#4051 | |
![]() Join Date: Nov 2005
I've seen guys with 25mm extensions running 7 degrees of camber, so unless you want that much, I'd stick with 15mm.
#4052 |
![]() Join Date: Jun 2004
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
I know it would be a simple bracket but as common as z32 rear brakes are and the fact that you are buying knuckles that have brackets for the 2nd caliper already seems silly to have to make another bracket but if that's what has to be done. May be the difference in buying these or dw/era1 because you can keep the z32 ebrake on those.
#4054 | |
To help fix this I sent my e-brake shoes to Porterfield to have them relined with their new RD-4 race compound. Way cheaper than Project Mu shoes and should be a better compound. I should get them back next week. If I still can't get the wheels to lock with minimal effort I may just go with PBM/hydro. Also it's hard to find coils that will even work with these dw knuckles in the rear for s14. S14 dw rear coils go to 70cm so that gives you an idea of how tall the coils need to be. Axle boots can also be a problem depending on what ruca/traction arms you have and how low you are. I noticed my friends s13 axle boots are smaller than my s14 boots so might have to trade him |
#4055 |
Trader Rating: (18)
^ thanks for the info keep me posted I've never had a problem with stock pads on z32 ebrake but it makes sense that it doesn't work as well as stock after it's flipped.
The thing for me is it's for my street car with full interior and a hydro wont look as clean as a stock ebrake. I don't mind running a line lock for ebrake but I haven't seen any clean hydro setups with full interior and center console. Mounting it under the radio would be fine but I have a double din nav so it's like trying to cram 10lbs of shit in a 5lb bag. |
#4057 | |
#4060 | ||
Seems like it might almost be worth buying the PBM rears at $400 then cutting off the brake caliper mounting points and running George's dual Z32 bracket for an additional $270 or whatever it is. Comes out to be $670 for a dual caliper rear, which is still cheaper than ERA-1 or DW... Might take this route. |
#4062 | |
Secondly, you can't find a machinist to make you two brackets for less than $270? And you want to run two anchor weight calipers back there? Make the bracket, run a wilwood. No sense in doing it more expensive and heavier.
#4063 |
![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
Hey guys, we haven't posted on here for a few years now however you'll be seeing more of us in the near future once we've got our distribution center setup in the States.
The reason for my post is to ask your opinions on a design for a billet 7075-T6 aluminium knuckle that we're working on. At this stage here is where the design is at: - body and mounts to be machined from billet 7075-T6 aluminium, spindle material to be 35CrMn (TBC pending FEA tests) - All threads going into main unit to have threaded inserts - Direct bolt on design for S13, S14 and S15's (provision for both 12mm and 14mm knuckle to strut mount, provision for different taper for LCA ball joint, and 2 different spindle sizes to suit either S13 or S14/S15) - 40mm drop spindle - As the design currently sits (still needs to be run through the FEA and optimized) currently weighs in at 2.1kg's. The stock S13 unit weighs 3.3kg's, stock S14/S15 unit weighs 3.8kg's and the Drift Works unit weighs a whopping 3.9kg's - The design caters for interchangeable brake caliper mounts - The design caters for interchangeable tie rod mounts (so far we have 2 designed; standard and DW style) - Provision for ABS sensor (not shown in images below) - Ability for stock brake dust cover to slip over base of spindle ![]() Just to show you the possibilities of what our new billet 7075-T6 aluminium modular knuckles will have have a look at this ![]() (Again, please note that this is NOT the finished product, FEA's and optimization of the design still needs to occur). With the ability to swap out tie rod mounts you can completely change the feel and drive of your car. We can see in this image the stock arm Vs. the DW arm, the DW arm will give about 18% quicker steering than the standard arm. You’ll also notice the DW position is further outboard than the standard position. This will give you less Ackermann effect, so the inner and outer wheels will steer at nearly the same angle, rather than having the inner wheel steer tighter than the outer wheel. That said, the possibilities are endless. One idea that we're toying with is to have the CAD files to the mounts (both caliper and tie rod) available to the general public, this would mean that people with the skills to play around with their own mounts could do so with relative ease. ![]() The questions: - What is this design missing from your "ideal" knuckle? - Someone has brought to our attention that we should be using a standard radial caliper mount, what is common in the US (we reside in Australia and it's not so common over here) Thanks for your input in these early stages to help us improve on our design prior to production ![]() Regards, Greg |
#4064 |
P.S I deliberately haven't mentioned the price because I don't want this to seem like a for sale ad, this is not for the purpose of selling, more so development.
#4065 | |
As far as the bracket goes, I could have them made for the cost of material, if not for free if I asked for a favor (I work with a machine shop on a daily basis) and wanted to go that route, but then I'd need to CAD them up myself (not really a big deal, just a few hours of my time) and wait for them to get machined. I'd much rather buy something that's already figured out. As far as running the wilwood, when I checked the site, it didn't seem like the style used on the PBM knuckle came in a size that'd work with the Z32's rear brake thickness (probably do, I just couldn't find them). In terms of expense, it doesn't seem like it's that much more expensive, IIRC, the rotors that George runs on his Dual Z32 kit are more than $25 cheaper than an oem Z32 rotor, and a pair of rear Z32 calipers are what, $100 vs $260 per pair of wilwoods, in the end, I'm ~$100 more expensive than the PBM setup, without much more additional work. (I figure the $100 of additional expense is less than what my time is worth to design the brackets and the cost of the material to make them) I think you're right on weight though, the setup I'm looking at would probably be heavier, although I couldn't see it being much more than stock knuckle with a similar setup. |
#4066 | ||||||||
There is no grip and drift specific rear knuckle, Im sure the grip guys just wont use the dual caliper mount. The reinforcement of the RLCA mount prevents the use of the Z32 drum. Quote:
then ![]() now ![]() Quote:
![]() Quote:
![]() My daily driver ![]() Quote:
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 05-09-2012 at 06:26 PM.. |
#4067 | |
I think I figured out how to explain my logic without making a wall of text. Comments are more than welcome. In by no way am I trying to bash PBM, when I talked to dan on the phone he was very helpful with my questions, and I'm planning on ordering rack spacers + other items in the very near future. PBM is always constantly trying to think of new ideas.
-For a car that has a vertical KPI, 0 ackerman would be when the outer tie rod pickup point is directly behind the KPI (or balljoint). To add or remove ackerman you move this outer pickup point horizontally (perpendicular to the KPI) to the inside of the car for positive ackerman (toe out at full lock), or to the outside of the car (toe in at full lock) on s-chassis. The key here for ackerman, is the perpendicular distance of the outer tie rod pickup to the KPI when looking from the front or bck of the knuckle. -On s-chassis' the KPI is angled in at the top, and for all intensive purposes we will say that the KPI is along the shank of the balljoint (the red line). To adjust ackerman, we do the same thing as stated in the previous bullet point (move the tie rod pickup point) and the perpendicular distance to the KPI effects ackerman in same way as a car that has a vertical KPI. The blue line below shows my line of no change in ackerman because the perpendicular distance to the KPI stays the same along that line. ![]() Now if you just extend your shank to space your LCA down you will add ackerman to your car because when you add that spacer your LCA is still the same length and the spacer pushes the knuckle towards the inside of the car, which in turn pushes the outer tie rod pickup point towards the center of the car, which in turn increases its perpendicular distance to the KPI, thus adding ackerman. The way to solve this issue is to Lengthen your LCA ~(spacer_height)*sin(KPI_angle_from_vertical). This will keep your lower ball joint on the same axis (red line) keeping the original KPI, which will not effect ackerman. |
#4069 |
![]() Join Date: Sep 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
Not really, bro. The traction rod length is going to depend on your particular ride height, camber/toe settings and personal preference of how you want the car to feel.
#4070 |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
GKTECH - the drop would be nice at 60mm, most S chassis are lowered around that much in the front and for drifting it would be sweet to have 0 KPI so you wouldnt have weird positive camber in drifting without running huge negative camber, which will decrease with steering angle increase
#4071 |
GKTECH - yeah what Motory said. I like the changeable arms.
Dan at PSM - I'm excited for the forged knuckle! Same specs as a pro knuckle, or is there more drop there? Maybe it's just an illusion from the smooth look. Mark- While your thinking is logical, you are missing one thing. Spacing the LCA down increases the horizontal distance between your tie rod pickup and ball joint. If you draw a line down the two towards the rear of the car, THAT is your ackerman. There is no way around increasing your ackerman with a spaced ball joint besides modifying the steering arm. Sorry.
#4072 | |
I agree that most people probably would lower their cars 60mm's, most coilovers lower the car to some degree anyway so unless we had coilovers that were to match the 60mm drop spindle, then it wouldn't work but I certainly hear what you're saying. In regards to the KPI/SAI, on the revised version of the design (which we should have finalized within a few days) we will go one better than what you have requested, we will have adjustable KPI. Much like the MSI billet uprights seen here: MSI Billet Aluminum Uprights (Lots of pics) - Subaru Impreza WRX STI Forums: IWSTI.com We're more than open to ideas as we are in the early stages of the design. That said, we should be finished within 2 weeks or so before we start getting these on to the track. |
#4075 |
The design and everything looks pretty damn awesome, the biggest chalenge is offering them at an affordable price. Most S-Chassis people in the US are either: not serious enough, don't care enough, are kids with not money, or just flat out bums.
#4076 | |
The kit will include everything required to get you going and car specific too, or mix and match (ie. you choose at the time of ordering which LCA ball joint you're running, which strut your running for either 12mm or 14mm bolt holes, you choose the spindle you want etc. etc.) We don't yet have distribution setup in the US however we will in the very near future and until then, we will have DHP, UPS, USPS and FedEx accounts setup within the coming weeks to cater to US orders. Greg |
#4077 |
Sorry, just to clarify that price is in AUD (AUD vs USD is around parity at the moment anyway) however that price includes 10% tax which you won't have to pay so the price for US customers is expected to be a bit less than $550/pair + freight ($100 or so max as they'll be under 5kg's a pair)
#4078 |
Sounds like a pretty awesome deal!
#4080 |
same spec. just smoothed out. Right now we are machining a logo on the flat space under the spindle.
