06-18-2012, 04:03 PM | #4291 |
i recently got done with my LCA/knuckle combo (based on Def's how-to). i used knuckles which were professionally cut and TIG'd for greater steering angle. i drilled out the knuckle to 3/4" and used shims totalling ≈1.7" (≈42mm) of roll center correction. i also drilled out the tie rod pickup point to 5/8" to use a heim joint and fine tune it's drop down distance (aka bumpsteer correction) with various collars and washers. the final product looks nice and made LOTS of angle compared to stock.
the only down side is the shorter pickup point on the knuckle gives less steering leverage, making it very hard for me to steer without power steering. sooooo i converted back to stock LCAs and knuckles for the time being. i may convert back to power steering later, we'll see. in the meantime, if someone wants to buy this setup (modded LCA's, modded s13 knuckles, outer tie rods, and all the nuts/bolts/spacers/shims/etc), PM me. i'd consider selling it all as a complete bolt-in setup and just sticking with the simplicity of my stock stuff for now. i wish i had taken a pic when everything was installed. lotsss of angle! haha
06-19-2012, 02:03 AM | #4292 |
Wow they dont even look modified!
I dont get overcentering right now because it is running stock caster but I do need to relocate the steering rack because it will definately overcenter once I have solved the clearence issues The s14 has longer lower control arms so it should also have longer tie rods, but they could have just made outer ones longer too |
06-19-2012, 06:27 PM | #4294 | |
Trader Rating: (29)
Feedback Score: 29 reviews
Bottom is S14 |
06-19-2012, 09:27 PM | #4295 | |
While the shorter pickup probably did make steering a bit more difficult, if you ran a lot of negative camber thanks to those adjustable LCA's, that may have been the main culprit. |
06-19-2012, 09:46 PM | #4296 |
^ i tried driving around with the LCAs adjusted to roughly s14ish length. not crazy amounts of camber and toe was zeroed out. simply too hard to turn a tight corner without that leverage on the knuckle and without power steering to assist.
06-20-2012, 01:59 AM | #4298 |
I installed inner tie rods from that of Nissan Maxima A32, they are the same as I30. They are much longer than X-trail ones but still I have 10mm of thread engagement so I am planning to fit a rack spacer. Have any of you had problems with offset rack spacers? Removing the front crossmember seems a bit pain
I also adjusted my camber plates to max negative camber with min. caster ( rotated them toward inside), tyre looks quite flat on the ground Last edited by Motary; 06-20-2012 at 03:53 AM.. |
06-20-2012, 02:50 AM | #4299 |
06-20-2012, 10:24 AM | #4300 | |
[SIGPIC][/SIGPIC] |
06-21-2012, 06:23 AM | #4301 |
It was a question of time which I didnt have. I am moving my car home back to my personal workshop, keeping it with me in the city is useless because the garage is about half a meter of space to both sides lol
Adding a spacer will also increase rack travel but I have to make a custom lower control arm and I am unsure how to proceed. Picture of ride height and arm position: Before: After: Maybe make an arm like Nigel's Last edited by Motary; 06-21-2012 at 07:04 AM.. |
06-21-2012, 08:33 AM | #4302 |
Trader Rating: (131)
Feedback Score: 131 reviews
Alright, so here's the scoop. I installed Megan Racing roll center adjusters all around on my car a while back, basically just as a replacement for the ball joints (since I know that they do nothing to actually correct roll center.) I've decided to do something about that, and purchased some Ikeya Formula front LCAs for the car to help with the roll center and keeping the arms level to the ground.
I had hoped to score a set of Ikeya Formula RLCA, but I lost out on that deal. I am now in the market for some PBM RLCAs to correct roll center, but for another reason as well. My rear wheels that I recently had rebuilt are a bit too aggressive for my tastes, so I am planning to have the back pad shaved down 5mm to get closer to the look I want. However, I am not sure that will be enough. I emailed PBM and found that the track width with their arms can be adjusted up to 10% in from stock (7mm), or up to 90% out (wider) from stock. If I were to adjust my rear track width inward 7mm with these arms, this would reduce the rear camber I have to run to clear the fender, correct? I found a similar situation on Joel of C's Garage's car, where they shortened his RLCA to remove some negative camber: My other question is: I need to run different tie rod ends, such as SPL, in addtion to the Ikeya FLCA that adjust roll center, correct? Appreciate any insight- I've done my research and am in the process of doing some more, but I would love to hear some experienced opinions. |
06-21-2012, 09:31 AM | #4304 |
Motary, what kind of joint is Nigel using on the front LCA where the tension rod bolts to it?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
06-21-2012, 10:17 AM | #4305 | |
06-21-2012, 10:25 AM | #4306 | |
Though, the arms do come with a little (5mm?) spacer to correct a bit. |
06-21-2012, 10:47 PM | #4307 |
Trader Rating: (115)
Feedback Score: 115 reviews
What benefit would there be to a narrower rear track besides fitting wheels? How would that effect the suspension's travel? I heard a rumor that some of the top level guys have their rear track narrower than stock and I can't wrap my head around why that would be better.
06-22-2012, 01:18 AM | #4308 |
It mainly has to do with how narrow the rear track is in proportion to how wide the front is, I believe. I know I have read an article a long time ago claiming that the narrower the rear track, the better the car will drift. Unfortunately I do not remember any of the technical explanations, just said conclusion.
That is why more and more drift cars are looking like this. |
06-22-2012, 06:45 AM | #4309 |
I would think that have a smaller rear track would help the car to swing around.
It should be the same as it is on road racing applications. great front track helps to rotate the car, so maybe they are using that instead of adding rear toe in. ex b: more mechanical grip, so you dont have to run as big of a tire up front (i believe) |
06-22-2012, 08:35 AM | #4310 | |
Regardless, I have decided to just have the wheels modified for now, and not mess with the rear lower arm at this time. Appreciate the info and insight guys- lots of great info in here. |
06-22-2012, 08:47 AM | #4311 |
That initiation was so weird. I can't tell if he just under-steered a ton or what, looks like his car is setup really awkwardly.
06-22-2012, 10:36 AM | #4312 | ||||
Shortening the rear lower arms helps with dynamic camber change a little as well, at least if you don't have much roll center correction. Quote:
Also, his steering is probably so quick that he can turn the wheel that far in with a flick of the wrist probably. Definitely looks cool, hahah. Like I said above, it's all in what you want the car to do.
06-22-2012, 07:24 PM | #4313 |
That looks like a shallow faint initiation. I see it all the time here in Japan. Especially in street drifting where the roads are narrow. That shit looks Boss to me.
06-22-2012, 07:50 PM | #4314 |
Trader Rating: (18)
Feedback Score: 18 reviews
I think it has a lot to do with his narrow ass tires and toe out. Probably running such narrow wheels and tires and spaced so far out to get that much angle.
06-27-2012, 04:05 PM | #4315 |
ok so, i'm going to get an alignment
i have D-max coil overs,extended LCAs,maxima/i35 tie rods,and PBM SAK im going to use my coils to adjust caster and the LCAs to set camber, its mainly a drift car,with little street use,any tips on how should i set my caster,camber and toe thx |
06-27-2012, 04:14 PM | #4316 | |
I think what messed my head up was the bit of understeer on turn in combined with the amount of body roll he had. I'm used to cars that are way stiffer than that. That car really make me want to reconsider my whole love of wide wheels up front, that thing looks like it has a tonne of angle and probably just has hammered fenderwells. |
06-29-2012, 05:45 AM | #4317 |
by the way, Poorman, do you sometimes update the front page? It would be quite beneficial to make a list of mods to improve roll centers, camber curves and max steering locks and perhaps use my graph of rc mod effectiveness so people would know how to improve their suspension spending a reasonable amount of money
06-29-2012, 06:44 AM | #4318 |
Yes, I really need to edit the first two posts. The info is quite outdated now. I'll try and get around to that next week when I have a few days off.
06-29-2012, 08:10 AM | #4319 |
Does anyone have some spare bumper steer correction endlinks for sale?
looking to replace the ones on my hatch, but oem stuff wont cut it for more than 3-4 months |
06-30-2012, 07:45 PM | #4320 | |
