06-11-2012, 04:47 PM | #4891 | |
lests say i wanted you to make me a cell for this.. ( what would you charge and when can i buy it) if you were willing to make the same setup for this car. This is tha pan i made for the car. Only issue im going to have is re doing the bracing i put in under it for a drop in tank. Might want to do a cell that mounts on top of this but something like 28''l x 20''w x 8''t were looking for 12-15 gal
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover The build http://zilvia.net/f/builds-builds-on...u-city-az.html Owner of NVS Fabrications |
06-11-2012, 10:13 PM | #4892 | |
Edit: Thats funny, just noticed you are in arizona as well haha. Getting hot as heck here xD
S14 KA NA two cylinders, 75whp limper Last edited by tauntdevil; 06-11-2012 at 11:52 PM.. |
06-12-2012, 02:02 PM | #4893 |
Any advice on where one could get started on learning to fab?
I was thinking of picking up a welding class at my community college but not sure if it'll help or if it's different. Any schools anyone went to? Pretty much, where did you pick it up/learn? |
06-12-2012, 10:44 PM | #4894 | |
Can borrow a welder or if you want to get into it seriously, buy a welder and start with simple stuff like metal plates to make angle or stitch weld the strut towers of cars, etc. Start off cheap with a mig welder. I got a harbor frieght one for $25 once. Dont need anything super expensive at first unless you want too. Make sure whatever you weld is clean. Bare metal clean. I normally use acetone or alcohol after grinded it to bare metal. Also if you have a friend with a welder, see if he will let you weld a little.
S14 KA NA two cylinders, 75whp limper |
06-15-2012, 05:28 PM | #4895 |
nothing to fancy $30 in AN fittings for a radiator overflow tank
16oz budlight bottle because our build is powered by budlight + -4an straight bulkhead an fiting +90der -4 an = a catch can .. I will be sealing the cap with super black silicone but you get the point
06-15-2012, 05:59 PM | #4897 |
^^^^ one up much ... FU i hate you lol .. amazing work though ,,
06-15-2012, 07:24 PM | #4899 |
My next buy will be a 180 .. I need to Tig so bad
06-16-2012, 09:28 AM | #4900 |
Trader Rating: (42)
Feedback Score: 42 reviews
I was looking at them but found a great deal on this 165. Had 2 hours on it with the unregistered warranty, Foot pedal and everything to hook up for 1k.
SW Fab |
06-17-2012, 03:13 PM | #4901 |
what i have been working on for the last year plus
06-27-2012, 06:30 PM | #4902 |
Here's a fiberglass piece I've been working on the past few days.
It's for a '60 VW bug driver rear window. The purpose is to replace this window and get more air to the engine bay to help with cooling.
06-27-2012, 11:30 PM | #4904 | |
The grey is body filler. Once I trimmed all the foam Down i used the filler to smooth it all out.
06-28-2012, 11:22 AM | #4906 |
Trader Rating: (82)
Feedback Score: 82 reviews
If I'm not mistaken, you can't have the rear bars attached to the rear bar for certain type of drift competition
NEED Bolt kits for your car? |
07-02-2012, 12:00 PM | #4911 |
im looking for opinions on this welder....im looking for one to get started welding with, to do some light work and sheet metal. ive found a guy selling a hobart 115v with argon bottle and cart for a decent price, but i want to make sure i can adjust the heat to create better welds, heres the pics of it...let me know if its worth it
07-02-2012, 09:53 PM | #4913 | |
For me this welder doesn't have enough settings but will probably do the job just fine. Not a fan of hobart but there a good welder just make sure its 220v capable so you can really get good penetration.
07-09-2012, 04:33 PM | #4914 |
What do you guys think about the Lincoln Electric K2185- 1? I'm not looking to do anything crazy mainly exhaust & bracing. The price doesn't seem bad plus I don't have access to 220 only 110 in these beat ass apartments lol.
07-15-2012, 01:29 AM | #4915 |
two quick questions
No welding skills what so ever, point me in the right direction? What would be a good piece of equipment to grow on? No real price range! Third, I lied. picture below has a bolt in cage for a 350Z, yet the cage setups are generally all the same. The bar to the sides of the passenger/driver seats, does it have to be straight? Adding two more point that go to the footwells, would that help? The reason behind the question is that I'm tall and the bar being straight would ruin any ride over 10-15 minutes for me. Thanks |
07-15-2012, 06:07 AM | #4916 |
I guess I'll throw some junk up here I did.
Axle hubs for a S14, I think this was so we could use 300ZX hubs in a Q45 differential or something like that? It was a weird mix up of Nissan OEM pieces. Couldn't be done on a turn table because I had to clamp it down level while welding. Mild steel axles and hubs with SR70S-2 filler rod. S-Chassis SR20DET turbo manifold with Tial v-band collector and four EGT bungs. Cast 304 stainless steel, flanges of unknown stainless alloy, 304L filler rod. Welding procedure test during a manifold in progress. Checking for penetration. S14/S15 'black top' SR20DET intake manifolds to fit RHD/LHD S13-S15 S-Chassis. I don't know all the aluminum alloys for this, but I used 4043 filler rod. |
07-15-2012, 11:28 AM | #4917 | |
No the bar doeas not need to be straight. You can have up to 3 bends in that bar. When i did the bars on this s13 hatch i uses 2 bends and got them as close to the A pillars as i could beacuse the driver is 6'2'' and needed the room. as the car sits now waiting for the paint guy to come paint the car Silver.
07-15-2012, 07:57 PM | #4919 |
Thanks a lot!
