08-18-2014, 05:11 PM | #4262 |
Yes sir, Also if it's not too much trouble could you get a pic of your alternator setup? Thanks.
08-19-2014, 09:31 AM | #4263 |
decided to just dive into the car last night, started going from the alternator connector and working my way back, noticed the IG wire was broken (Middle Wire on the oval plug) Looked at the diagrams that shows that goes to a switched 12V. so i ran a temp wire to test it, and poof working alternator! Thanks again for any help!
08-20-2014, 11:06 AM | #4267 | |
Daily: '99 Pontiac Trans Am. Projects: '96 S14, '87 Merkur XR4Ti |
08-20-2014, 01:44 PM | #4268 |
Has anybody had any luck with the stock front sway bar? I know about the Sikky and the spacers, but are there any other alternatives? Also, where do you get spacers? I'm getting ready to drop everything in and want to make sure I have that squared away.
08-20-2014, 02:07 PM | #4269 |
Which swap kit are you using? People have varied success depending on what brackets they have for the motor mounts. I have a ZeroLift kit, and I'm not 100% sure my stock sway bar will fit without spacers or anything, but I'm optimistic.
08-20-2014, 02:10 PM | #4270 | |
They are the basic eBay mounts in a S14. |
08-20-2014, 02:24 PM | #4272 |
Stock sway bar won't fit at all with any mount kit unless you have spacers, silky, or one of the skyline sway bars if memory serve me right.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
08-20-2014, 03:15 PM | #4276 |
yep, makes the sikky seem okay. i actually just placed an order for a front sikky lol if i were you id just do the same
follow my build on instagram: s14project |
08-20-2014, 08:53 PM | #4285 |
Trader Rating: (18)
Feedback Score: 18 reviews
So your hood didn't close with freed mounts and the stock sway bar? No disrespect, just trying to decipher whatever you said. Thanks
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
08-20-2014, 09:22 PM | #4286 |
soo.. How hard would it be to wire a mk4 instrument cluster into an s13?
Would the gauges work tach, speedo, gas, etc? I've searched but, no luck on any info. |
08-20-2014, 11:14 PM | #4287 | |
The clearance to the subframe is perfect I couldn't ask for tighter lol |
08-20-2014, 11:17 PM | #4288 |
any thing is possible but Seems like a hassle for something that wont fit well, the mk4 cluster is flush mount and uses the dash as a bezel I would just order phr gauges without the cluster
08-20-2014, 11:19 PM | #4289 | |
