#4621 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
I tried finding just brackets, and was unable to. And a lot of shops wouldn't fab them up for me because of safety issues or whatever bs. You can get bottom mount rails from Bride and I think Recaro that bolt right up to the floor... From what I know. Someone correct me if I'm wrong.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#4622 |
![]() Join Date: Dec 2010
Hmm, im thinking if that's the case fabbing them myself sounds like less headache...ill just get my material, cut and drill mounting tabs, bolt them up, tack on the box frame to the tabs, remove, weld...sounds like an afternoon
#4623 |
yes that would be the best way make them yourself its not even difficult to do, just measure and cut everything right and it would be much cheaper too and make sure that the brackets are sturdy enough.
#4626 | |
and to beat a dead horse, Losely mount the seat rails and brackets first, so you can adjust it to your seat. Then tighten slowly each side so it sits evenly - like 2 turns each side then 2 turns each side till it's done
street dancer. GLEAM |
#4627 |
ok I've looked everywhere but couldn't find an answer to this specific problem, my idle is kinda low, when I put it in drive it drops to 450-500 and the car kinda shakes, its a ka24e single cam, timing is at 10 degrees, the problem is, when I turn the IACV, there is no response whatsoever, the rpm doesn't go up or down, what could be the cause?
i'm the kouki monster ![]() |
#4629 |
I just ordered what I think is the USDM Kouki Bumper Retainer. Ths is the part that the bumper bolts on to. Now I have a JDM Kouki bumper. It will still work......right? Right!?
#4631 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
DING DING> This is the only way to install seats IMO. With so many varianences in brackets and setas, it just works best to keep it loose, and then apply a final torque.
#4632 |
That's how I have them. I mean, I clear fine right now, but when time comes to wear a helmet, idk how I'll fit.
#4633 | ||
![]() Quote:
As for your muffler turn down question, they are great because instead of projecting soundwaves outwards through the air, the turn down aims the waves at the road, which is fairly pourous and absorbs a portion of the sound wave and reflects less back into the air than if they were projected out the back...its the best way to quiet a car without limiting performance... A lot of scca guys are going to downturns because of noise advantages |
#4634 |
![]() Join Date: Oct 2010
um on the top of every bolt that is used to mount brackets to the block theres a number or letter. on the head of the bolt. i want to know what letter or number the bolts that attach the engine mount brackets to the block have?
#4636 | |
#4637 |
I need an a/c compressor as mine has died on me. If you were going to get one, would you get a used one or a new one? If a new one, would you get it online or just at a local auto parts store? Only reason I ask the last part is the power steering pump I got from an auto parts store would not bleed the air and immediately made noise because it was bad.
#4638 | |
#4639 |
![]() Join Date: Mar 2008
I just replaced my power steering rack and hard lines (high pressure and low pressure) with new stainless steal ones. Bled the system, then re did it again to get any remaining air bubbles. Went to pull out of the driveway and the power steering pump started to wine. Lasted for about a minute and then went away. While this was happening if I was to turn the steering wheel, it feels like I am just using a manual rack. But once I got full lock in both directions the stiff feeling goes away and it acts like a normal power steering car. Thoughts?
#4640 |
![]() Join Date: Feb 2010
![]() Feedback Score: 19 reviews
Okay so I'm over heating a bit but its kinda strange to me and I don't know where to start. When I see the temp gauge start to climb I turn on the heater and it will go down but eventually it starts to climb again and it goes down again. So I leave it off and its fine but then the needle climbs AGAIN. So I turn on the heater again and its fine once again... I don't really know where to start and I don't want to just start tearing shit apart. I can only think that the thermostat is stuck or something? Water pump is good, its not leaking coolant or anything.
#4641 | |
Is your fan turning? Does the clutch modulate the fan based on temp? If either answer is no, your fan clutch is bad... How's your coolent level? When you run the car from cooled off, open the rad cap and get the car to warm up, rev from the engine bay if you have to and see if the thermostat opens up and coolent level changes...have you bled the coolent system to make sure you have it properly filled, you need to burp out all the air in the system by running the car and make sure it warms up and add coolent when the thermostat opens. The 240 likes to hide air in the system and it helps to shake the car actually haha...also make sure you fill your coolent reservoir to appropriate levels when cold...if you really are uncomfortable go pick up a thermostat, should be 170 degrees f...its only like $10 How's the oil look? When you run with the rad cap off are little bubbles coming up in the opening? Or is the oil milky? That would indicate a blown head gasket... That's what you need to check... |
#4642 | |
#4644 |
Hey guys to do my timing all i need to do is take oil pan off, that bracket under oil pan? can i get to the two bolts that hold the timing cover ? crank pulley, valve cover, two bolts in head that hold the timing cover, bolt thats on crank pulley, cams ? engine is in the bay and i DO NOT want to take it out AGAIN. thanks sr20det redtop
#4645 |
![]() Join Date: May 2010
Does the "Megan Racing SSDP-KA24 Downpipe (Non-Turbo)" Delete both the first and second cat?
Link VV Megan Racing SSDP-KA24 Downpipe Non-Turbo Thanks!
boisedrift.com |
#4646 |
JDM Kouki front bumper corner lights. How are they wired up? to the USDM corners and blinkers harness or just the USDM blinker harness. Thanks.
#4647 |
![]() Join Date: Aug 2005
What are decent pads for street/track? Current set-up is 30mm z32 front and stock rears and have Hawk HP+ and thinking of purchasing the same ones. Any recommendations?
#4648 | |
#4649 |
![]() Join Date: Nov 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Are these fouled?
![]() ![]() I can't figure out why my car won't idle right. At first it was making a "pop" like sound every few seconds, now it's more consistent, car shakes and all. I have -18~20 vac, just rewired the maf, cleaned the IACV and checked the plugs. when I try to rev it it sputters/nearly stalls till ~1500rpm then after that it revs like nothing is wrong. Only two things I have changed on the car recently was putting on a new z maf and changing the spark plugs back in July 2010, I really haven't driven the car since. Any help is appreciated. Thanks! |
