08-25-2013, 02:08 AM | #5731 |
08-25-2013, 02:08 AM | #5732 |
i use PBM s14 style tie rods... work great for me....
08-25-2013, 08:52 AM | #5734 | |
WTB: 1(one) battle version toe rod
-Mike |
08-25-2013, 11:29 AM | #5735 | |
Though to really take advantage of this, a shorter lower mount would also be convenient, in which case the Z32/R32 front mount could be used. Or the generic S13 rear lower mount design could be rethought. And I am curious if the aftermarket rear knuckles do anything with the the shock mount position as well. |
08-25-2013, 09:46 PM | #5737 | |
08-26-2013, 02:12 AM | #5738 | |
08-26-2013, 07:10 AM | #5739 |
guys one more question,
If I dont want to make the wise fab kit to go all the way to 65 degrees, how would that be possible,, meaning i want the max lock to be at 50-55, which is more than enough I believe. |
08-26-2013, 09:15 AM | #5741 | |
When I installed PBM's drop knuckles on my S13, I had to lengthen my coils about an inch or so to keep the same ride height. AFAIK, most/all S14 rear Coils are longer than S13 coils. There's a certain point where the overall lengths will cross over, with the lowest S14 setting being usable on an S13, but it's not optimized by any means. |
08-26-2013, 09:28 AM | #5742 | ||
Although s14 rear lower mounts are the same height as z32/r32 front mounts, same bushing size too.
-Mike |
08-26-2013, 11:24 AM | #5745 | |
S14 coils are longer, meaning that at a certain point, they'd be your limiting factor as far as ride height is concerned. With that being said, there should be/is some over lap between S13 and S14 coils as far as adjustment is concerned, so if you were in that over lap distance, then you could, in theory, run either without negatively effecting ride height - but there's a Bonus. Figure if an S13 strut has X" of travel, and an S14 strut has X" + 2" of travel, then you would gain the difference in travel by switching to S14 struts, and be as low as you were previously. (Though, with that being said, some S13/S14 rear coils use the same strut depending on the manufacturer, and the only difference is the lower mount like Fortune auto's stuff.) I think that all makes sense, but then again, I'm half stupid most of the time. |
08-26-2013, 11:53 AM | #5746 | |
And i have FAs on my s14, the rear struts ARE longer than s13 rears, just like almost every other coilover I have seen.
-Mike |
08-26-2013, 12:32 PM | #5747 |
Ok just installed custom knucles and tierods and for some reason now i got alot of woble in the steering wheel is that normal? I do feel the differance when turning radius wise but going strait it has a very distinct woble all i have is custom knucles tein inners and outters ,stock flca stock rack is it my steering rack going out??? And everything is tied double checked
08-26-2013, 03:16 PM | #5748 | |
This is rad, what knuckles, PSM? I'd like to use this in the first post. Speaking of which, the pictures are back up, I need to add some more things still though.
08-26-2013, 06:50 PM | #5749 |
Can we start compiling front wheel widths and offsets that work with modified knuckles and a factory design tension rod and control arm setup? Excluding bent / relocated inward tension rods and 1 piece LCA's.
My 17x9 +20 do not clear the tension rod. Recently posted, 17x9 -32 does, and earlier in the thread, 17x7.5 +8. I am looking to change to 17x8 but not sure of what offset will be ideal. |
08-27-2013, 03:00 AM | #5751 | |
ah well. Waiting for some FA500 with swifts so that wont be a problem soon. |
08-27-2013, 08:14 AM | #5752 |
yeah PSM knuckles, ikeya inners with 7mm spacers, PSM eccentric rack spacers, stock s14 outters, modified godspeed lca, relocated tension rod location on lca, and modified furtune auto tension rod. you can you ahead and use the pic if you want.
08-27-2013, 07:05 PM | #5753 | |
So is there any real down side to running drop knuckles? How much preload do you guys typically run on your springs? |
08-27-2013, 07:39 PM | #5754 |
as a general rule of thumb, no; there are way too many advantages to bother considering whatever negligible decrements might be involved.
level LCAs. level tie rods. decreased ackermann. lots of low. lots of angle. lots of $wag.
08-28-2013, 08:59 AM | #5755 | |
im dont have any preload Last edited by JohanM; 08-28-2013 at 09:38 AM.. |
08-28-2013, 09:04 AM | #5756 |
Hold up guys, PSM knuckles aren't drop knuckles, they are roll center correction knuckles. That's going to get confusing for some people if they don't know the difference.
Drop knuckles lower the car. Roll center correction knuckles do not. Some kits are a combo of both.
08-28-2013, 09:39 AM | #5757 | |
08-28-2013, 09:42 AM | #5758 | |
Ah number 5 of the first post makes that a bit confusing then. I had thought they were the same thing. So what would be the advantage of one over the other? |
08-28-2013, 10:57 AM | #5759 | |
Obviously for the rear, there aren't really any kits that aren't drop knuckles, as you can't move the rear roll center around too much without moving all the arms together.
08-28-2013, 02:39 PM | #5760 |
So if I were to get the PBM knuckles, my ride height would be unaffected, but my roll center would be changed by 45mm.
Where if I got the DW ones, my ride would drop about 1 3/4 inches AND change my roll center by 45mm. |
