01-31-2010, 11:23 AM | #481 |
With the combination of NRG's short hub and gen 2.5 quick release, is the steering wheel exactly in the OE position?
From the Nardi website: (DEEP CORN) 350 mm = 80 mm offset 330 mm = 53 mm offset Is this offset (concavity) the same for their entire lineup of concave wheels (i.e. Sport Rally), and is this measurement from outside face to outside face of the steering wheel? Thanks
"I'm a rage-aholic, I just can't live with rage-ahol!!!" |
01-31-2010, 12:17 PM | #482 |
Will the Hi-Throttle pulley wheel from the s14 SR be compatible with the S13 SR motor?
THIA...
http://www.leg1t.com |
02-01-2010, 01:59 AM | #484 |
few random questions:
Does any of the front light (bricks, turns, park) wiring on an S13 Silvia, use the same plugs/connectors as the the S13 240? Are power steering pumps (RB25 specifically) gravity fed? I.E. does the resivoir have to be higher than the pump or is being at or slightly above ok?
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please. |
02-01-2010, 04:27 AM | #487 |
Trader Rating: (53)
Feedback Score: 53 reviews
that light indicates that your cat is overheating and you need to have it checked out. i first thought it was a engine overheating light when i saw it, but i later found out that it's tied into the temperature sensor that runs to the cat. if you dont have the cat anymore then dont even worry about it.
02-01-2010, 09:22 AM | #489 |
where do I get JUST the harness to put a blitz DTT DC in my Ca powered S13? I got it out of a STi that got traded in so I still have that harness as well.
"So here I am, right back at it again, just like I've always been" |
02-01-2010, 09:26 AM | #490 | |
.com |
02-01-2010, 11:50 PM | #492 |
Trader Rating: (53)
i suppose it should be, i would assume that the temperature at which the sensor would alarm is the same for both redtops and blacktops. I am not sure though. i had a cat delete pipe and the sensor was cut.
02-01-2010, 11:55 PM | #493 |
Trader Rating: (44)
Feedback Score: 44 reviews
I think it's a stock exhaust gas temp light. It came on one time at the track when my car was getting a bit hot.
www.realize-jp.net |
02-02-2010, 12:33 AM | #494 |
This only happened once but, when I was stopped my tach gauge went CRAZY, and started bouncing from 1-3k, and my turn signal went into warp speed, but after around 10 seconds or so it slowed and went to normal.
Loose wire? Bad fuse? |
02-02-2010, 06:19 AM | #495 | ||
No, the control arm will be too short. You need S14 ones.
Blitz Turbo Timer Harness NS-04: No Limit Motorsport Quote:
JDM gauges: USDM gauges: Edit, from the other thread, it is an exhaust temp sensor... it would only work if you have the exhaust temp sensor installed I guess:
02-02-2010, 09:22 AM | #496 |
I just got done installing my second Grant steering wheel. I noticed that on both the adapters won't allow the steering shaft nut (the factory Nissan one) to tighten down at least flush with the top of the shaft like it should with the stock wheel. I have had the correct adapters from Grant. Im going to call them later and make them aware of this. Over time if you dont use thread locker the nut gets loose and you have to retighten it. Kinda scary. I guess since the Nissan factory shaft nut is collared, I could try using a non collared one to get some more threads in there. Anyone else experienced this, and what did you do?
BOOYAH! |
02-02-2010, 09:39 AM | #497 |
I never plugged anything in remotely close to being a exhaust temp sensor, from what I can remember. Ive done a couple of swaps, but nothing has been cut or plugged into the exhaust/cat area. Only thing around there is the tranny snesors and wiring.
Thanks, for all the responses though guys. im getting a test pipe today to try to solve the problem.
.com |
02-02-2010, 02:11 PM | #500 | |
'89 Sil80, SR20DET, GT2871r .64 |
02-02-2010, 02:42 PM | #501 |
What can I use to replace the stock "T" fitting on the S13 Redtop Motor? The diameter is 13mm inner and 15mm outer....really don't want to buy a whole valve cover for just this metal piece...
02-02-2010, 03:46 PM | #502 |
I hope some one can help me answer this question. i just bought a bmagic s13.4 conversion a few weeks back and i am puzzeled on how to hook up the brackets that come with the kit. i have searched the web with a fine tooth comb, pm'd other zilvia members, but with no result. Dose any one know of some type of instruction or guide, write up i can use so that i can properly install the brackets to my s13?
Ricer: Any car which was designed to go slow and modified to even go slower |
02-02-2010, 04:36 PM | #503 |
woohoo i can be a noob comfortably!
i am getting 16x10's made for my S13 coupe and i want to run a bit of stretch (thinking 215's) can someone please suggest a reasonable tire size and offset that will provide a flush look without too much rubbing?? that fitment thread has almosy NO 16's in it. |
02-02-2010, 11:15 PM | #505 |
Oh DAMN. Well lucky you, cause when I went to install my Grant wood wheel today to replace the Grant that I had in there I could take the steering shaft nut off with my fingers. You can tighten it down with threadlocker but over time it will come loose. You will know when you feel play in the wheel, where there should be NONE. I am going to try to find a solution using a shorter, non-collared nut, one unlike the Nissan factory one and use a lock washer. If that doesnt work I have a 6 bolt 'JDM' hub adapter I will see if I can drill out to match the Grant 5 bolt pattern and use that.
BOOYAH! |
02-02-2010, 11:23 PM | #506 |
Does the KA use the same alternator brackets as the SR?
Basically what I need to know is this.. Is the hardware on the top of this picture (for SR): the same as the hardware in this picture? (for KA, apparently) |
02-03-2010, 02:00 PM | #510 | |
Trader Rating: (53)
