Old 01-15-2013, 02:57 AM   #4951
--Redwork--
--Redwork-- is an unknown quantity at this point
65* will be will with big lock spacers.
No way you can get that much angle from just a knuckle change.
--Redwork-- is offline   Reply With Quote
Old 01-15-2013, 01:24 PM   #4952
Motary
Motary's Avatar
Motary is making a name for him/her selfMotary is making a name for him/her self
Send a message via MSN to Motary
Originally Posted by KA240SX808 View Post
Are those approx/ Angle numbers with Just the Knuckles?
With 6-7mm Slip on ITR Spacers?
Big 14mm Spacer + Slip on ITR Spacer?
Just curious if that 65* is straight from the Knuckle only.
I did some vectors on their stuff, also max 55 degs.
Motary is offline   Reply With Quote
Old 01-16-2013, 07:46 PM   #4953
GKTECH
GKTECH's Avatar
GKTECH is making a name for him/her selfGKTECH is making a name for him/her self
zero ackerman installed (the previous setup shown was actually the extreme steering arm)
USA Warehouse now open
www.gktech.com.au
GKTECH is offline   Reply With Quote
Old 01-16-2013, 07:49 PM   #4954
GKTECH
GKTECH's Avatar
That number is just an estimation at this point however we'll know 100% in the coming days however the estimation on the extreme steering arms is based on installation with the offset steering rack spacers.
As the knuckle is modular our steering arm options are virtually limitless
www.gktech.com.au
Old 01-16-2013, 09:20 PM   #4955
dil han
dil han is an unknown quantity at this point
Thoughts on these? First set made still in testing.
Countersteer Motoring 240sx Steering Knuckles - YouTube
dil han is offline   Reply With Quote
Old 01-16-2013, 10:04 PM   #4956
PoorMans180SX
PoorMans180SX's Avatar
Basically a PSM Pro knuckle with less roll center correction and less development behind it. It will probably work pretty well.
Old 01-16-2013, 10:07 PM   #4957
dil han
Good to hear!
Old 01-17-2013, 03:51 PM   #4958
swiftmini
swiftmini is an unknown quantity at this point
Not using a jig to aid modding knuckles to that extreme is a little shonky imo :/
Ive never known anyone to do it freestyle like that
[SIGPIC][/SIGPIC]
swiftmini is offline   Reply With Quote
Old 01-17-2013, 04:04 PM   #4959
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
any ETA yet on the PBM cast knuckles?
haven't seen much posted on them since they posted their first test batch a while back.
jaysgottaredtop is offline   Reply With Quote
Old 01-17-2013, 04:26 PM   #4960
dil han
A jig is to mass produce quickly and precisely. The knuckle in the video is one of the first pair. Now that each are made, a jig can be made. Also because everything is cut square and true, with proper measurements everything lines up perfect every time.
Old 01-17-2013, 04:28 PM   #4961
PoorMans180SX
Forged knuckle. They're on Matt Fields car and a few others for testing. I'm guessing they're letting them run for at least a few events each, then they'll start producing them.
PSM knuckle has 62 degrees with their small spacers. It is possible without those big spacers.
Old 01-17-2013, 04:32 PM   #4962
jaysgottaredtop
excuse me, forged. lol. you know what i meant. the not-hacked-up-and-welded-back-together kind.
tell em to hurry up before i give in and buy GKTechs.
Old 01-17-2013, 05:44 PM   #4963
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
Ya it really does not matter how careful you are in that hand cut hand weld operation no matter how carefully you measure. Matching the left and right needs to be CNC the smallest change is just a really large result. Our modded knuckle is on a CNC jig & even then its not dead nuts since there is some welding heat force on the parts despite the jig. The upcoming Forging is even more precise since the blank is getting the CNC machining directly with zero heat factor. ETA March.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 01-17-2013, 09:39 PM   #4964
808drft
808drft is an unknown quantity at this point
Id say possibly but Dan should answer it. I have their old weld on kit which is roughly 50ish* of angle (checked with alignment machine but wheel heads hit my fender before full lock and was at 47*) and my tie rods are no where near bottoming out in the rack.
808drft is offline   Reply With Quote
Old 01-17-2013, 09:46 PM   #4965
jaysgottaredtop
Originally Posted by DC Dan MAX USA View Post
ETA March.
word. hurry up. lol.
Old 01-18-2013, 02:11 PM   #4966
GKTECH
GKTECH's Avatar
we've just finished our tests for static load and fatigue over 500,000 cycles on the steering arm and the hub spindle (we used a V1 prototype knuckle for the hub spindle test).
Our on screen FEA simulations were validated with the real world test data which means that we've now got sign off from our engineering firm.
Here's the V1 prototype knuckle about 60,000 cycles in to the fatigue test on the hub spindle.
www.gktech.com.au
Old 01-18-2013, 02:12 PM   #4967
GKTECH
GKTECH's Avatar
P.S this means that we'll be machning up knuckles from Monday and they'll be finished in around 3 weeks time (we've got 100 sets of knuckles to machine up along with all the accessories)
www.gktech.com.au
Old 01-19-2013, 03:33 AM   #4968
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Will all your knuckles and the knuckle adapters come with both sets of the ball joint taper inserts?
It would be nice having the option to use either S13 or S14 FLCA without having to swap ball joints.
Old 01-19-2013, 03:37 AM   #4969
GKTECH
GKTECH's Avatar
It would be nice having the option to use either S13 or S14 FLCA without having to bother with swapping ball joints.
At the time of ordering you can configure the knuckles and RC bolt on kit. They come with either S13 or S14 ball joint taper inserts however you can purchase the inserts on their own for $20 if you don't want so swap ball joints when playing around with different LCA's
www.gktech.com.au
Old 01-20-2013, 03:54 AM   #4970
GKTECH
GKTECH's Avatar
Fitted up with a wheel alignment
www.gktech.com.au
Old 01-22-2013, 09:55 AM   #4971
My$800S14
My$800S14's Avatar
My$800S14 is an unknown quantity at this point
How did you align it with a tire in that condition?
Sent from my SCH-I535 using Tapatalk 2
MAddDsBRO
LEHDABIHLOO
My$800S14 is offline   Reply With Quote
Old 01-22-2013, 10:49 AM   #4972
PoorMans180SX
Because alignments aren't tire dependent?
Old 01-22-2013, 01:10 PM   #4973
My$800S14
My$800S14's Avatar
Well yeah thats true, but the settings will change some when you put good tires on a car that was aligned with bad tires, I guess it was a dumb question anyway
MAddDsBRO
LEHDABIHLOO
Old 01-22-2013, 01:44 PM   #4974
Croustibat
No. They are not tyre dependant, again.
Yes.
We dont care about that.
Old 01-22-2013, 02:24 PM   #4975
Giuseppe@EnjukuRacing
Giuseppe@EnjukuRacing's Avatar
Giuseppe@EnjukuRacing is an unknown quantity at this point
Send a message via AIM to Giuseppe@EnjukuRacing
Hmmm.. would love to try this setup on my car.
Giuseppe@EnjukuRacing is offline   Reply With Quote
Old 01-22-2013, 02:25 PM   #4976
My$800S14
My$800S14's Avatar
Yes.
Thanks bro!
MAddDsBRO
LEHDABIHLOO
Old 01-23-2013, 12:06 PM   #4977
kewilso3
kewilso3 is an unknown quantity at this point
I think it might have been mentioned before, but is the geometry the same as your modded knuckles? Will the price be the same $400? Will you continue to offer modded knuckles or will the forged pieces replace them? Thanks
kewilso3 is offline   Reply With Quote
Old 01-23-2013, 12:31 PM   #4978
DC Dan MAX USA
Trader Rating: (79)
Geometry is the same. The price will probably be the same so therefore there is no need to continue to mod the S chassis knuckles after fresh stock arrives. Even know the product cost is the same, the expense and convenience overall is better than before because you save shipping cost in one direction and the time it takes to remove the old ones, box them up & ship them out.
Old 01-23-2013, 01:21 PM   #4979
kewilso3
Here's gktech's knuckles using the zero ackerman arms mounted to the "wrong" sides...
Old 01-23-2013, 03:45 PM   #4980
jaysgottaredtop
^ so basically you buy GKTech knuckles w/ zero ackermann arms and have the option of zero ackermann OR pbm-esque steering angle results, depending on which way you mount the arms?
...in my very science-based estimations of grainy MS Paint'd internet pictures.
anti-squat, best thread ever, kpi, roll center, steering angle, suspension
