05-02-2013, 05:59 AM | #5281 |
It's 1500 Euros plus shipping. They make kits for S13 and S14 subframes, you just have to specify when ordering.
05-02-2013, 07:21 AM | #5283 |
05-02-2013, 09:07 AM | #5284 |
If you are using an S13 as your car, keep the S13 subframe, s14 when extremely lowered loses its anti-squat and goes to pro-squat resulting in less forward bite
05-02-2013, 03:15 PM | #5285 |
I use my S13 to grip, and not exactly scratching the frame rails on the ground I currently cant get much higher actually, maybe 1/4" but not much more. i maxed the rear coilovers height.
As far as i can see, the wisefab rear kit seems to be available for S14 and S15 subframe. The S13 one is different and the kit wont fit, unless they provide the different misalignment spacers. edit: damn, didnt read the previous posts. thanks guys. Driftshop ... well there are some reasons i am not keen on doing business with them. The first one being the business is declared as a software making business. |
05-02-2013, 03:24 PM | #5286 | |
I have no idea why you'd want the wisefab kit if you're that high though, your camber and toe curves are probably very manageable. Not to mention you'd probably want to run a sway bar for normal track use.
05-02-2013, 03:45 PM | #5287 |
Yup, didnt see there was no sway bar attachment. My bad.
These are the reasons i wanted the kit: 1- i think my knucle bushes are shot and i cant be arsed to change them. They are the last oem bushes on the car. Just changing them for ball joints would cost me 300+ € already, and that is without labor. I need new traction and toe arms too, which are going to set me back another 240€. I think that is already half that kit price. 2- weight reduction. 3 - it looks cool and i can afford it (i should not come on that thread on payday really ) But yeah, no swaybar is a no go. I went back from a very stiff bar to the oem one, but am not ready to drive without one. |
05-02-2013, 04:44 PM | #5288 | ||
While driftworks might not be the lightest or have sphericals, they're better than your stock bushes and there is 45mm of drop there. GKtech also has really light RUCA's and Toe arms. BTW guys, this thread is now the biggest in Tech Talk. Pretty cool
05-03-2013, 01:34 AM | #5290 |
Hi,
One little correction, allthough it is not seen on the pictures or video, production version of our rear kit will have mounting points for the anti-rollbar.
Ready to Lock? www.wisefab.com |
05-03-2013, 02:13 AM | #5291 | |
05-03-2013, 03:41 AM | #5292 | |
Release date ? Pricing for a front & rear kit ? As far as driftshop goes, i have trouble dealing with an official importer that declares its business as a software company. Maybe the info is not up to date though, still i found that info on 4 other websites that are supposed to have info updated since may 1st. **edit:** The websites i got my info from were not up to date. driftshop IS correctly registered (confirmed on score3.com and verif.com). I based my info on societe.com, vilokal.fr, france-prospect.fr ... and on verif.com too. All 4 of them indicated driftshop is software programming company. The first 3 still indicates that. Data on verif.com has been updated though, but it still shows on google search as a programming company (probably because it needs to be indexed again, last sweep indicates it was like that on 8th of april) verif.com gives the correct info now. That and I usually bring my car to another shop that i trust for various reasons (i have known the people who work there for years, i know they do very good work although they lack a bit or organization; but they are the only ones i trust to drive my S13 without flashing a valet mode in the ECU). I wont say their name, but i think you know them already, they are in Fontenilles. One of the drift S13 they work on has a front wisefab kit. Anyway... is there a way to get that kit directly from you, or from another dealer ? Last edited by Croustibat; 05-04-2013 at 07:29 AM.. |
05-03-2013, 04:20 AM | #5293 |
Yes, shoot me an e-mail to [email protected] and we will find a way.
05-03-2013, 08:14 AM | #5294 |
My friend fab's knuckels, based out of Mooresville, NC. This are his V2 kit, it's set for 0 ackerman and has RC correction. They are paired with S14 LCA which have been boxed in and bump stops removed, and Ikeya formula inner tie rods/S14 outers. I love it! I also am running a 15mm bolt on spacer and my wheel wells have been cut out. We raised it a bit after the initial install and I never got around to lowering it because it just drives so well at the current height. I may lower it in the future, we will see. I am running about 5.5* camber all around and have a nice, flat contact patch.
Been running for about a year now: On the ground Running tandem with my friend Ivan, who also has these knuckles installed. Running against Forrest's LS S14 at Streetwise drift. Probably near full lock A fun run at SWD A local track we use to practice at.. Some decent GoPro footage |
05-04-2013, 02:15 PM | #5295 | |
This front kit should be showing up at my door this coming Friday...
05-05-2013, 05:17 AM | #5296 | |
That said, as the knuckles cost us more to manufacture than what we sold them we are more than happy to offer a refund. If you do want a refund email [email protected] and we will get that sorted right away. I personally have both my cars in pieces waiting for the knuckles so I understand the frustration and we are doing everything we can to get everyones knuckles out ASAP. 27 sets are going out on Monday with another 5 later in the week and then the remainder should be out within 2 weeks or so. Greg |
05-05-2013, 06:18 PM | #5298 | |
05-05-2013, 08:38 PM | #5300 | |
Oh right... good to see it's not just us that can have delays however in that case, we can't refund you haha |
05-06-2013, 06:19 AM | #5301 |
Discovered something interesting about my S13 that has front mounting point of the rear lower arm lowered ~60mm while designing a new upright:
Anti-squat is dynamic! |
05-06-2013, 11:14 AM | #5302 |
kinda just jumping into all this for one question but what would you guys do if you were planning on purchasing a angle kit for your track car right now?
I see alot of people are saying theres alot of down time for parts to come in but i dont mind waiting alittle while as long as its not anything crazy like 5 months haha thinking more along 1 or 2 max..... so with that said what angle kit would you guys go with? i was planning on having someone custom make me one but i feel its a better idea to go with a name brand with a rep behind it.... thanks in advance |
05-06-2013, 11:34 AM | #5303 | ||
If you're buying new stuff, just see if the company has it in stock. I know driftworks and wisefab are known to have things in stock and ship fast. Other companies are made in smaller batches or JUST coming to market. Quote:
This is interesting. What are the horizontal and vertical axis?
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 05-06-2013 at 12:24 PM.. |
05-06-2013, 11:46 AM | #5304 |
Is it a mistake not to use a "lock stop" while drifting?
I use Driftworks offset spacers so i guess they may have to take some pounding? since the rack is limiting how much lock i can have Driftworks offset spacer Driftworks geomaster knuckle Driftworks R33 GTR kinked tension rods 28mm extended s14 LCA By the way its on a s14 |
05-06-2013, 05:46 PM | #5306 | |
05-06-2013, 06:09 PM | #5307 | ||
I guess figure out what you want out of your front suspension, then see what gives you what you want, and if it's in your budget.
05-07-2013, 06:16 AM | #5308 |
Is there a reason you dropped the front instead of raising the rear? I was going to bring the back up because I thought raising the mounting point on the rear would help with the antisquat, and RC correction slightly.
05-07-2013, 06:30 AM | #5309 |
It also changes your bumpsteer quite a lot.
05-07-2013, 05:22 PM | #5310 | |
Theres no way that any welded knuckle mod can compare to the accuracy and consistency of a pair of our CNC machined forged blanks. Reserve a pair by clicking here.
