07-15-2013, 01:25 PM | #5581 |
The setup i run now has identical components to the setup i ran before. Its just the way i have set everything up is different.
before i had -5* camber and 5* caster, geomaster knuckle with the included angle reduced and with a 245 40 17 ad08 now i have -5* camber and 9* caster, geomaster with normal amount of geomaster included angle and with 215 45 17 toyo road tyres too be honest both worked well for me, but the camber gain of each setup was night and day different My R32 pictured below has the top mount fitted to get maximum camber and caster and my s14 is also fitted the same way, but the top mounts need machining for more caster. Ive added camber at the top to help stay away from over centre
[SIGPIC][/SIGPIC] |
07-15-2013, 02:36 PM | #5582 |
yah the knuckle i build you dont have to worry about over centering. leave the camber plates rotated in the normal fashion and you get 52 degrees of angle no over centering and a good ackerman reduction, 5 degrees at full lock (on my car, need to confirm caster angle). no rack offset spacers no funny stuff just a part that works. confirming angles on another car tomorrow with my knuckle.
[email protected] |
07-15-2013, 03:41 PM | #5583 |
heres my cut knuckle.
4130 chromoly inserts laser cut and cnc bent at a local shop I TIG welded, pre heated and peened after welding and then cool in sand over night. this is my prototype so I have cleaned up the fit considerably since these knuckles. did some testing at the track, reverse enteries were no problem at all. (still confirming numbers and angles of everything on the test car) driver reports great steering feel and the steering quickness feels good not to fast. car doesn't want to get stuck at lock of feel sluggish. Just let go of the wheel and the car self steers the other way. got the car over a foot in the air at a jump at the balcony, inspected for any stress cracks on the knuckle and everything looks beautiful. super strong when welded correctly
[email protected] Last edited by Bink Industries; 07-15-2013 at 04:36 PM.. Reason: forgot a picture |
07-16-2013, 01:41 AM | #5584 | |
Rear is double wishbone instead of multilink for simplicity sakes. I later discovered double wishbone has half as steep anti-squat curve too, however but you can't really mess around with it as you can with a multilink. N8 of S-Empire - I spot a one piece lower control arm there too Lovely how modified the stock uprights |
07-16-2013, 03:24 PM | #5585 | |
I will post pics of my lower arm later.
[email protected] |
07-17-2013, 12:16 PM | #5586 |
Trader Rating: (24)
Feedback Score: 24 reviews
So I have the custom spindles that I've posted earlier in this thread that offer ~33mm of roll center correction and quicken the steering to 2.25 turns lock to lock.
For the new s13 I've put together I'm eyeballing the PBM spindles, but I don't really need "hellaangle" or anything. I'd just like the RCC and the quicker steer. Running stock FLCA,steering stops and tie rods I shouldn't have any problem running these spindles and getting what I want, correct? |
07-17-2013, 12:38 PM | #5587 |
you would likely need longer inner tie rods to reach the relocated pickup on the knuckle. you might be able to get away with just extending out adjustable outer ends (SPL etc.)
also i would make sure that the steering angle is limited where you want it. im might not be important if you're not drifting, seeing as you wounldnt be at full lock, but i would still make sure you're not contacting the frame rail or tension rod/sway bar |
07-17-2013, 08:55 PM | #5588 |
Flipped my brackets and pulled a collar today, as well as moved my camber plates to the middle, reducing caster.
Got the camber down to -6ish, and it raised the car some. Looks like I'll have to pull the last collar to get ride height where I want it. Kei-offices are definitely not meant to go low. There is even more angle now, believe it or not. TDP is also sending me their 100mm RC correction shanks
07-17-2013, 09:14 PM | #5589 | |
Well played sir, well played. |
07-18-2013, 05:36 AM | #5590 |
our billet rear knuckle prototypes have been machined up and we've started on our new R-chassis knuckles which I believe will also fit the Z32's.
Overlay of the S-chassis knuckle and the R-chassis knuckle: and our rear knuckles being fitted up: |
07-18-2013, 11:02 AM | #5591 |
If I started with stock suspension and coil-overs and didn't lower the car too much, wha is the most important thing to change first? I've read like 50 pages but I'm still not grasping exactly what the enemy is, so to speak.
07-18-2013, 11:03 AM | #5592 |
Tires......
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
07-18-2013, 11:36 AM | #5593 |
Subframe bushings and tension rods. Both bushings are huge and suck at doing what they're supposed to.
07-18-2013, 12:23 PM | #5594 |
the S-Chassis rear knuckle will work with the stock calipers and stock rotor?
07-18-2013, 03:21 PM | #5595 |
Yes they will/do. The mounting plates are interchangeable so you can easily swap out for different setups. This setup shown is exactly the same position as the factory rear knuckle to suit 2 oem calipers with the corresponding rotor. We will also have some Wilwood options.
07-18-2013, 03:29 PM | #5596 | |
Robbie |
07-22-2013, 10:28 PM | #5603 |
Been doing some research since I have replaced all suspension arms and the car needs alignment soon.
My main question is in the rear traction arm. I am not confident in the alignment shop handling this. Can someone with a very low s13 measure center to center their traction arm? I figure that will be a good start for me to get it in a good spot. What kind of extra length are we talking about here vs stock? Hate to thread jack, but you gurus can provide the best info. Input appreciated
@UpshiftEngineering |
07-22-2013, 11:15 PM | #5604 | |
07-23-2013, 12:21 AM | #5605 | |
07-23-2013, 07:33 AM | #5606 | |
07-23-2013, 08:44 AM | #5607 |
07-23-2013, 09:14 AM | #5608 |
I looked at that graph last night, I was tired and didn't take it all in.
I did not realize there were three traction arm measurements, was only paying attention to ruca stuff. My mistake. Now honestly I do not know what I want my curve to look like, considering I have not been into this whole suspension thing very in depth before. But lately I find it quite interesting...eventually I'll read this whole thread. Ninja edit, as stated quite bluntly below 'minimize toe out under travel' I think I'm getting somewhere. Thanks a lot.
07-25-2013, 08:01 AM | #5610 |
Random question.
All tierods with lengths listed on the first page have the same thread pitch at both ends right? Just only want to buy these once p.s. its awesome that I can just go to the first page of this thread to see which parts I need for which desired setup
cONtRol FReAkS |
