Old 03-12-2008, 09:22 PM   #421
bsilvias13
bsilvias13 has made poor choicesbsilvias13 has made poor choicesbsilvias13 has made poor choicesbsilvias13 has made poor choicesbsilvias13 has made poor choicesbsilvias13 has made poor choices
this thread is so dope its crazy. some great fab work in here.
Just for the fun of it!
bsilvias13 is offline   Reply With Quote
Old 03-12-2008, 10:27 PM   #422
sac
sac's Avatar
sac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymore
Originally Posted by fakts13 View Post
http://www.coolandquiet.com/products_detail.cfm?PID=4
First thing that came up with a google search.
that looks like it will work well. I know that gold shit works. But i dont like the look of gold in my engine bay.
thanks for posting that.. +1
sac is offline   Reply With Quote
Old 03-13-2008, 12:38 PM   #423
Swerv13
Swerv13's Avatar
Swerv13 will become famous soon enoughSwerv13 will become famous soon enoughSwerv13 will become famous soon enough
Hey guys, I found a s13 fastback for sale. its a shell on a rotisery and has already had the seams welded. I understand the work was done by a shop. I was always warned to use caution welding chassis seams for fear of warping. should i avoid this sale or can i inspect it in some way? maybe check the heat "marks" in the metal for how fast/hot/rythem of the welding?
-Erven
Swerv13 is offline   Reply With Quote
Old 03-13-2008, 01:01 PM   #424
GSXRJJordan
GSXRJJordan's Avatar
^^^ I don't think you'll be able to tell, one way or another, unless you took frame measurements. In the FSM theres measurements for everything... shock tower-shock tower, etc. If you wanted to spend 30mins in there with a tape measurer, you could put your mind at ease ~
And who doesn't like f*ckin GOLD in their engine bay?!? My god, it just screams 'this car's da bidnezzz' like a top mount manifold or a bay full of stainless lines. "I love gooooooooooooooooooolllllllllllllllllllddddddd..."
Old 03-13-2008, 01:16 PM   #425
Healtoeae86
Healtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really nice
[QUOTE=driftstyre;1882440]Thanks Jordan!
C&R makes the gold and silver foil that HRP sells. The gold is good but the Silver is a lot better for heat reflection. It is cheaper, a little more weight, but thicker and the adhesive used is better as well (less "stiff" and adheres to contours much better). I have had the firewall lined on the outside and inside with gold foil for two years, but there is only so much it will reflect. I honestly think it is better for hoods, airboxes etc, that can't really absorb much heat. I got some silver to cover the firewall "more better"(I've always wanted to say that)
Bill your right, I did my whole firewall and exhaust underside under drivers side feet area as well as covered the oem heatshields in all the gold foil stuff. I think the fiberglass backed stuff should work a lot better. Im still getting my feet hot while at crusing speeds...The fiberglass backed stuff should work A LOT better.
Healtoeae86 is offline   Reply With Quote
Old 03-21-2008, 08:39 AM   #426
Jakob
Jakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to all
i am trying to teach myself how to weld, so is it possible that i post a pic of some welds and you tell me what i do wrong or what i can do better?
here are the pics:
and the backside:
edit: oh yea it's 1.2mm stainless steel
2nd edit: thats mig welded
Jakob is offline   Reply With Quote
Old 03-21-2008, 09:16 AM   #427
fakts13
fakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nicefakts13 is just really nice
can't find my glasses right now, but is that mig or tig?? if tig, you're going too hot and WAY too much filler. start low on your amps and increase as necessary to maintain a decent weld puddle. if fitment is perfect, no filler is required and you can just fuse them. try to only have 90% penetration to keep contamination from the back of the weld down. i would try starting at 40 amps, smallest tungsten you have ground down to a SHARP point, and use .030 or .035 filler (unless you have access to smaller).
fakts13 is offline   Reply With Quote
Old 03-21-2008, 11:25 AM   #428
Jakob
that was mig welded. but im planning to buy a tig welder soon. thank you for your reply!
Old 03-21-2008, 01:20 PM   #429
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
if you post what types of settings and welder setup it will be easier to give you more direction. the weld technique is a pretty good start. but yeah needs less heat and less filler.
lazierhobo is offline   Reply With Quote
Old 03-21-2008, 02:30 PM   #430
Jakob
the welder itself is a cheap unit, so i cant really adjust the settings. there are 2 switches i have put them both at the lowest setting (you can switch from 1 to 2 and from min to max) i had them at min and 1. the filler adjuster is a scale from 1 to 10 i had it between 3 and 4. i used 1mm thick filler. its a mig welder and i used argon with co2
Old 03-21-2008, 07:04 PM   #431
BlackTopBomber
BlackTopBomber's Avatar
BlackTopBomber is making a name for him/her selfBlackTopBomber is making a name for him/her selfBlackTopBomber is making a name for him/her self
this thread is awesome! i love it. got a few questions for some of you. i am looking at getting a new welding rig. i really don't need anything crazy or fancy, just something with all around abilities. its going to be a descent mig set up. so far i have been looking at the century 140gs or the hobart 210. any input would be appreciated on if this is a quality set up. i pretty much plan on using it for chassis/cage work, and probally exhaust and sheet metal work.
BlackTopBomber is offline   Reply With Quote
Old 03-22-2008, 06:02 PM   #432
Swerv13
Swerv13's Avatar
This is a great book, and well worth the $20 it costs. "Performance Welding Handbook" You can find em in many bookstores and ofcourse online.
-Erven
Old 03-22-2008, 07:28 PM   #433
steve_o1989
steve_o1989's Avatar
steve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond repute
here are the pics:
and the backside:
It's hard welding thin metal, especially if you have minimum control over your heat. Also, when you are welding such tin metal, it is best to use a series of tack welds because you don't want to put too much heat into the metal as is will warp. The weld technique looks good though. Beads look fairly consistent. I would say good for a beginner. And the uber penetration is because of running too hot aswell.
Go and get some thicker metal, probably about 1/8" would be good, and just practice running beads on it. When you start getting better, move on to butt welds, corner welds, tee welds, lap welds, edge welds just to get used to welding different joints. After that you can try the same welds in different positions (vertical, horizontal, overhead if you want)
Looks like you're off the a good start though. Keep at it.
Steve
1997 240sx SE
1998 Frontier SE
1990 240sx Coupe - Sold
1992 Talon Tsi - Sold
steve_o1989 is offline   Reply With Quote
Old 03-23-2008, 01:09 AM   #434
DisEpyon
DisEpyon's Avatar
DisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to behold
Send a message via AIM to DisEpyon
hey guys,
well i finally got around to do some practicing today on cast aluminum.
I felt like chopping up a honda manifold (not sure which motor it was for, but it was for scrap) and welding it back together.
Here it is when it was one piece
here are the runners i chopped off one by one
Then of coarse it needs to be cleaned, i used this 2 year old purple power that was sitting around in my garage for ever, i swear this stuff works like magic
all the pieces cleaned inside and out where the area of welding will be
Then it was time for beveling each edge
here are the welds i did for the flange to runners, I tried tack everything up with the manifold and runners and flange, but dam it was getting annoying trying to hold everything and using stuff to hold it, then you realize a tack broke and you go back to fix it and another one breaks, while your trying to align the holes, it just turned into one big mess, so i said f**k it, ill just weld the runners and flange first, i mean after all its just practice. i brushed with stainless steel brush first, then welded.
Not the best looking but i think im getting better, here are some pics i did months ago for cast aluminum, this was the last time i practiced on cast aluminum. Just some stringer beads, and FYI these pieces of cast aluminum is from nissan, belonged to a rb26 oil pan. seems like the aluminum from honda is easier to weld on then the aluminum from nissan, oh well i dont know...
took longer to prepare than to weld, was the only time consuming part.
DisEpyon is offline   Reply With Quote
Old 03-23-2008, 04:05 AM   #435
Jakob
that's tig welded right? those welds look awesome
Old 03-23-2008, 10:42 AM   #436
sac
sac's Avatar
^^i am not a expert, but i am pretty sure tig is the only way to PROPERLY weld aluminum
haha.. weld that bitch back up and sell it.. you could probably get some stupid fuck to pay ya 100 for it sayin its "custom". haha
Old 03-23-2008, 11:01 AM   #437
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
referring to that.. it seems like you dont have anybeads and your getting close to getting it too hot. and like everyone else said that metal is thin..and extremly hard to weld, basically if your doing that, have really fast hands ha.
but it looks okay just no beads.so you can "zig-zag",or try and make your wrist circle fast.
good job on welding on that thing stuff though ha
here are the pics:
and the backside:
This image has been resized. Click this bar to view the full image. The original image is sized 800x534 and weights 50KB.
HS13KLS is offline   Reply With Quote
Old 03-23-2008, 11:58 AM   #438
DisEpyon
DisEpyon's Avatar
yes it is tig, i forgot to say what process i used. thanks, i am planning on welding the manifold to the runners today.
hehe, i was thinking the same thing, some one might buy it just because it looks custom with the welds on it.
Old 03-23-2008, 12:50 PM   #439
Xracer
Xracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to behold
Send a message via AIM to Xracer
DisEpyon: Very nice welds, i know cast is difficult but you definatly make it look good. I wish i could weld aluminum like that. I need to build my intake manifold soon.
R34 NEO POWER
Xracer is offline   Reply With Quote
Old 03-23-2008, 02:27 PM   #440
blu808
blu808's Avatar
Dis: very nice welds. What machine are you using?
Old 03-23-2008, 03:18 PM   #441
DisEpyon
DisEpyon's Avatar
thanks, cast can be easy if you make it easy, the key thing to it is clean clean clean!! its ok to be over compulsive about cleaness, what ive been told anyways what is the manifold you are going to make going to go on, and the plans for it too?
thanks, the machine i am using is a lincoln precision tig 225
a pic when it was new
Old 03-23-2008, 05:42 PM   #442
blu808
blu808's Avatar
Haha. We have the same welder pretty much. Mine is the older 185. I use mine everyday and have no problems with it for 3 years. Great machines.
Heres mine when new.
Old 03-23-2008, 10:15 PM   #443
HS13KLS
GEEZ that welder...wow...
smells like a lot of money. ha.
Old 03-23-2008, 11:31 PM   #444
DisEpyon
DisEpyon's Avatar
here is something i made for my car awhile back, its a breather ventilation tank or what ever you want to call it.
sorry i dont have any before pics, just the finish product.
so far i dont have any problems yet, car runs good, and still havent loss alot/any of oil, what the dip stick is reading anyways.
Old 03-24-2008, 12:32 AM   #445
blu808
blu808's Avatar
o shit that breather tank is amazing. Any specs on the material and machine settings? it looks as if you oversized the pieces to be welded together, then just fuzed everything with no filler. that is what I do sometimes when I want really small even beads.
Old 03-24-2008, 12:51 AM   #446
slw240sx
slw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant future
Send a message via AIM to slw240sx
here are a few of the wheels tubs i had shown in the build stages earlier in this thread.
some of the progress just so you dont have to go back pages
Don't mind those seam welds, they are not mine, the owner of the car did those. you can also see where someone had cut the fender supports in half, the whole nose of this car has been chopped off and replaced due to a wreck, i got it pretty close to straight again after the hack job a body shop had done, but its still fits fenders and the hood wierd.
http://www.forcedfabllc.com/
slw240sx is offline   Reply With Quote
Old 03-24-2008, 02:22 AM   #447
sac
sac's Avatar
Originally Posted by slw240sx View Post
^^ haha is that a bottle of anal lube i see sitting near the LF strut tower?HAHA. COMICAL!
Old 03-24-2008, 12:15 PM   #448
driftstyre
driftstyre's Avatar
driftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond repute
Send a message via AIM to driftstyre
Just a few updates. Been working on the front end, and am confident about the way it is working out now. Its far from completion but will hold the intercooler, oil cooler and most importantly, house the four mounting points for the splitter bird cage.
driftstyre is offline   Reply With Quote
Old 03-24-2008, 02:00 PM   #449
DisEpyon
DisEpyon's Avatar
the material is 1/8 aluminum plating, welded with 3/32 5356 aluminum rod, the machine was set around 145 amps (i set all my aluminum working high like that so i can control a wide range of heat) didnt use pulse or post flow and i dont remember where i had my ac balance at, somewhere between cleaning and penetration, most likely a little more on the cleaning side.
i fitted the plates with a corner joint, like in example c in the picture, then grinded the edges a tad bit to help give it a bevel
I have a question for those of you that weld on stainless steel alot,
how are you guys setting up your back purge system? details or pics would be nice. my brother bought some sch 10 manifold tubing material for me to practice on and im having a little trouble as to how to hook one up. Ive heard people using a seperate cylinder, or hooking up a y splitter some where on there machine or cylinder and running a hose off one end.
Old 03-24-2008, 09:49 PM   #450
wannabe_drifter
wannabe_drifter's Avatar
wannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to behold
driftstyre: Is that some ITBs that I see on that SR20DET ??? That looks real nice !
http://i123.photobucket.com/albums/o308/two40/Mine/CoupeSte-Croix.jpg
wannabe_drifter is offline   Reply With Quote
