#541 | |
![]() Join Date: Apr 2008
sounds llike ignition issues.
1992 240sx (RB20. 362whp@16psi) |
#542 |
need help guys. a friend of mine just had an RB25 swap on his hatch. now the car is not runnin good. the car just dies while driving and/or sometimes wouldnt start. whenever we disconnect the CAM sensor (the one in the front) connector and plug it back in the car starts right away. is this a CAM sensor problem or timing problem? need help from you guys.
#543 | |
i would lean towards a CAS problem. try out a different one and see how it runs.
#544 |
thank you. i will try replacing that and hopefully it will fix the problem. thus anyone here have a Cam sensor that they want to sell? im located in west covina and my friend is in rancho cucamonga.
#545 |
Radiator problem/.
Hey guys, posted a thread about this, but decided to post here since this is all about an RB and can help someone later as well.
My old radiator cracked, so i purchased a new megan racing one. The only issue is the fans not fitting. They are Flex-a-lite fans, but the only way i see it working is if i put the fans on the front and remove the ac condenser(sp), or if i cut the support for the radiator, but i rather not do that. Question is, anyone know of fans that are smaller? Thanks Edit: The fans i have look like these http://www.flex-a-lite.com/auto/html/compact.html Edit. Ended up taking out the condenser. Last edited by 951's 330i; 03-06-2010 at 04:37 PM.. |
#546 |
rb20 help
i just put a rb20det in my car like a 3 weeks ago and it runs like crap. it came out of a running car i saw the car run the day we took it out. when we put it in my car it was running only on 5 cyl. so we changed the ignitor all of the coilpacks and the coilpack harness now it will not spark at all we used a rb25 ignitor and i think that might be the problem but i dont know. iany help would be golden cause i have a event in like two weeks and need to get the car running
#547 | |
you cant use an Rb25 ignitor on a Rb20 , the pinout is different. good way to check if its a coil pack is to put your Rb20 coils back in , along with your ignitor chip. turn it on , then one by one , unclip the coil to see if there is any change , if there is a change plug it back in and move onto the next one. if it checks out that all your coils are fine , then it could be a possibility that one of your injectors arent firing. try cleaning out the male and female connectors for the injectors .
#548 | |
it wont start at all. would i beable to change the pinout to get it to work. i did the coilpack switch thing and make sure all of the injectors a shooting and they all are. |
#549 | |
im sure you would be able to change the pinout , im just not sure how to do it. so you unclipped the injectors one by one just like the coil pack test and you say they all work. i guess it must be in the coil packs somewhere , check your grounds.
#550 |
ive done that and everything was good. so tonite me and my class are gonna build a new coilpack harness i will be sure to take pics and share with you guys. thanks very much for your help
#551 |
hey how do you guys pass emission test with an RB? i just recently got a NEO rb25 s13 and i gotta do one this month but i was wondering if they'll do obd1 or 2. i heard for obd1 they just do the sniffer test or something like but which one would they do for my car? do they do it by the year of my car or the engine?
#552 |
![]() Join Date: Aug 2009
Newb question... New to RB's but...
I bought an s13 coupe w/ an RB20DET and just wondering what oil filter and spark plugs they use that I would be able to get from a local autozone, kragen, carquest or napa... My current oil makes mud look thin hahahahaha not good |
#553 | |
![]() Join Date: Aug 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
#555 |
![]() Join Date: Dec 2006
Well since this has turned into a General Discussion thread I guess I'll post this
You guys that are looking for R33 Cross members Check here http://zilvia.net/f/s-chassis/310116...r-intrest.html
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
#557 | |
no idea ... but you can use the KA sensor is thats what you're looking for
#559 |
yea idk if i miss it or what but i was just wondering what the common problems were with the rb25det series II. the only one i read about is the crank collar is a must, but also read that it is only for racing only. anyways i would appreciate your guys feedback on any problems known about the rb25det series II
Thanks |
#560 |
one thing you should consider when doing bottom end work is replacing all the hardware with ARP products. thats your connecting rod bolts , main studs and head studs.
#561 | |
#562 | |
This guy local guy in making over 500whp completely stock even head gasket. Probably the weakest point are the piston ring land's, but if staying under 500 and not beating the shit out of it stock bottom end should be fine ![]()
#563 | ||
Fun Fact: Ran the part Numbers in FAST and Came up with this from the E61 MAFS Which is apparently the same as a certain J30 MAF (pic is here but Zilvia is not showing pics right now for me at least) ![]() Then This one is for the E60 MAFS ![]() Then the J60 RB20/25 S1 MAFS ![]()
#564 | |
#565 |
Hey everyone, quick question.
Im thinking of doing a holset turbo setup on my car. See, from way older posts, that if i can come up on a hks or apexi manifold, i should get that. I think thats what im understanding. Im looking to get the holset hx35 turbo. I found a hks manifold, and finally also the turbo but the thing is i only have enough money for one. Both for around the same price. I gues my real question is, should i get the manifold or the turbo right now? And if this manifold is worth it for that turbo? Thanks all/ Need the advice asap! |
#566 |
just wait buy the manifold and the turbo at the same time. so then your not lke " ok i have a turbo but no manifold .. no i have to play the waiting game" .
get it all at once and install it all at once ![]()
#567 |
Lol thats wat i had planned on doing, but i heard that manifold is really hard to come by. That or the Apexi one. So since i just now saw it, i was thinking i should get it. Lol I HATE THE WAITING GAME
#568 |
get the manifold they are allot hader to come by, Holset turbo's pop up a little more often in good condition worse case senario we can get you a new one from a shop in OC called Turbo City
#569 |
Yeah i was trying to get that manifold yesterday, but the last like 30 seconds it went from 220 to like 375 lol i lost
