#4681 |
![]() Join Date: Jul 2009
my car's not turbo, and the engine was rebuilt less than 400 miles ago, I drive it like once a week ever since it was rebuilt. it does run rich tho.
#4682 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
I like to change the oil 100 miles after break in, then 250 after than, and then at 500. Then I goto my normal routine.
#4683 |
![]() Join Date: Mar 2009
![]() Feedback Score: 8 reviews
Offset ??
I've got a set of 5Zigen FN01R-C 17x9's on my 3000GT VR4. I bought these wheels like 2 years ago before I knew much about offset. Is there a way to tell what they are just by looking for something like a sticker? I'm interested in putting the front two on my 240 and then buying two 17x10 +12s for the rear.
Thanks for the help ![]() |
#4685 | |
Trader Rating: (58)
Does google work? Google 'how to measure offset'. I could explain it, but google has pictures.
#4686 | |
Trader Rating: (58)
WIth a fresh engine, fuel certainly will seep into the oil.
#4687 |
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
when adjusting the soft/hard setting on the coilovers, should I have the wheels lifted off the ground or is it fine to just do it with the car on the ground?
#4688 | |
![]() Join Date: Dec 2010
#4689 |
You dont have to have the wheels off the ground to adjust the coilover setting.
If the prev. owner has been using PS fluid, could I mix it with ATF? It needs more fluid in there. |
#4690 |
![]() Join Date: Dec 2009
I'd recommend just flushing it and refilling it with ATF. That's what I plan on doing in a few days.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#4691 |
i changed out my shifter bearing - should i put grease on the shifter ball or no. There wasn't any when i took it off so i just poured some gear fluid...
street dancer. GLEAM |
#4692 |
small question here .. i just converted my s13 coupe into rhd..i want to do a engine swap on it but i dont want to put the sr20 no disrespect to anyone but were i live there like assholes everyones got one...i was thinking of swapping a vq35de from a 350z 6mt i wanted to know if anyone has any info on this i searched but no luck would it fit even if it rhd??
#4693 | |
![]() Join Date: Feb 2010
![]() Feedback Score: 19 reviews
Okay so I replaced the radiator and the shit is still trying to overheat. I thought it was a busted radiator since when I opened the engine bay coolant was splattered around the cap. I also got a new cap OEM from Nissan. I'm thinking the next culprit is the thermostat? But if the thermo was broken wouldn't the car take forever to warm up? It warms up fairly quickly and after awhile of driving I'd say ten minutes temps start really climbing... |
#4694 |
![]() Join Date: Dec 2003
Dude why are you not listening, REPLACE YOUR COOLANT TEMP SENSORS
That way you know you are getting the correct reading, If you replaced the radiator you should have just done the water pump and thermo at the same time
![]() **CoUpe LOve** Member #00 |
#4695 | |
But replace the temp sensor, or get a water temp gauge. While you're at it, you may as well flush out your coolant system and replace the thermostat and hoses too.
#4697 | |
depends what kinda wheels they are - usually its just a 12-point 8 or 10mm socket and a 10mm, maybe 12, for the back. BBS RS & RM Refurbishing
#4698 |
quick question, Im swapping a Ka24de in my s13. I pulled out the ka24e, now I am confused as to how to work the powersteering lines. On write ups for the swap, they say to "move the lines to driver side for the dohc set up"... okay I was looking at them and said how?. theres sensor on the lines too. If I get the chase bays ps kit for the ka24de will it solve my problem? I already have the resevoir and low pressure hoses for the ka24de but the high pressure hose is off the ka24e which is on the passenger side.. help please? sorry if its a long question.
#4699 |
My bad wakebhr thought you were talking to some other dude. I'll replace the thermostat first, forgot about the possibility of it being stuck closed. If the problem still persists coolant temperature sensor next. The water pump was replaced about ten months ago I'd say but I'm almost positive that isn't the culprit.
#4700 | |
#4703 | |
![]() Join Date: Aug 2008
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 5 reviews
changed my oil about 2 weeks ago, used the same weight as before but different brand. then while visiting a friend about 150 miles away my oil light came on. light seems dim, and flickers sometimes. has not gone out. levels are perfect, oil still looks fairly clean, new filter. stock redtop sr. wtf
*edit- small dent in oil pan. great.
#4704 |
#4706 |
Got me some tokico shocks/ struts or w.e, not sure what to call them.. they are blue, i think d-specs? Non- adjustable on the top like normal front coils... seems as if i need to use a hexagonal wrench tool to get it loosen and slamm my ride to the illest,
but i don't know how? I dont have any tools! What should i do? I used one of them big sewer wrenches but i couldnt get it loose and the steering wheel was turning when i turned it.. MY RIDEESSS FLOATINGGG 3 inches, needs some slamation, help plz. |
#4707 | ||
Trader Rating: (58)
#4708 |
![]() Join Date: Dec 2007
I'm going to install a home depot lip on my freshly painted front bumper because I've driven it less than a handful of times and already scraped my bumper twice, thus cracking the paint on the bottom edge of my bumper. I wouldn't really care if I had some replica kit but seeing as how my GP Sports front bumper has been discontinued for awhile now, I'd like to do my best in preserving it.
Is it even worth the effort? Or does it do shit all for protection? |
#4710 |
How do I align a door? My passenger side door on my S14 is a bitch to close, you have to literally slam the door. I don't want to buy new hinges, as those are quite expensive.
The car was hit right in front of the door, between the front wheel and door.... So that's probably what messed it up. I guess I'll buy door hinges if that's what it comes down too, but would there be any other way to make them aligned? The part of the door towards the read of the car seems to be too low.
