Old 03-05-2018, 05:08 PM   #541
Psychomoongoose
Psychomoongoose's Avatar
Psychomoongoose is an unknown quantity at this point
Anyone consider using some sort of engine-riser mounts to lift the unit up a bit? On one hand Im against chaging the ride height of my car, and also dont want to change the center of gravity by raising the engine. On the other hand, I do like the benefits of the Z33 unit and the incresead oil pan ground clearance. Would I be able to beat the trans tunnel into submission with sledge or would I have to cut and weld the tunnel to fit the riser mounts+CD009?
As long as you're not a ham-fisted retard there shouldn't be a problem.
Psychomoongoose is offline   Reply With Quote
Old 03-05-2018, 07:22 PM   #542
TheRealSy90
TheRealSy90's Avatar
The everything cd009 swap thread.
The area that hangs the lowest isn’t nearest the engine. It needs to be raised at the gearbox mount as well. Problem is you’re already nearly touching the top of the Xmsn tunnel. So that will have to be cut and raised higher and re welded. Then all the exhaust and charge piping needs to be re done too.
Such a good signature.
Old 03-06-2018, 12:31 PM   #543
S-Verteen
S-Verteen is an unknown quantity at this point
Moving things up changes the driveshaft geo and if you are using a bigger aluminum driveshaft may hit the shifter like mine did.
S-Verteen is offline   Reply With Quote
Old 03-06-2018, 01:38 PM   #544
loucal
loucal has a little shameless behavior in the past
On top of this, idk about you guys but I've got maybe a half an inch between the top of the trans and the tunnel so its not like it would make too much of a difference.
loucal is offline   Reply With Quote
Old 03-06-2018, 01:46 PM   #545
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Yea, I got something like that. If I really wanted to correct it, you'd have to cut out the trans tunnel, rasie the engine AND trans, I know we have some +- to the angle of the driveshaft, but to make it worth it, it would have to come up as a whole pretty damn high.
di-devol is offline   Reply With Quote
Old 03-06-2018, 01:51 PM   #546
TheRealSy90
As long as the angle of the input u-joint and the output u-joint are the same then it's fine. Which is why the engine should ideally be raised equally both at the engine mounts and the trans mount, so that it stays "level" and the angles stay uniform.
Old 03-06-2018, 02:15 PM   #547
beems240sx
beems240sx's Avatar
beems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant future
Hey Guys,
Small update:
Reverse lights: Working with factory wiring wired up to the CD009 reverse switch
Speedo: Working and accurate! Here is the setup:
Intellitronix GPS unit wired into the Dakota Digital SGI-5C
Dakota Digital Wiring:
Power: Any power source
Ground: Any ground
Sensor Ground: VSS ground
Input: Intellitronix white wire
Out 1: VSS signal
Dakota Digital Switches
#1: OFF
#2: ON
#3: ON
#4: OFF
Intellitronix Switches
#1: Down
#2: Up
The stock speedo does have a small lag but it is pinpoint accurate and i've verified it with the Speedbox app on my iPhone.
Lou
I really appreciate this info as I was searching for a decent option. Is this the GPS unit you are using?
https://www.summitracing.com/parts/i...hoCrH4QAvD_BwE
beems240sx is offline   Reply With Quote
Old 03-06-2018, 06:22 PM   #548
loucal
No problem! That is the unit i am using but its much cheaper at JEGGS
http://www.jegs.com/i/Intellitronix/556/S9020/10002/-1
Old 03-13-2018, 02:39 PM   #549
di-devol
For people wondering, here's a shot of the cd009 mated to a 1j with collins kit, in a s13
It's a little big.
Old 03-13-2018, 05:10 PM   #550
TheRealSy90
Skid plate time!
Old 03-13-2018, 06:14 PM   #551
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
Does that trans hang below frame rails or is it the angle of the picture?
jumpman2334 is offline   Reply With Quote
Old 03-13-2018, 11:10 PM   #552
di-devol
About 2" below the rails, yea.
Sketch.
Old 03-14-2018, 12:08 AM   #553
No 240.. No id
No 240.. No id's Avatar
No 240.. No id is on a distinguished road
Quick question...
I’m trying to do a cd009 on a RB26, do I use a RB clutch and flywheel setup or z33? Trying to run a twin clutch setup.
You can sleep in your car, but you can't drive your house.
No 240.. No id is offline   Reply With Quote
Old 03-14-2018, 11:38 AM   #554
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Got the gen 4 CBF Performance shifter in the other day. Seems solid
corkscrew is offline   Reply With Quote
Old 03-14-2018, 12:57 PM   #555
t66-240
t66-240 is an unknown quantity at this point
I have a similar setup( collins bolt on with a 2J). That angle makes it look worse than it is. I'm more worried about the oil pan so I'm getting this....
https://xcessivemanufacturing.com/ni...n-s13-fsp.html
It's a little big.
t66-240 is offline   Reply With Quote
Old 03-14-2018, 01:32 PM   #556
di-devol
The trans hangs about 2" lower than the frame rails, I'll take a pic that shows it tonight.
It's funny that my oil pan is above the front cross memeber on mine.
Old 03-14-2018, 01:57 PM   #557
TheRealSy90
I wonder how much material can be shaved off that lowest point of the trans by the tail housing before getting into an oil galley.
Old 03-14-2018, 10:54 PM   #558
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
I literally came here to ask if anyone else has had the driveshaft hit the shifter. Guess there's my answer... I have an aluminum shaftmasters driveshaft and GKTech shifter. So what's the fix? Change the mounting geometry? Mine just barely rubs, I might grind down the shifter link a little.
I'm using the GKTech crossmember btw and it didn't fit very well. Could be because my SR sits lower than stock? Is there a better option for a crossmember that will position the trans better so the shaft doesn't hit the shifter?
My S13 SR Street Mod Build
LuckyX2 is offline   Reply With Quote
Old 03-15-2018, 08:28 AM   #559
TheRealSy90
Honestly I think it has to do with whatever yoke is used when they build the driveshaft. I had the GkTech shifter with the aluminum 1 piece shaft that Mazworx supplies with their CD009/SR bellhousing kit, and the driveshaft yoke did not hit the shifter anywhere. I think there's two different size driveshaft yokes that these shops can use and one has a slightly larger diameter or something.
Old 03-15-2018, 09:09 AM   #560
jumpman2334
not enough to do anything (its not like the casting is a couple of inches thick, the bottom bolt locations also confirm this). it sounds like the only thing you can do here is raise the engine and trans (if the hood/tunnel will let you do that). not sure what that will do to COG and the other plethora of issues?
Old 03-15-2018, 09:11 AM   #561
S-Verteen
Driveshaft hit the weld on the start stop knot on mine, in hindsight i would have made it 3/8 longer. its minute so spacing the shifter up with 1 washer will work for me
Old 03-15-2018, 09:54 AM   #562
LuckyX2
LuckyX2's Avatar
Ah, so it's the brass bushing at the bottom of the shifter that hits? I haven't torn mine down yet but I had assumed it was the little L shaped link which can't be spaced up.
Old 03-15-2018, 10:48 AM   #563
TheRealSy90
I only ask because apparently the CD trans on Joe Haven's coupe has ground through some of that material by now and hasn't yet dumped it's fluid out lol. His car is low as fuck.
Old 03-15-2018, 11:14 AM   #564
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
It's a little big.
Youre using the collins plate adapter? How does everything fit up? Trans tunnel bashing?
BiG MiKE86 is offline   Reply With Quote
Old 03-15-2018, 11:37 AM   #565
jumpman2334
we will find out eventually. lol
Old 03-15-2018, 12:17 PM   #566
di-devol
Not so much at the firewall, but hella bashing for the tail in the tunnel. The tunnel isn't wide enough. It pinches the trans right about where the reinforcing is for the trans crossmember.
We did the 'ol in out, in out for a while to get it in. There also seems to be an offset to the shifter. The shifter us off center to the passenger side a bit. I can see the same thing in other people's photos.
I spent some time trying to center the shifter before I realized the transmission WAS centered lol
Old 03-16-2018, 06:38 AM   #567
Nemui
Nemui is an unknown quantity at this point
I have the Suspicious Garage 2jz/cd009 driveshaft and Serial Nine shifter and it doesn't hit at all. They state it uses a 3/4 ton chevy yoke which I believe is the 1310 yoke. The other option is a 1350 yoke which is a bit bigger and beefier but may run into clearance issues.
Nemui is offline   Reply With Quote
Old 03-22-2018, 02:41 PM   #568
di-devol
Never mind the exhaust, but here is a good shot of how low it hangs. Again, this is 1jz-cd with the collins kit in an s13
Old 03-22-2018, 03:37 PM   #569
HypnoFish
HypnoFish is an unknown quantity at this point
Man that sits low.
Im using all xcessive mounts and brackets and mine sits about an inch below the rails. using the Colins auto bell adpater kit.
HypnoFish is offline   Reply With Quote
Old 03-22-2018, 03:52 PM   #570
di-devol
Originally Posted by HypnoFish View Post
Man that sits low.
The top of the trans is 1/8" shy of hitting the trans tunnel. It is as high as it can go. I don't know how anyone's is sitting higher?
