03-11-2012, 01:54 PM | #4681 |
Trader Rating: (29)
Feedback Score: 29 reviews
It is a bit of a balancing act in that you want the bar to be strong enough to resist small impacts " rubbing", but in a bigger one you want it to give and absorb energy without destroying the chassis.
03-13-2012, 01:43 PM | #4682 |
so how do you guys make exhaust manifold flanges for your projects?? im wondering if there is a place where you get your dimms for your cnc program or if you take measurements yourself. im current a MET student who is in a class running FAE analysis on solidwork files. i would like to design a sr or kat manifold but cant find a place with dimmensions made for the flanges. any ideas?
03-13-2012, 04:30 PM | #4683 | |
S12 || KN13 || S13 || B16 |
03-14-2012, 09:36 PM | #4688 | |
i never thought about scanning the gasket, also didnt know you could trace in solidworks (been an autocad user for 8 yrs, finally switching over) and if i ever build one i will deff buy a pre-built flange |
03-16-2012, 01:51 AM | #4690 |
Hey guys,
In the market for a welder right now. Stuck between a Miller DVI2 and the newer 211. I plan on using it for custom car fab shit (tubs, bash bars, exhaust/intercooler piping, etc) Don't plan to do production type stuff or anything, nor does it have to be portable. I'll be using it both at home and at a shop. Now here's the deal. If I go with the DVI2, it would be a used one that my landlord is tryna sell. Don't know much about it, but he said it wasnt used a lot, and is thinking of selling it for $1000. As for the 211, I'd have to head down to Air Gas and buy a brand new one, which should be a little more than $1000. Regardless of price, which one would be a better buy? Much thanks in advance |
03-16-2012, 02:05 AM | #4691 | |
why use cosmosxpress on SW? Its just a testing thing, no where near as good as using Abaqus/Catia or some other real FEA. We used SW just for some quick things in SAE. Our FEA class and major parts went onto abaqus.
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3 |
03-16-2012, 02:06 AM | #4692 |
Why FEA it? You don't know any of the loads unless you get a DAQ. And I really doubt you'll be looking into modal analysis or stresses due to thermal loading and or impulse reactions. Karlitos is right also, SW cosmos is not that great. It doesn't even let you define your own mesh and tetrahedral is the least accurate element.
03-16-2012, 08:00 AM | #4695 | |
we use the CMM at work to gather as many data points as needed. Then plot them in Gibbs, build the parts and transfer the G Code to a CNC machine. |
03-16-2012, 01:48 PM | #4696 | |
Random google image: Also set your amps and wire feed so the weld would penetrate and would sink a tiny bit inwards or be level, but never make mountains |
03-18-2012, 07:45 PM | #4699 |
I usually find it really easy- 2 points that have a little bit of wiggle room with couplers
small complex pipes like these always kick my ass not so much the fitment and welding it is just really hard to tell a customer that I spent 3 hrs on less than a foot of piping |
03-19-2012, 12:59 PM | #4701 | |
Trader Rating: (22)
Feedback Score: 22 reviews
I'm going to switch it up a bit from all the welding pics. Here is a plastic electrical control panel I made for my s14.
Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
03-19-2012, 04:23 PM | #4702 | |
Removed the paint on the arms with 60 grit sandpaper (didn't have a grinder on hand) and prepped with alcohol... Still had popping. Guess I need to use a grinder and remove the coating on the cutouts next time. What they look like now... got another pair on the way to try again. |
03-19-2012, 05:08 PM | #4703 |
wire brush to bare metal then wipe down with non-chlorinated brake cleaner or acetone. works well for me.
edit: forgot i was logged in on my buddies account ka-titties |
03-19-2012, 05:56 PM | #4704 | |
this might help MIG WELDING - Mig welding techniques for high end metal fabrication. MIG Welding TIG Welding Tube Work Plate Work Some of my recent work on a friends car. The rear sub fram bracing Boxed in RUCA mount Rear trunk floor pan. What we put in plave of the spare tire shit pan stitch weld Rear cage mount boxes The cage I have done alot more just dont have time to post 8 pages worth of pictures lol .. Or for you premium members we have a built thread there http://zilvia.net/f/premium-member-b...u-city-az.html
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover The build http://zilvia.net/f/builds-builds-on...u-city-az.html Owner of NVS Fabrications |
03-19-2012, 07:14 PM | #4706 | |
yeah man anytime. If you have any questions shoot me a pm. Im no crazy godly welder but i did go to school for welding. That website i linked you to has alot of good info on it for people just starting off. http://www.profabricationtechniques.com/
03-21-2012, 06:10 PM | #4707 |
Designed by me, welded by my boss.
03-21-2012, 07:51 PM | #4708 | |
You're not letting off the trigger by "stopping" are you? I'm guessing you mean you're pausing? |
03-21-2012, 08:51 PM | #4710 |
It is indeed. It was quite nice, I cleaned it up a little on the inside, and ground one of the runners just a bit to get it perfectly flat. This is the prototype though, so I can't speak for the actual production units.
