#481 |
Intel Core i5 2500k. Stock clock for meow.
AsRock P67 Extreme eVGA gtx570 16GB Corsair Venegence 120gb OCZ Agility SSD 500gb secondary HDD I mostly use it for surfing. From boot to windows desktop in 9 seconds. Memory consumption is finally a non issue for once in my life. |
#482 | |
![]() Join Date: Sep 2009
![]() Feedback Score: 23 reviews
thanks I'm building a new machine for Black friday Intel Core i5 2500k Asus Sabre tooth P67 eVGA super clocked 560 Ti 16G G.Skill RipJaws 115gb Mushkin |
#483 | |
I was going to go with that Asus board, but apparently their rep for making a solid board has gone down the shitter in the past couple of years, along with alot of QC problems. I remembered from the P4 days that Abit made a really good mobo, but they cut their operation down to like nothing and they dont make them anymore. I read alot of good things about the AsRock board, so I went with it. |
#485 |
![]() Join Date: Dec 2005
Did they change bullet drop with the update? I haven't played in a while but did a little last night, and I don't know if it was just me, but it really felt like I was having to aim higher than I normally had to (SVD). If they did, Sweeet.
#486 |
![]() Join Date: Mar 2004
Client-Side Changes
Visuals, Stability and Performance Fixes: • General performance and loading time improvements • “Black Screen” fix for an issue occurring on some PC Configurations • Stereo and Rendering Support for Nvidia and AMD Graphics Cards • Adjusted the “stuttering” encountered on some PC configurations. • Fixed several Crashes when joining MP and Co-Op sessions • Fixed multiple problems when using multiple monitors (Eyefinity / Surround). • Fixed visual corruption issues on certain Nvidia Cards • Improved loading times for certain textures • Added console command “GameTime.MaxVariableFps” to limit max FPS • Added console command “UI.DrawEnable” to hide UI for screenshots / videos Balance and Gameplay Adjustments (PC) • Fixed a problem with high speed mouse movement • Added back some missing Growlers on Kharg Island Conquest Large • Added back EOR sound for SQDM and TDM • You should no longer be able to damage a friendly vehicle when sitting in an open position • Grenades now drop to ground if you get killed while attempting to throw it(note the affect this will have on Hardcore mode!) • Spawn protection now should work in Conquest. You should no longer spawn on points too close to enemies • You should no longer spawn too close to enemies in TDM and SQDM • Combat areas on Kharg Rush tweaked in order to disallow defenders to access the carrier ship after 1st base is taken and being able to enter the AA gun • Fixed a problem with revived players not suffering suppression • Fixed a problem with the camera when being revived in COOP • Added joystick deadzone setting • Fixed sound for when climbing ladders • Fixed an issue with some weapon sounds in first person • Fixed a swim sound loop error • Increased the damage of Helicopter Miniguns, AA guns, and Jet Cannons against infantry • Increased the damage of Helicopter Miniguns against jeeps. • Reduced the physics impact of AA guns and Jet Cannons, players under attack from these weapons should no longer lose control. • Increased the damage of the 44 Magnum slightly. • Increased the range and minimum damage of the .357 Round from the MP412 Rex. • Increased the range of all .45cal and 9mm weapons. • Slightly increased the range of the P90 and MP7 and PDW-R. • Slightly increased the range of the 5.56mm PDW-R and decreased the minimum damage at long range. • Slightly increased the minimum range of the Mk11, SVD, and M39 EMR 7.62mm rifles. • Decreased the maximum damage and maximum range of the G3 and SCAR-H 7.62mm weapons. • Reduced the damage from FIM-92 and SA-18 IGLA missiles against aircraft. • Increased the damage and range of the 40mm BUCK rounds. • Reduced the damage .50cal weapons do against Helicopters. • Updated T90 canister shell tweaks to match Abrams canister shells UI Changes (PC) • Added round duration and ticket summary at EOR • Advanced squad polish – should be more intuitive • Significant changes to the Join Squad functionality (see below) • Fixed a problem regarding keybindings while playing • You should now get a better error message when being disconnected via Battlelog Server Update Highlights • EOD Bot exploit fix • Several crash fixes • Anti-stat padding measures taken, disallowing ranked servers to run obscure settings • Improved team kill kick configuration • Support for unranked servers. Unranked servers do not report players’ scores to Battlelog, but server administrators can freely control all settings Share your profile and stats with new Battlelog functionality • Ability to share your Profile and Stats pages to Facebook, Google+, and Twitter • User Profile and Stats pages on Battlelog can now be accessed without being signed in to Battlelog if you know a user’s URL • Single sign on from Battlelog to Origin. If you’re not logged in to Origin and join a game server, Battlelog will automatically sign you in to Origin in the background and join the game server Quick notes on Squad changes in the Nov 22 update • Removed FIND ME A SQUAD option • Allow players to join empty Squads alone, thus having 1/4 squad members • Change order of options to LEAVE SQUAD, INV A FRIEND, SWITCH TEAM • Disable Privacy flag when 1 man squad • Reset Privacy flag from Private to Public when squad drops to 1 player • All occupied Squads will now show up colored blue on the Squad Selection screen • Players who choose not to join squads will also show up as Blue in the “Not in a Squad” line • Squads that are currently empty will display as white — if you wish to join an empty Squad, you can choose the first one marked with white text A detailed look at Squad refinements A detailed look at Squad refinements Today’s PC client patch features numerous tweaks to Squad functionality and is part of our ongoing efforts to make it easier to play with friends and Platoon mates. These changes will also be implemented for consoles when we release the PlayStation 3 and Xbox 360 updates shortly. Stay tuned for the exact date of the console updates. First, we need to look at how joining with Squads and Platoons affects the balance of teams. Initially, servers are commanded to equal out each side, so joining with friends can impact that balance while joining with Platoons further hinders this. As a result we have made some adjustments to the in-game Squad management screen. For PC, you are now able to highlight the various Squads and select which one you wish to join by selecting a Squad and then clicking the Join Squad button. Please note that the Squad Privacy option still allows 2 man Squads which, during 64 player sessions, can lead to players with no squad position –- the number of people with no Squads will be shown at the bottom of the Squad selection list. i hope they nerf the ir scopes next. |
#487 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
Holy mother fuck, this. It seems like anytime I get killed anymore it's by a dude with an IR scope, suppressor, and a foregrip.
Also, I'm tired of being blinded by flashlights in the fucking day time.
#490 |
what gun do you use it on? i havent been able to find a practical application for it outside of long distance shooting with the assault riffles
2004 Nissan 350z 2002 Nissan Silvia |
#493 |
well for me looks like the game is broken,, a lot of people are experiencing black screen upon launch of a multiplayer game on pc after the new update..
Keep it Classy |
#494 | |
I was also having a issue with the way Origin was launching the game, it would cause the top portion of the screen to be like etched but transparent from the first frame. Its fixed now. Also, my update was only 400mb iirc??? |
#496 | |
Trader Rating: (25)
![]() I don't understand how I have this k/d, I suck haha.
#497 | |
hmm I like it because it has a 5 year warranty, good price, and good features :/ might just do that, I'm kinda forced to get a new PC as I'm 99% sure that my old one won't be able to play BF3 |
#498 |
![]() Join Date: Nov 2011
I mostly use a supressor on all my guns (depends on the map.) After I got over my CQ habits, I started using the sv98 with an ACOG/straight pull bolt/no secondary. Things a fucking beast and in one day my hit percent has gone up 1.5%. I'd say that's pretty good considering my main weapons are submachineguns and the only sniper I used was the MK11. Close quarters single shot to the chest=Kill.
#499 |
i got my longest headshot 654m on a 8x scope m98b . 12x is real garbage because of bullet tracer is incorrect blocks you and needs to be fixed. i use also the 4x and 3.4x.
i wish i can hit like 1000m/2000m with .338/.50 like in irl. also i hate how you cant have the bolt and the bipod.also man, the m98b reload animation is so long, i actually browse zilvia while i reload. unlike the usas12 is retardly fast, i'm running away (to a support) most of the time because i already blazed all my ammo. |
#501 |
I played a little last night because I wanted to up my longest headshot. I was about to give up because on the 360, the graphics start to break up at around 400m, so I was getting mad. Then I hit a 600 something and was happy because it beat my record, then I went on to hit a 774 in the same game.
#502 |
Its usually two shot, unless opponent has slight dmg already w hardcore 60%hp.
You get dmg from like jumping off a car. Also last night I had to 2 shot some guy face sticking out a window. It's retarded. Op my ass. Mag learned the hard way. They had a late dmg increase on .50 patch but most gamers already abandon the game. Bf should stick to more to realistic sim game not cod way. |
#504 | |
Trader Rating: (25)
How far do bullets travel until they disappear? I have a 688m headshot but anything longer and the tracer disappears so I don't know where I'm shooting, haha.
#505 |
I love how everyone assumes the Barrett is a .50 caliber
![]() I don't know how it is on the PC but on the console version the mountain peaks disappear visually and you have snipers floating in the air, yet the mountains are still physically there catching your rounds. It makes for really difficult ranging and drop compensation when counter sniping. I wish the 12x ballistics was a mil-dot reticle... much easier to range than the ballistic. On the beta I completed support but I've been really happy with assault class now. I do miss dropping all my c4s on top of a camping prone sniper though ![]() |
