01-05-2013, 12:52 AM | #4921 |
You should see around 65 degrees of steering lock with these however I'm unsure exactly how much camber this will add. I'll ask the question from the engineering firm and see how we go although it won't be any different to running S14 LCA's in an S13.
01-06-2013, 05:30 AM | #4923 | |
Will you be making them for an S13 or S14 ball joint taper? Or both versions (hopefully)? |
01-07-2013, 10:36 PM | #4927 | |
Against manifacture defect, not stupid people defects, or driver mishaps What size are the bolts for the tension rods, and the inner pickup for the lca's Im pretty sure they are 14mm or 16mm and i know it was covered in here a while back, but I cant find it, I would be willing to delete this if necessary to avoid redundancy Sent from my SCH-I535 using Tapatalk 2
MAddDsBRO LEHDABIHLOO |
01-08-2013, 12:56 AM | #4928 | |
The inner LCA bolt has an M12x1.25 thread however it is 14mm's on one side (ie. one side of the bolt is wider than the nut side) |
01-08-2013, 01:32 AM | #4929 | |
Can't wait to see those in action.
Anyone got some updates on PBM Forged Knuckles?
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
01-08-2013, 02:11 AM | #4930 |
GKtech stuff looks awesome. But I would also love to know more news on the PBM forged front knuckles. I am patiently waiting for these to be released. Will definitely be ordering a set as soon as they come out. I think there are a couple cars currently running them and testing them out like matt field's s14.
Corndrift Blog |
01-08-2013, 02:39 AM | #4931 |
I need to test if some of this will work on a S130..
Can I be a beta tester? haha I plan to try out stock s13 knuckles so I can simply use the s13 coilover system since I already have the rears in. |
01-08-2013, 04:04 AM | #4932 | |
01-08-2013, 07:44 PM | #4933 |
Ok so whats the best size hiems to use for the pickup point for the tension, and lca's? Im thinking 17 or 18mm?
01-09-2013, 06:57 AM | #4934 | |
You need to use heimjoints after their static radial load, not bolt size
you need ones that can do atleast 60kN or 13500lbs, also this has been discusses earlier in the thread. Good news from wisefab facebook page: Quote:
01-09-2013, 11:18 AM | #4935 | |
I'm about halfway through a big update for the main post on my computer, I'll be editing it soon.
01-09-2013, 11:58 AM | #4936 |
Looks like Trela doesn't use Driftworks knuckles...Hahahahah.
01-10-2013, 08:31 AM | #4938 |
Big update to the OP! Let me know what you guys think!
01-10-2013, 09:34 AM | #4939 |
I'm a huge fan and i still don't get WHy and WHY and WHYYYYY this thread is STILL not a sticky what the hell this is the single most only reason to be on zilvia, this thread.
01-10-2013, 09:47 AM | #4940 |
I think this thread should be a sticky ... on nissanroadracing.com
very good job, but i think there is a more to be said about the steering rod. There is a very informative thread about it on NRR, to avoid various bumpsteer issues (bump oversteer/understeer) they dont need to be parallel to the LCA, but they need to intersect the LCA at the same point the "KPI" line does, or something like that. Dont quote me exactly on that though, i am still working on it. If i understood correctly you can get a massive toe change on bump/rebound by spacing the steering rod connexion to the knuckle, and the adjustment to do to get a very small toe change instead is very very small. Check "bumpsteering an S13" or something like that on NRR. Very very instructive (warning: dont read if without some anti headache drugs) |
01-10-2013, 01:21 PM | #4943 |
Great new front page. Answered some of my questions about roll center correction from the point of view of a road racer, not so much a drifter. Just need to start saving an ass-ton of moneh.
May the bridges I burn light the way. |
01-10-2013, 02:11 PM | #4944 |
Front page is great! But you may want to add that Garage 7 offers a bolt on lock kit for the R33/R32/Z32s double wishbone setup aswell.
Garage 7 R32/R33 Skyline Bolt In Lock Kit |
01-10-2013, 02:20 PM | #4945 | |
I need to add TDP's R-chassis lock kit too.
01-10-2013, 10:20 PM | #4947 | |
01-14-2013, 01:21 AM | #4948 | |
01-14-2013, 12:38 PM | #4950 | ||
With 6-7mm Slip on ITR Spacers? Big 14mm Spacer + Slip on ITR Spacer? Just curious if that 65* is straight from the Knuckle only.
