Old 06-18-2015, 07:08 PM   #5311
NOLAGG
NOLAGG's Avatar
NOLAGG is an unknown quantity at this point
Originally Posted by BiG MiKE86 View Post
Yes sir I do have a build thread. Running koyo Sr radiator, TRD thermostat, Toyota coolant and distilled water. One Derale fan / one mishimoto fan
I'm looking on eBay at the derale fans and there's allot of styles available.which is the I've you personally run? Thanks for the input as well.Gonna check your thread out now.
NOLAGG is offline   Reply With Quote
Old 06-18-2015, 07:11 PM   #5312
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
No problem.
Derale Cooling Products 16925 Ho Rad Fan Pusher
BiG MiKE86 is offline   Reply With Quote
Old 06-18-2015, 07:18 PM   #5313
NOLAGG
NOLAGG's Avatar
No problem.
Haha cool.I'm actually reading your thread and doing my research on borgwarners . Any personal input?
Old 06-24-2015, 03:50 PM   #5314
bkg775
bkg775's Avatar
bkg775 is a well-known jackass
Hope this may save some people future headache but on my 2J coupe I used the 2JZGE pump with the factory reservoir that is attached to the top of the pump to clean my engine bay up a bit. Long story short it did not work and my pump squeeled like a pig whe I turned the wheel. I've since used my factory reservoir and mounted it back to the shocktower.
For those that don't know what the GE PS reservoir looks like ^^^
BlackHand
bkg775 is offline   Reply With Quote
Old 06-24-2015, 07:19 PM   #5315
NOLAGG
NOLAGG's Avatar
So what did you wind up doing? Lol
Old 06-24-2015, 08:57 PM   #5316
bkg775
bkg775's Avatar
Just used my factory reservoir in the factory location on the driver side shock towers. Gotta bleed to ps system to see if it'll work again like before. I had to install a steering rack as well bc mine was leaking and pouring fluid out the reservoir when I turn the car off
BlackHand
Old 06-26-2015, 10:42 PM   #5317
NOLAGG
NOLAGG's Avatar
Picked up my motor today ands have my Megan mani and s366 on the way. I'm going to be removing the twins from this 2jzgte aristo motor this week along with performing maintenance ands wanted to know if some one can point me in the direction on where to find a thread on what vacuums ands water lines I can delete/have to re route I order to simplify/clean things up.Thanks in advance.
Old 06-28-2015, 08:26 AM   #5318
NOLAGG
NOLAGG's Avatar
Got my motor and started removing the twins.
Quick question, what is our does that nipple go to coming out of the back of the block I the exhaust side?
Old 06-28-2015, 10:12 AM   #5319
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
It's just a coolant drain, there should be a bolt right above it that you can twist to open it. Nothing goes to it.
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 06-28-2015, 10:46 AM   #5320
NOLAGG
NOLAGG's Avatar
Oh ok cool thanks.should I open it and release whatever coolant was trapped inside? Also what vacuums can I eliminate clean up on the intake manifold?I see the iacv and map are feed to I think the stock fpr? Is that correct?
Old 06-29-2015, 10:53 AM   #5321
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
That blows, I was looking to do the same since I have a freddy manifold.
Yep, drain that dookie dook dook old coolant out (be sure to use toyota Red coolant when the time comes). Only vac lines you need are Map, FPR, and brake booster. Depending one which stock 2j manifold you have (some came with a fitting for the brake booster, some didn't) you should have enough nipples for each. Put a filter over the IACV.
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 06-29-2015, 11:06 AM   #5322
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
Anyone ever had an air leak at the injectors? I'm new to top feed injectors and was having some running issues (1JZ VVTI) with high idle and break up under load. I did a boost leak test and found air rushing out of the intake manifold where the injectors seat.
I went and bought new isolators today at Toyota but am unsure if that will stop them from leaking. Parts catalog makes me think there isn't any other seal there I should replace.
Toyota P/N is 23291-41010 for those interested.
bmaddock is offline   Reply With Quote
Old 06-29-2015, 11:06 AM   #5323
NOLAGG
NOLAGG's Avatar
Yea there's no fitting for the brake booster, just a bolt in the top. What should I do about that?
Ands can you explain about the filter in the iacv?
Old 06-29-2015, 08:30 PM   #5324
bkg775
bkg775's Avatar
Somewhere in this thread there's a link for the banjo bolt u need to run the brake booster to the Intake mani if that what u mean
BlackHand
Old 06-29-2015, 09:42 PM   #5325
NOLAGG
NOLAGG's Avatar
How's your Monday night 12 am? Cause this is what I'm doing.
Old 06-29-2015, 09:55 PM   #5326
supercompact
supercompact is an unknown quantity at this point
Some people will silicone them in like in this picture:
Also, make sure you have the right injector bosses/bungs for whichever top feed injectors you have. I think they are usually 11mm or 14mm. I'm assuming these are aftermarket.
supercompact is offline   Reply With Quote
Old 06-30-2015, 09:08 AM   #5327
bmaddock
bmaddock's Avatar
Thanks supercompact, I found the injectors had a good amount of axial play in the rail so found some spacers at a hardware store that I used to keep them seated against the isolator in the intake manifold. Started it up last night and sounded to have a lower idle and revved much smoother. Going to boost leak test tonight and verify.
Also, pretty sweet you can actually remove the injectors without taking off the intake manifold. I just took off throttle body and IACV and was able to get down there to unbolt the rail with relative ease.
Old 06-30-2015, 11:54 AM   #5328
ATLspeed
ATLspeed's Avatar
I just went to toyota to get the banjo and banjo bolt and washers. The option that someone did in this thread is cheaper though.
As for the IACV, remove the rubber hose and slip one of these on.
http://www.summitracing.com/parts/KNN-62-1360/
95 Supra Turbo
Old 06-30-2015, 12:39 PM   #5329
NOLAGG
NOLAGG's Avatar
Ok got the booster part, but with the iacv, isn't that filter that you linked me to for the exhaust side valve cover ? Looks to small to fit over the huge iacv fitting, please correct me if I'm wrong .
World you happen to have a pic of your stock intake manifold with all deletions done to it.(coolant lines, vacuums ,ect.)
Thanks brother
Old 06-30-2015, 04:31 PM   #5330
BiG MiKE86
BiG MiKE86's Avatar
Thanks brother
Check my build - I think I have pics of all that and part numbers
Old 07-01-2015, 01:23 PM   #5331
jbjslambert
jbjslambert's Avatar
jbjslambert is an unknown quantity at this point
Coolant pipe
I'm getting ready to go single and my borg warner turbo uses oil only. I don't need coolant...so has anyone ever deleted the pipe all together and made a block off for the water pump and the heater core feed on the back of the head?
jbjslambert is offline   Reply With Quote
Old 07-01-2015, 01:27 PM   #5332
NOLAGG
NOLAGG's Avatar
Instead of blocking it off, get a ge water pipe to eliminate all the coolant lines off the water output for the stock twins since you won't be using them no more.I'm doing the same and will upload a pic tonight some I'm getting it today from toyota.
Old 07-01-2015, 01:32 PM   #5333
jbjslambert
Yes. Im aware of using a the ge coolant pipe. But in a 240sx it still doesn't get rid of the problem of having a hose coming out of the back of the head that's higher than the rad cap. (Pita air pockets)
I'm wondering if the system would have adequate return without the pipe?
Old 07-01-2015, 01:36 PM   #5334
NOLAGG
NOLAGG's Avatar
Post a pic I'm not understanding.I'd you mean the coolant pipe that sticks straight up, loop it to your ge coolant pipe if you're not worried about heat
Old 07-01-2015, 01:43 PM   #5335
jbjslambert
Being a track car i have no need for heat. I would like to get rid of the pipe all together.
A hose connected to the nipple on the back of the head makes that hose the highest point in the coolant system in which causes potential air pockets
Old 07-01-2015, 03:42 PM   #5336
BiG MiKE86
BiG MiKE86's Avatar
Jack the front of the car up nice and high when bleeding [emoji16] I've got that setup and no problems
Old 07-01-2015, 04:18 PM   #5337
supercompact
Agreed, or park it on a nice steep hill and burp all the air out.
Old 07-01-2015, 09:50 PM   #5338
NOLAGG
NOLAGG's Avatar
Any one running a cx racing turbo manifold?I got the cheaper 160$ one and it didn't line up for shit.any suggestions besides throw it away?
Old 07-02-2015, 07:27 AM   #5339
BiG MiKE86
BiG MiKE86's Avatar
Send it back
Old 07-02-2015, 08:52 AM   #5340
Sky80
Sky80's Avatar
Is it just the studs that don't line up or the exhaust runners also? If just the studs, bore out the holes?
