#4322 |
Nice before and after shots. Lookin good. Do you have their fronts as well?
I saw PBM just ran out of the rear knuckles... wonder if they'll make any revisions on the next batch. Here's one comparing PBM with the Driftworks... you can see everything is a bit lower on the DW knucks ![]() |
#4323 |
![]() Join Date: Jan 2006
ya i had the max weld on kit for a few years and this year switched to the PRO knuckle. feels so smooth with the RC correction. excited to see what kind of difference these rear will make
#4325 |
IIRC, the theory is that if you use PBM's entire line of RC correction stuff you get about the same amount of correction as DW. I think the Subframe Risers are good for 15-20mm, the LCA's good for another 5mm and then the drop knuckle is 25mm. Added together, you're in the 45-50mm correction range which is the DW setup.
Which, looking at the DW setup, it seems like the arms are in the same position relative to the wheel as PBM.... Did they just move everything up 25mm and then drop the LCA mount? Seems like they cheated a bit.... |
#4326 |
![]() Join Date: Sep 2008
I like the fact that you can use the z32/q45 ebrake with the DW knuckles, not to mention if you pair the DW knuckles with only the PBM risers it should be awesome.
I however don't like how the DW fronts you have to use s14 wheel bearings, I dont want to ditch my j30/s13 bearings.
WTB: 1(one) battle version toe rod
-Mike |
#4327 | |
Any part numbers? Does anyone know where parts shop max gets their bearings? I would like to do something like this to my lcas.
#4328 |
Dunno but the DW knuckles were a bitch to fit in the rear because the arms are so close to the axles. The swept Cusco RUCAs I had hit the axles pretty bad if at a decent ride height. I tried the Isis RUCAs which are a flat design and it was better but still not what I wanted. The traction rod bracket can also hit the axles and it's hard to find coils that will work since you need to raise the car 2" and most coilovers won't go that high in the rear.
The PBM knuckles have more clearance there so it isn't much of an issue and you can use pretty much any coilover with them since it's only 1". Also everyone says the z32 E-brake sucks with DW knuckles since you need to flip the assemblies and the Z32 rear brake setup is pretty heavy (you gain about 6lbs with just the rotors/calipers) PBM will likely have the same weak e-brake issue if they allow Z32 E-brakes with their rear knuckles since the only way to get them to work on a drop knuckle is to flip the assemblies. |
#4329 |
![]() Join Date: Nov 2005
Yeah most people don't need as much rear correction as the DW provide, especially if they're using subframe risers. PSM's have spherical bearings, which in my opinion outweighs the added drop of the DW's anyway. Also, they're cheaper.
PSM makes all their own bearings btw.
#4330 |
![]() Join Date: Mar 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
How much adjustment do those modded oem arms even give you? Especially since the tension rod is bolted outward of the adjustment, it's not gonna move very far.
#4331 |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
So Driftworks rear knuckles do provide what they say 45mm change compared to stock.
Time to make some for my own car then, thanks a lot for the comparison picture az_240 Useful info for everyone when choosing which to buy |
#4332 |
So i'm thinking about getting my flca's extended 1.5" and my knuckles modded. A friend of mine that builds longtravel kits for prerunners said he can do the arms and knuckles no problem. The arms are easy to do, but I don't know exactly what to tell him to do when he starts on the knuckles? Should I start out by just getting rid of the ackerman and the length of the tie rod mount at first and see how I like it?
edit- My steering rack is already moved 50mm forward and I have pbm rod spacers and a spacer on the passenger side of the rack like George sells. |
#4333 |
#4339 |
So now wisefab has a kit for supra including rear knuckle and wishbones:
Wisefab introduction of Supra/Soarer kit by Fredric Aasbo on Vimeo With aasbo commentating and driving, looks neat ![]() |
#4340 | |
But again, a wisefab car without front fenders? Is there a reason for it? Or are they incapable of engineering a kit that allows for use of a fender? Why not just cut the front fenders where the wheel hits? I don't get it.... |
#4343 |
I've been reading thorugh this thread for weeks, we've done a few modifications to the car:
-Cut and dropped arm on the knuckle -S14 FLCA - Ikeya Formula Tie rods That's about it so far, i still rub the frame rail under full lock so we put bump stops in to make sure i dont get there. ![]()
#4345 |
Can anyone post pics of s13 with s14 lower control arm, i hear they are about an inch longer, but I have poke with stock arms already, now imagine if I had wisefab +60mm control arms
#4349 | |
![]() 12mm...we measured
