05-01-2011, 04:38 PM | #5833 |
Any tips/tricks you guys have on removing the driveshaft bolt that connects to the diff? I've PB blasted the shit out of it and it won't budge. It also still moves a bit when I try to turn the bolt, I've put the tranny in fifth gear and still I can't get the bolt to move and the little movement it does have it's just the shaft moving. Everything else is fine, I just can't get the four specific bolts to move at all.
05-01-2011, 05:30 PM | #5834 |
hey guys, can you talk to me about weight distribution of an rb25 into an s13, i know it has been covered a lot but im still a bit skeptical. how does it affect it for drifting and such..
thanks |
05-01-2011, 05:32 PM | #5835 |
So last night I noticed the smell of coolant when I pulled in the garage popped the hood and noticed my upper radiator hose had a hole through it.
Take that hose off the upper coolant neck and notice that not only is there a hole in the hose but one in the coolant neck as well. WTF could have caused this. There appears to be another one forming as well on the coolant neck. For reference Imagine there was a hole left of the clamp through the rubber and end of the coolant neck. About big enough for a 2 toothpicks to go through.
05-01-2011, 07:00 PM | #5836 |
help with stock project
Does anybody know where to get replacement wire harness plug connectors?
I have an 89 240sx with most of the harness connectors either broken or brittle. One in particular would be the Temperature sensor that reports back to the ECU. Any link or help would be appreciated. |
05-01-2011, 07:55 PM | #5837 | ||
Genuine OEM Nissan Thermostat Housing 240SX 91-98 KA24DE Quote:
Falkens, yokos, Dunlop, etc all stretch pretty nice. Cruise the fitment/stretch threads, and check out rimtuck/tyrestretch |
05-01-2011, 10:14 PM | #5840 | |
AFC #1
loosen both bolts then pull out on the knuckle and hold tension outwards while tightening the bottom bolt. Then tighten the top bolt. This will pull the wheel away from the strut body.
05-01-2011, 10:16 PM | #5841 | ||
most passenger car tires can be streched....but summer tire with a stiff sidewall is best IMO, regardless of brand Quote:
just one of many credible reviews...search on timeattackforums.com aswell Tire Test: Nine Affordable Summer Tires Take On the Michelin PS2 - Comparison Tests - Auto Reviews - Car and Driver although they didnt test the hankook ventus RS3 which is in the same category as Z1's in terms of price and performance |
05-01-2011, 10:38 PM | #5842 |
upper intake manifold... if the only way to remove this by dropping the bottom or removing the head?
Also, oil on spark plugs - what can be the problem? I can't figure it out, replaced gaskets already but it seems like its still in plug well 2/3 I'm fine with doing the latter, but just wanna check gotta replace a head gasket.
street dancer. GLEAM |
05-02-2011, 01:28 AM | #5843 |
^ on what engine? I can remove my intake mani without removing the head. Takes a little work but doable.
Which gaskets did you replace? How about from the valve cover? I just helped my buddy do his supra, his spark plugs were swimming in oil. He was leaking from the valve cover. |
05-02-2011, 02:05 AM | #5844 |
I have a fmic that does NOT have a nipple for the wastegate, before the intercooler like most i have seen. Should i plug the wastegate up to the nipple that is on the coldpipe (the only nipple on the entire fmic kit), OR plug it up to the intake manifold?
05-02-2011, 09:47 AM | #5845 |
So i took off my 10mm spacer now that i have better fitting rims, I bought some lug nuts from autozone (yea those cheap wannabe tuner lug nuts) my question is because they are extended lug studs what kind of lug nuts do i need to buy? I would like one with locks.
05-02-2011, 09:56 AM | #5846 |
Are all coilovers rebuildable? I'm thinking about picking up a used set off E-bay.. they aren't blown yet, but they are pretty old. If so, where do you take them?
05-02-2011, 10:21 AM | #5847 |
Anyone know Auto Parts Stores/Chains that carry this damn Thermostat housing for a KA24DE.
So far autozone and advanced are both telling me that they dont carry it along with napa.
05-02-2011, 10:33 AM | #5848 | |
