10-04-2008, 10:12 PM | #541 |
CODYACE I am almost convinced on getting the JWT cams
so basically the S3 are better if i dont want to upgrade springs and c1's will need to upgrade the springs correct? I checked the price on the website its jsut about $550 bucks is that for the set or each cam? thats what is keeping me from buying them so far.. now question on the tomei poncam's any good? if they are what woudl you reccomend from them? of course i am running S14 SR JWT ecu 2871r 855cc inj etc..... thanks ahead, i am getting ready to buy this week!
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. Last edited by GabeS14; 10-06-2008 at 02:36 AM.. |
10-07-2008, 01:21 PM | #543 | ||
Trader Rating: (58)
Feedback Score: 58 reviews
In all actuality though, I would much rather see guys wanting that power, go with 30r based setups. Less PSI needed, equal spool up, and generally easier on the engine. It most certainly is. Water Injection (Which I still need to get fixed) will help solve that issue. Quote:
S3's will rock rock.
10-08-2008, 11:52 AM | #544 |
hey guys if i am making a 400hp at wheel what is the best turbo, cam and injector to get? 400hp at wheel = how much hp at engine? i sux at turbo..
my mod done so far Tomei Headgasket Tomei Rocketarms Tomei Valvespring (this 3 item done is becoz of my headgasket was going to spoil so i change 1st haha) Apexi PowerFC w Commander Apexi AVCR Custom Manifold Custom Downpipe Custom Cat Fuji RM01 exhaust if i am gg for ard 370 - 400hp at wheels (maybe pushing it higher later part) Turbo (which one shld i get?) if i am gg for Garrett (GT2871 .64 / GT2871.86 / GT3037/71?) will it lag? Injector (which one shld i get?)if i am gg for Tomei Cams (which one shld i get?) if i am gg for Tomei and what else do i nid? |
10-08-2008, 12:18 PM | #545 |
So cody, water injection helps a lot with heat soaking ? Also why not run race instead of water injection ? Can you explain the major differences ?
10-08-2008, 02:23 PM | #546 |
^^^ I think he means water spraying on the intercooler. Water/Methanol Injection is more commonly known to increase octane which it does... but its hard to tune for it unless you have like a 1 gallon tank in your trunk lol, in case you are boosting and spraying...
I have a done a lot of research about the snow perf and other out there. It can spray based on triggers such as RPM, gearing, etc etc, but I just don't like it how you have to know if it is out (granted some have lights or warning meters), but still I just don't want one more thing I need to check where JUST in case I run out my motor blows.....
Turn and Burn! |
10-08-2008, 02:56 PM | #547 | |||
Trader Rating: (58)
With Water Injection, you can run it all of the time, and really gain the advantages of a cooler combustion, without sacrificing anything. While some guys tune for more boost with it, I like it's safety advantages at the pump level. I love race gas, but do not think it should be part of a street based car. With the water injection (I use bug juice) it's super cheap, can be found everywhere too. On the Sentra, we used the actual windshield washer fluid reservoir...on an entire HPDE day, it will only use about half of it. It sprays above 3500/4k only, and you use the jets for the appropriate jet size. You can really notice the difference in response as well at the end of a long session. Quote:
It's easy to tune, and can be activated by WOT, RPM, or anything. Even a simple hobbs switch can work. Mine is controled by the JWT ECU. As far as when you know you're out....some come with warning lamps. I've seen some guys wire up a switch into the tank and then ativate a bulb in the dash. I bet ultimatly, you could order an OEM winter kit, that comes with the low fluid kit, and use that to trigger as well....tons of stuff. I stimply just check the tank. No offense, but if you're not constantly looking over/checking the car out, then a high power turbo car isn't something you should have. If you check the oil, you can easily check the tank. The main thing, IMO ONLY, is that you should use meth as a safety feature. I don't trust using it 'increase' boost.
10-08-2008, 03:55 PM | #549 |
Trader Rating: (58)
Nope, I need to quit being lazy and get a new pump.
10-08-2008, 08:37 PM | #550 | |
they dont answer emails anymore lol
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
10-08-2008, 11:55 PM | #551 | |
10-09-2008, 12:13 AM | #552 |
Trader Rating: (58)
The Extrude process essnetially 'polishes' the entire inner surface of the manifold and turbo. It improves effeiciency, and flow greatly.
for more pictures: Gallery :: Extrude Honed Turbine and Manifold
10-09-2008, 12:59 AM | #553 | |
if i am making a 400hp at wheel what is the best turbo, cam and injector to get? 400hp at wheel = how much hp at engine? i sux at turbo.. my mod done so far Tomei Headgasket Tomei Rocketarms Tomei Valvespring (this 3 item done is becoz of my headgasket was going to spoil so i change 1st haha) Apexi PowerFC w Commander Apexi AVCR Custom Manifold Custom Downpipe Custom Cat Fuji RM01 exhaust if i am gg for ard 370 - 400hp at wheels (maybe pushing it higher later part) Turbo (which one shld i get?) if i am gg for Garrett (GT2871 .64 / GT2871.86 / GT3037/71?) will it lag? Injector (which one shld i get?)if i am gg for Tomei Cams (which one shld i get?) if i am gg for Tomei and what else do i nid? |
10-09-2008, 01:02 AM | #554 |
get the gt3076 topmout with 264/264 cams 11.5 lift and 740cc injectors. (Halu)
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 Last edited by SoguRacing; 10-09-2008 at 01:39 AM.. |
10-09-2008, 01:36 AM | #556 |
Yes I think his response was driected to you.. I agree with his reccomendatin, that should put you over 400hp
10-09-2008, 11:15 AM | #558 |
1stly guys i am really sorry i keep asking the same question. coz i dun really understand.. i hope u all can help me out.
2ndly it hard to find a good workshop in SG that tune SR well & if it have it so F**in EX to tune in SG..so i hope that can get a ideal one and that it. if i am going for 370hp at wheel at least and my setting will be Tomei Head Gasket (alrdy in my car) Tomei Rocket arm (alrdy in my car) Tomei Valve spring (alrdy in my car) Tomei 270 Cams (planning on which to get) Tomei 740cc Injector(planning on which to get) Apexi Power FC (alrdy in my car) Apexi AVCR (alrdy in my car) Walbro 255l F/P (alrdy in my car) Custom Manifold (alrdy in my car) JIC Magic Downpipe (alrdy in my car) JIC Magic Cat (alrdy in my car) Fujitsubo RM-01 Exhaust. (alrdy in my car) which turbo will be ideal (coz mayb in the later part i will increase abit of HP but i think the most i will go to is 450hp) if using .64 will it push the turbo too hard in the end if i increase? if using .86 will it lag? if i start from 370hp |
10-09-2008, 11:51 AM | #559 |
Trader Rating: (58)
If you want 450 whp, go with a 30r
If you want 380-420, go with a 2871r .64, and smaller cams.
10-09-2008, 12:28 PM | #561 |
Trader Rating: (58)
My dyno is the trap speed dyno
10-09-2008, 12:36 PM | #563 |
from what I've read..and not from experience I would go with a 3076 which is what steve shadows has. he's got 264/264 cams a q45 throttle body, greddy intake plenum, and 740's. he's got 400 to the ground. stupid fast!! stock bottom end.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
10-09-2008, 12:41 PM | #564 | ||
Trader Rating: (58)
I understand that you're new to this, but PLEASE do some searching around on the forum. You're asking very simple questions, while we're trying to keep this thread somewhat technical about the turbo at hand. Quote:
As soon as you posted the dyno comment, I knew that SK had manipulated you Darn you SoCal suckerrs! haha (SK and I make love). Tell him he shoulda just went 35r and been done
10-09-2008, 12:51 PM | #565 | |
10-09-2008, 01:51 PM | #566 |
I Have had a problem with blowing headgaskets left and right and was thinking it could possibly be my tune on my power fc.
I will start off by saying I don't have a power excel dealer or support shop to tune my car so it has been done using FCdatalogit. Would it be a good Idea to ditch the power fc and get a tuned computer from rs-enthalpy or JWT instead of using power fc or does anyone know of a place that can tune my power fc and send it back with out having my car. My setup is simple gt2871r .64 hks 740cc injectors z32 mafs apexi pfc I am thinking that the timing map in the tune is off causing detination leading to my past 3 blown HG. Can anyone confirm that detination can cause blown headgasket problems. |
10-09-2008, 06:10 PM | #568 | |
Trader Rating: (58)
Steve is a good guy. He needs to come out to the East Coast !
10-09-2008, 06:12 PM | #569 | |
Trader Rating: (58)
Tuning could also be an issue, but most MLS gasket are pretty good at resisting simple detonation. As you said, you can always get your money back out of the ApexI unit and switch to a rom tune pretty easily. Do you have any more info on your setup?
10-10-2008, 05:01 AM | #570 | |
u all wouldn't recomend to put a .86 in SR right. |
