04-02-2011, 05:32 PM | #5403 |
Trader Rating: (58)
Feedback Score: 58 reviews
i hate you
04-02-2011, 05:40 PM | #5404 |
Well I ask because I've heard people say that its a shitty pump, that it doesn't do consistent load very well. I know it pumps more than the z32 and the z33, and considering i'm trying to finish the vq swap, I want to know would the q45 pump be better? I already have a walboro. And I know eventually, when I go supercharged that I will need to go with a stronger pump anyways.
Drives a BRZ and is building a V6 S12 coupe. |
04-02-2011, 05:45 PM | #5405 |
IIRC 100% of USDM s14's came with a factory third brakelight in the trunklid. because it is required by law that all new cars sold in the US have 3 brake lights. The s14 never sold in the US with a factory brake light in the wing. Canadian models might be different.
04-02-2011, 07:05 PM | #5408 |
Anyone know where I can find a spec sheet for different R34 differentials?
I bought a supposed R34 clutch type and I want to know what model it may have come out of.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
04-02-2011, 08:13 PM | #5409 | ||
Trader Rating: (58)
Keep the walbro. No reason to do the job twice. Quote:
OR you can jack the rear of the car up...and spin the tire over, and then count the driveshaft revolutions. Do the math to determine your ratio. You'll know a 4.08 froma 4.3 to a 4.6 for sure. I'd check the FSM for this info, as that would be the most reliable source to me. I know the 240 ones have info on VLSD and Open diffs.
04-02-2011, 09:14 PM | #5410 |
Right I dont know which FSM to check. Im sure they arent all the same for different trim levels of skyline right?
I mean a GTS FSM wont be the same as a GTR or GT right?
04-03-2011, 01:43 PM | #5411 |
oh true that, i thought you meant s14s in general
street dancer. GLEAM |
04-03-2011, 02:03 PM | #5412 |
Hi,
Anyone know how to troubleshoot a greddy electronic warning boost gauge? when i plug it in with a working sensor (i use it for my profec) it lights up but does not do any sweeps or read anything at all - how do i know if it's the control box or the gauge itself? thanks! |
04-03-2011, 07:44 PM | #5413 |
Trader Rating: (58)
Hard to say really, Nissan is kinda oddball with how they put together their FSM's.
04-04-2011, 03:56 PM | #5416 |
yo...i just got thde info back on my mines wc s14 ecu and i have a few questiosn. as i am still new to sr20s and well fuel injection in general
Dear Mr. Hunter, The specs for the ecu that you have is Fuel mapping has been optimized Injection and ignition timing adjusted Speed limiter has been cut Rev limiter has been raised 500 rpms Designed to run on 100 RON(at the least 98 RON) rating octane gasoline Max Boost set at 0.8kg (set at a safe level. Possible to boost higher depending on the circumstances, but boost at your own risk.) Best Regards, Daniel Larson Mine's Co., Ltd. 5-7-25, Hayashi, Yokosuka-City, Kanagawa, Japan 238-0315 TEL : +81-46-857-3313 FAX : +81-46-857-2708 Email : [email protected] URL : Mine's im worried about the the ignition and injection timing being adjusted. as far as i know everything is stock in the motor. guy thinks it might have aftermarket cams. but i havent checked. do i need to be concerned about it? or what else should i know about it? thanks for the help |
04-04-2011, 04:35 PM | #5417 |
Could an EVAP leak be causing my car to idle rough when the motor is properly heated up? On colder days, the motor stays cooler because my thermostat is stuck open, but on warmer days, when it heats up my car idles from 800-200rpm constantly, and gets super close to just choking out.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
04-04-2011, 09:13 PM | #5419 | |
Trader Rating: (58)
Sell it, and purchase a Jim Wolf Technology or RS Enthalpy ECU. The JDM ecu's are not setup for USDM based cars at all. Yes
04-07-2011, 01:27 AM | #5430 |
does anyone know which year/model the tweeters came in the s14's exactly?
I had a 95 se with leather option and it did have the tweeters. my 97 and 98 se don't have it. but my friends le does. Do the 97-98 only have tweeters on the LE models? and 95-96 se's tweeters comes on all? |
