#4231 |
![]() Join Date: Apr 2007
My Ikeya Formula tie rods weren't long enough. I made some spacers with KA cam gear bolts and Moog outer tie rod jam nuts.
#4233 |
That's how I extended my stock tie rods when i extended my control arms. But I didn't want to weld to my shiny new tie rods. New knuckles. And I raised the front of my car almost an inch. I haven't been able to drive it angrily yet.
![]() P.S. Is angrily even a real word?
#4239 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Last time I checked he sold out and was trying to find another place to machine them cause who he was using wanted to up the price. IDK if he found someone or worked something out. But if he is making them again I'm down for a pair.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
#4240 |
![]() Join Date: Jan 2006
Cor integration makes those spacers. With the slip on spacer on the I30 inners you koose about 5 threads compared to the teins. There is still a decent amount of.thread left over to fo.into the rack
#4241 | |
![]() ![]() Mine were too short from the moment i bought them. I have dw geomaster knuckles and homemade lcas. IIRC the lca is 390-400mm which is somewhere around 35-40mm longer than stock. Iam running 245;40;17 ad08 so as soon as i can drop back too a 215 ill be able to shorten the arms by 15-20mm ish ![]()
[SIGPIC][/SIGPIC] |
#4242 | ||
Nigel Petrie of Engineered Too Slide Quote:
[SIGPIC][/SIGPIC] |
#4243 | |
Kinda forgot about those. On my car, the tentative plan is to use offset rack spacers, only lenghten the control arms 25mm, and chop the knuckles to ~4" even. Until then, we are going to install the knuckles that came off his car. |
#4244 |
Sorry guys I haven't been making those in a while. My machine shop raised the prices on me and I haven't been making them since.
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all |
#4245 |
I just realised what you have REALLY done with these knuckles
![]() You flipped the centre upside down like dw geomaster knuckle. 1.Iam guessing you made jigs?? 2.Did you copy geomaster geometry? 3.Also the subframe up there ^^^ Any worry about flexing or anything, its pretty thinned out in places, i want to copy ![]() 4.Did you modify the chssis rails on the car to regain some clearance for the camber arms and camber arm brackets? 5.You raised it 30mm right, is that 12mm or so removing the bush and another 18mm cut away from the frame? ![]() ![]()
[SIGPIC][/SIGPIC] |
#4246 | |
![]() Join Date: Apr 2009
alignment was 3.6* camber 1/8th toe out. 7.2 caster level control arms wheels were 18x 9.5 -5 |
#4247 |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
1) Jigs to hold them in place yup
2) Geomasters raise bearing 25mm, these raise it 40mm, so no, these are better ![]() 3)If you are worried about flexing, you can add material to the otherside where you come some off. I'd personally make a new frame since this mod was very time consuming and if you're allowed to do this in a drift series, a custom frame could be legal too, for an engineer like you it should not be a problem ![]() 4)Chassis rails were not modified 5) It was raised 40mm, 12mm from bushings and 28 cut off, for more detail about this you can google 'engineered to slide cradle' About the Xtrail ones, I installed my them on my s13 without any issues, they are with M14x1.5 outer tie rod end thread and M16x1.5 inner like S14 ones and they are 20mm longer than stock s13 ones. Last edited by Motary; 06-13-2012 at 02:10 AM.. |
#4248 | |
![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
#4249 | |
3. I think your right. I need to make my own frame and my own rear knuckles. I have been looking alot at the japspeed and engineered to slide tubular frames. I need to pull my finger out and get on with it ![]() 4. Awesome. Just confused cose on engineered to slide s13 he has. But i think his is more extreme. 5. Awesome thanks ![]()
[SIGPIC][/SIGPIC] |
#4250 |
agreeed,...motary, stuff looks great
:thumbsup:
cONtRol FReAkS |
#4251 |
Yeah ETS Nigel raised his subframe 55mm, my idea for making new knuckles for the rear would be removing bearings/bushings and making 'ears' like the subframe and use male rod ends has
![]() Food for thought: excessive caster, yet car and driver are very successful ![]() HGK racing lock kit for e46.. ![]() ![]() |
#4252 | |
![]() when your going backwards the steering is useless. you NEED a higher grip level on the rear. if the front tyres are flat and making maximum contact patch giving more grip than the rear, then the car will just carry on looping round into a spin. maximum front grip is for fast bends, twinning ect mega amounts of lock is only usefull for massive entries in my opinion I defo prefered trying to going backwards with excessive camber gain, feels poop with flat contact patch I agree with the use of rose joints at the knuckle end of the arms. cheaper and stronger too make. probably easier too. My mate is coming over later and he is a solidworks genius so we will bash something out and see what we think. I have also got access to a pipe bender and a qualified welder. I have my own lathe and work in a cnc factory so shouldnt be too much trouble ![]() EDIT: 55mm ![]()
[SIGPIC][/SIGPIC] Last edited by swiftmini; 06-13-2012 at 11:31 AM.. |
#4253 |
It looks like the anti squat was not adjusted, for my own subframe I have S14 spec and lowest hole for spec that makes upper arms parallel with lower control arm.
I would also think that lots of understeer would help cars with big reverse entries, but then reverse ackermann and flat front wheels were added to the market making it so confusing. I just noticed before posting this we have same amount of posts lol |
#4254 |
![]() Join Date: Nov 2005
Very interesting discussion you have going here.
Do you guys really think that much correction is necessary in the rear? The front roll center drops MUCH faster than the front, and raising the rear too far above the front is going to give you some crazy understeer, as the roll axis vs mass axis angle is going to be way different. Also, you are going to gain a TON of anti-squat doing that. You'll definitely need to change the lower arm angle.
#4255 |
The car where I performed such extreme mods had rc height of -300mm in the rear, the car is ridicilously low, rim tuck with 17 inch wheel
![]() For us who don't follow rules correcting front geometry is easy by raising chassis points, heim jointed arms are very thin compared to oem bushings and using offset rack spacers to avoid bumpsteer |
#4256 | ||
Ackerman adjustment is also very good though. i find that my car can drift on a much bigger angle and at much higher speed. At the track if i decide that the front needs too be slowed down or sped up i just adjust my front toe slightly. When i drift my mx5 i have too change my style od driving alot. its only about 100hp and is slammed on cheap coilies with a cusco diff and 7mm lock spacers. i have too keep momentum up and also need as much front grip as possible so i can get speed up before is start drifitng. the s13 has enough power to just drive any old fashion ![]() Everything i write is just my opinion it all comes down to personal preference and style. Iam sure guys like wisefab are doing what they need for theyre style of driving or competitions ect. Quote:
I do intend on alot more front correction though, before i do anything at the back. I want to move the front crossmember upward atleast by 30mm ![]()
[SIGPIC][/SIGPIC] |
#4257 |
Check out my rear wheel moving about in this video. its an old video. This is a contribution of bump, droop, roll, slammed car, standard traction rods, standard knuckles and s14 frame. Basically just poo!
swiftmini pembrey filler cap view.mpeg - YouTube So if you could move the frame far enough too restore the angles ect to theyre factoryish settings. would the benefits of a better controlled dynamic wheel geometry, outweigh the negatives of upsetting the roll centres, roll axis Vs mass axis? And here is an incar video, just for reference that shows my current setup. Please be gentle because its my first go on a fast track and the conditions were terrible, pretty down slippery but it was awesome fun. My car has perfect power to grip ratio in the wet ![]() ![]() ![]() https://vimeo.com/43386900 geomasters flush rear frame my home brew flcas ect -7* front camber ![]() 7* caster rb25 @320hp
[SIGPIC][/SIGPIC] |
#4258 | |
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Steps: Center wheel in wheel well using tension rod Rotate top hats Use top hat adjustment for Caster adjustment. Sound good?
![]() ![]() Friends help you move. Real friends help you move bodies. |
#4259 |
well it depends if you want more camber or less camber. pointing in will give more camber, pointing out will give less camber
[SIGPIC][/SIGPIC] Last edited by swiftmini; 06-15-2012 at 07:57 AM.. |
#4260 |
tubular subframe inspiration/pawn
rear ![]() http://a3.sphotos.ak.fbcdn.net/hphot..._2705617_n.jpg front ![]() ![]() i think its relative ![]() Ps Trela runs his own design knuckles on the s13.5 ^^^ and has mid mounted jz and has semi space framed rear end i believe ![]()
[SIGPIC][/SIGPIC] Last edited by swiftmini; 06-15-2012 at 07:31 AM.. |
