03-05-2011, 07:06 AM | #4891 | |
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
03-05-2011, 07:08 AM | #4892 |
O hello I was going to ask a q too...
so searched and got two answerrs... What are the weights for the stock base 4 lug 97 240 15 inch wheels, MESH style I guess you can say. I got 15 lbs or 18 lbs. can anyone confirm?
03-05-2011, 07:53 AM | #4893 |
I have a s13 open diff, pulled the gear box out to get it plate welded had no idea this came out and the DIY of pulling it out I used didnt mention this part and I have no idea where it goes I know its not the 2 small spacers you put on the other piece that goes on the bearings so wtf is it?
03-05-2011, 08:35 AM | #4894 |
I have a turbo that came with m car, the serial number says its a T-23753 but is not listed on their website. It is a genuine turbonetics. Turbonetics 50 trim .63 T3/T4 polished is what the for sale page said, but there is no t3/t4 on their website. Only t3/to4e(B). Can anyone help? I don't have pictures right now.
03-05-2011, 11:16 AM | #4895 | |
03-05-2011, 10:04 PM | #4896 |
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
How crucial is to tuck up the wiring harness under the front fenders? Can you get away with not doing it on a S14 if you're lowered, but not ridiculously slammed
★ ★ GRANDMIGHTY.COM ★ ★ |
03-05-2011, 11:17 PM | #4897 |
^you're gonna need to still tuck the harness. my friend is only 3-4inches high, from the front lip, and he rubbed his harness a little bit.
03-06-2011, 03:48 AM | #4898 |
180SX headlights with NSX headlight coversion, are they still motorized or do they then become fixed to only be sleepy eye or full ?
03-06-2011, 10:47 AM | #4899 |
thanks brotato - it should be the same
they become sleepy/permanent cause the nsx headlights don't come up as much so theyll angle super high up on 180sx
street dancer. GLEAM |
03-06-2011, 12:51 PM | #4902 | |
03-06-2011, 03:51 PM | #4903 | ||||||
Trader Rating: (58)
Feedback Score: 58 reviews
Here is an FSM page that I found after about 2 seconds of google searching for 's13 differential teardown' as I couldn't remember for the life of me which side it went on. Quote:
03-06-2011, 04:35 PM | #4904 | |
03-06-2011, 04:57 PM | #4905 |
im trying to change my headlight, but the screws on the metal trim wont come out even with pb blaster..if i brake the trim off is there a way to hold the headlight? would the plastic hold them in place?...help me! i need to drive at night
03-06-2011, 05:07 PM | #4906 | |
The top metal plate/cover does not support anything. (#9) The headlight support bracket (#5) is held on by 4-5 bolts and will not be affected by removing any trim |
03-06-2011, 07:18 PM | #4907 |
Ah K, yep understand now how if you would have them at Full Open the entire headlight would be pointing to the sky, Looks like they have to be fixed at the correct pointing angle.
Thanks chiboy & towlie.
03-06-2011, 07:52 PM | #4908 |
Trader Rating: (58)
That's what it is.
T3/T4 is just a generic forum name/abbreviation that people use for the T3/T04x (x being a variable letter to determine housing type). Turbos.
03-06-2011, 07:56 PM | #4909 |
will s14 se 5 lug hubs fit directly into a non se s14 or would i have to switch anything out?
06 subaru sti Sold/ 89 silvia coupe Sold/95 s14 work in progress/93 supra |
03-06-2011, 08:15 PM | #4910 | |
Trader Rating: (58)
Remember when you were in highschool and you had to type up a report about, I dunno, Frogs. You don't know shit about toads, so you went to google, or the magazine search thingy, and typed in 'Frogs'...and that got you results. Then you needed to find out how Frogs's mated and whatever. So you typed in, 'Frogs Mating' or 'Frogs reproducing'... ...well that same sort of stuff applies to cars, and the car forum. Instead of sifting through 8 pages of false wiki pages, and other shit, the forums have a search button. You type in 's14 hub swap' or something like that into the search and you read through the results...or you even goto google and do it. When well these guys realize tis isn't the 'Small questions thread, post hhere instead of searching' thread...the last 10 pages have been full of the same nonsense. PS: In case you wanted to know, here are two toads humping at the pond back at my parents house. Pretty load for being so little. Croaking and stuff. Unrelated, but it works.
03-06-2011, 09:01 PM | #4913 | |
cool thanks dick..
03-07-2011, 12:10 AM | #4914 |
OK here's an odd Q as this is bothering me. I like to keep my car nice and clean inside and outside. After cleaning the interior, I notice that after a week the interior builds up a good amount of dirt and dust. I keep my windows shut and recirculate the air, but it seems as if there isn't a filter keeping the dirt out from the vents. I know the car doesn't have a cabin filter. Is it possible that I'm getting dirt filtering past the door jams in between the door weather stripping? I got rid of my wheel wells and have reason to believe that this is contributing as well, but all my air vents are covered with dirt and dust. Any suggestions to keeping a clean interior?
03-07-2011, 12:35 AM | #4915 | |
03-07-2011, 07:03 AM | #4916 | |
The lining will cause a lot of shit to come into the cabin, since air flow is directed right into the door seam instead of under the car now. These cars are old as hell too, the foam seals on all the vents and all the piping has been long worn out, they're dry and don't really serve a purpose anymore. The dust behind the dashboard probably is sucked in with that and gets blown into the cabin rather than staying behind the dash. The weather stripping might not be so much of a problem but it also adds to this, seeing as those are probably going out as well. Solution? There isn't really much you can do other than completely get rid of all the dust everywhere in the car and clean it routinely, removing most of the dust will keep it from recirculating but more will always continue to come into the car.
03-07-2011, 08:10 AM | #4917 |
Trader Rating: (58)
03-07-2011, 01:05 PM | #4918 |
I have a 96 240sx it was converted to 5 speed. Check engine light for neutral position switch and knock sensor. My question is if I get the 96 manual ecu for it and a new knock sensor the check engine light will go away right?
03-07-2011, 01:10 PM | #4919 | |
Overkill, if you ask me. |
03-07-2011, 02:50 PM | #4920 |
i have 17x9 +12 215/40/17 up front and 17x9.5 +12 235/40/17 in the back..
What camber specs will i need for it to be flush but not crazy flush, It'll be my daily driver. I have coils and full arms, i'll roll my fenders if i need to. |
