#4621 | |
![]() Join Date: Sep 2013
https://conceptzperformance.com/Cart...n.php?II=17037 |
#4623 |
speaking of fans I will share my setup. I run dual derale pusher fans PN 16925 and I haven't looked back. Each one is capable of 2,210 cfm. I won't go into the wiring in detail but I have 3 settings controlled by 3 relays inside the fuse box and each one is fused.
Speed 1 runs both fans in series (fans spin at half their max speed this way) for maintaining temp in normal driving conditions. Speed 2 runs only the passenger side fan on full blast for maintaining temp on sprinted runs. Speed 3 runs both fans in parallel (fans spin at max speed) but I've never needed to use this. Each fan speed is controlled by each relay. And each relay is controlled by an AEM v2 based on engine temperature. This way I don't have to worry about turning on switches every time I go to drive the car. This is a turn key setup. ![]() ![]() |
#4624 |
http://www.summitracing.com/int/part...6925/overview/
It isn't cheap but it makes other fans look cute |
#4625 | |
![]() Join Date: Feb 2007
#4627 | |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
![]() Due to my pilot bushing mishaps I have been hesitant about actually beating/racing on it (8.5k redline from 1st-2nd where my problem occuried). I'm currently at 372tq.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#4629 | ||
#4630 | |
*simply put when installing if I have the shifter leaning to the left it will be difficult to go into 1st/2nd or if it's leaning to the right it's difficult to get into 5th/6th/reverse.
#4631 |
![]() Join Date: Oct 2010
Throttle cable
I tried a 1995 MK4 NA supra throttle cable and it DOES NOT FIT the S14 with 2jzgte vvti fitment. It is about 1.5" too short. I don't remember where I read that the NA one will fit but it does not. Pissed at the wasted time and money. Is the TT one about 1.5" longer guys?
For measurement info, the NA MK4 supra throttle cable is 17.5" long from the cable sheath tip to the thin metal flange that bolts up to the firewire. Also, I looked up the part numbers for both the NA and TT MK4 supra throttle cables. They are the same part number. So do not expect a TT cable to fit and NA cable not to fit, or vice versa. Last edited by rswails; 12-30-2014 at 01:12 PM.. |
#4632 |
Awesome thread! Been lurking here for awhile and I'm about to embark on this journey as well.
Question how many of you guys tackled the wiring on your own and not pay for a premade harness. Btw I have a 97 kouki |
#4633 | |
![]() Join Date: Jun 2009
![]() Feedback Score: 7 reviews
How-to http://my.prostreetonline.com/2013/1...n-a-s14-240sx/ Complete Non-VVTI Aristo ECU Pinout http://wilbo666.pbworks.com/w/page/3...ngine%20Wiring |
#4634 | |
Just waiting on my R154 to come in and I'll be ready to drop this bad boy in |
#4635 | |
So far I've relocated all of the underhood fuses, relays, and the battery into the trunk, I removed the bulky annoying SMJ connector, and I wired up a Haltech PS2000 ecu. It's not difficult but a lot of people seem to screw it up, it just takes the right tools and somebody that knows wiring. |
#4636 | |
#4637 |
No build thread, my previous car was stolen and so I keep my projects on the downlow. That being said I would be happy to try to help you with any specific problems that you run into if you want to get into your wiring.
I mounted the Haltech in the glove box so that I can unplug it and close and lock the glove box as an added security measure and I was able to keep all of the underhood fuses and relays in their original location in the same plastic box they were in from under the hood -it's all just now in the trunk! It's pretty cool how it all worked out but I did run into issues and I had to revise my plan several times. I used techflex heat resistant sleeving and shrink wrap on everything and military grade teflon cable on the ignition system wired up to some LS (D585) coils. The v160 speed sensor plugs right into the Haltech and I use a dakota digital adapter to modify the abs sensor signal coming from the differential to drive the instrument cluster gauges. I mounted two mini switches on the center cluster that I use to turn on anti-lag launch control and datalogging but they can be reconfigured through the Haltech to do just about anything. |
#4638 |
Finally got it started. Runs like shit though, AEM needs some (or a lot) tuning.
https://www.youtube.com/watch?v=PCIStjzPiQQ |
#4639 | |
#4640 | |
#4641 | |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
#4642 |
not sure if this has been talked about before, but...
I was missing F59 and F60 connectors off my 2jgte vvti swap. I went to PullaPart this weeked and discovered that these connectors are the same on a 1999 Lexus RX300 ECU. Also I found the BF1,BF2, BF3 in the RX300 over in the drivers side kick panel. So i cut male side off the vehicle to plug into my swap for now. Last edited by jbjslambert; 11-17-2014 at 05:46 PM.. |
#4643 |
Cranked up my 2J vvti tonight on the shop floor with some throttle body cleaner i had laying around. Fires up right away. will start up and run tomorrow with an old fuel pump a buddy gave me so i dont have to take mine out of the car.
Anyone ever experience a whining noise coming from the throttle body? Im thinking its a ground issue from my temporary wiring setup using some household wire nuts and some jumper cables for ground. lol |
#4644 |
![]() Join Date: Sep 2010
![]() Feedback Score: 11 reviews
Still have this brand new never used Tweakd 2jzgte vvti into s13 harness for sale. My loss if your gain, $625 shipped anywhere in the u.s.
Follow me on Ig- Andydennington |
#4645 |
#4646 | |
Give us a ring if you still need a harness! We have them in stock. Ask for Chris for special black friday pricing! ![]()
Visit our Website - Check out our Blog - Like us on Facebook - Follow us on Instagram ![]() |
#4647 | |
How has no one picked this up yet??
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
#4649 |
Those of you that may have a 350z trans sitting around til install...can you measure how deep the shifter hole is in the shifter bracket? (Hole where the shifter drops in)
Shifter bracket came up missing. Making my own now. Thanks. |
#4650 |
I have a 350z worth trans currently installed in the z.can I be of some help?
