Old 04-19-2018, 12:08 PM   #4021
yomisiu
yomisiu's Avatar
yomisiu is making a name for him/her selfyomisiu is making a name for him/her selfyomisiu is making a name for him/her self
i'll see if i can cut/hammer it some more and bend the metal the opposite way. the pbm ruca design looks like it should also resolve the frame clearance issue. thanks guys
yomisiu is offline   Reply With Quote
Old 04-20-2018, 06:38 PM   #4022
yomisiu
yomisiu's Avatar
noticed today that one of the tires doesn't look fully seated. i recall the tire guy having trouble with the air valve because it's really short/tight. i guess i'll have to take the wheels to a bigger commercial tire shop and hope they have a special slim air nozzle or something.
235/40 18x10.5 if anyone is curious.
Old 04-20-2018, 08:27 PM   #4023
shaggy sr
shaggy sr's Avatar
shaggy sr is an unknown quantity at this point
a quick question. how many MM spacers should i get for my front 18x9.5 +45 in s13 coilovers. it still touches the coil. i don't want adapters. or 18x9 +25 will work without spacers?
shaggy sr is offline   Reply With Quote
Old 04-21-2018, 03:35 PM   #4024
s13_maJiK
s13_maJiK's Avatar
s13_maJiK is an unknown quantity at this point
Quick easy way to determine this:
1. Take washers and place them over the studs
2. Put the wheel on (just hold it on) and rotate it to see if it hits, if it does, put some more washers on it until it doesn't anymore.
3. Measure the height of all the washers
4. Do some fun algebra. 25.4(x Inches)=MM Needed
If you suck at algebra, just put your measurement into a inches to mm converter. Then your done.
s13_maJiK is offline   Reply With Quote
Old 04-21-2018, 04:08 PM   #4025
derass
18x9.5 +15 is a pretty common size on S13, so I'd get a 30mm spacer.
Old 04-25-2018, 07:29 PM   #4026
HingwaM
HingwaM is an unknown quantity at this point
Anyone running Gram Light 57CR 17x9 with a 225/235 tire as a square setup on a stock body s13? Trying not to roll/pull fenders but i'm not sure what offset/tire size to go with.
HingwaM is offline   Reply With Quote
Old 04-25-2018, 09:32 PM   #4027
derass
I had 235/40R17 on 17x9 +20 all around with just rolled fenders on S13. That setup fit onto my 2nd S13 even without a roll; 100% stock fenders with -3* camber all around.
17x9 +20 is a good size. Just enough offset to clear the coilovers, but not so much that you can even squeeze a 245/40 or 255/40 all around under stock fenders with just a roll/pull.
Old 04-26-2018, 10:45 AM   #4028
HingwaM
I wanna be as close to 0 camber in the rear and around -2 or -3 in the front. Would I have issues with it hitting the coilovers or the fenders? Really prefer not to do a roll
Old 04-26-2018, 12:02 PM   #4029
Kviper52
Kviper52's Avatar
Kviper52 is an unknown quantity at this point
suick help, Weds Kranze LXZs 18x8.5 18.9.5 +22 on stock body s14, With a roll and a slight pull what lips could I run or how wide can I go and what tires without a stretch? dont want to rub and im on megan coils all around.
1991 240sx Coupe-Drift Car
1995 240sx LN1-Show Car
1993 Skyline ECR33-Street Car
1997 240sx -Wife Car
My Cars and Their story:
http://zilvia.net/f/showthread.php?t=657376
Kviper52 is offline   Reply With Quote
Old 04-26-2018, 03:03 PM   #4030
derass
Ya, 0 camber in the rear isn't going to work with a decent tire and no roll. Maybe if you run a 205 or 215, and/or a high-ish ride height. But that's gonna look wack.
Old 05-08-2018, 11:13 AM   #4031
Superstock2
Superstock2 is an unknown quantity at this point
Alright guys, I found a set of Kumho Ecsta v720's for super cheap but they're not the exact size i've been looking for. I've got an S13, rolled front and rear.
Wheels: 17x9 +22 / 17x10 +18 RPF1's
was looking at maybe 235/45 up front and maybe 245/45 in the rear?
Thoughts?
I want a streetable driver that can do some track/auto-x duty that also looks good. I'm worried the 45's will just be to tall. Thanks for the help.
Superstock2 is offline   Reply With Quote
Old 05-11-2018, 07:49 PM   #4032
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
Thoughts?
I just bought the same tires in 225/45-17 and 255/40-17 for my set of 17x8+32 and 17x9.5 +32 weds. Should work out
R@ddy is offline   Reply With Quote
Old 06-08-2018, 12:03 AM   #4033
bran420
bran420 is an unknown quantity at this point
What 17/18 wheel offset/width/tire size would I have to run to fit 55mm rear over fenders and 50mm front over fenders without having to modify the front wheel wells... Preferably 17’ lil meaty tire look...
Pic for example
bran420 is offline   Reply With Quote
Old 06-21-2018, 03:24 PM   #4034
Kamycakes
Kamycakes's Avatar
Kamycakes is on a distinguished road
18x10 +25
225/40 Pirelli P Zero Nero
Kamycakes is offline   Reply With Quote
Old 06-21-2018, 04:22 PM   #4035
TheRealSy90
TheRealSy90's Avatar
My Volk GT-Vs had valve stems like this that didn't protrude through the face at all and I couldn't get any air chuck on them. I got some valve stem extensions at the local Oreilly's and they worked perfectly. Should be sold by all the valve stem repair parts.
Such a good signature.
Old 06-22-2018, 09:35 AM   #4036
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
If you have a Napa near you their part number for the valve stem extensions is 90-319.
Sold in a set of 4 for $3.00 or so
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 07-16-2018, 08:56 PM   #4037
supramon808
supramon808 is a well-known jackass
Anyone with 17x9.5 +18 front and 18x10.5 +15 rear RPF1s on their stock body s14? any pointers. I know the front i can fit using 5mm spacer to clear coilovers. The rear might need a little work. Want to see some 18x10.5 +15 rpf1s setups so i can get a better idea on what to expect
supramon808 is offline   Reply With Quote
Old 07-24-2018, 08:48 PM   #4038
3NDLESS
3NDLESS's Avatar
3NDLESS is an unknown quantity at this point
9" +30 Meisters R Disk for fronts but I'm curious about coilover clearance on s13 and overall fitment. I've heard that I should run 20mm spacers but need confirmation
3NDLESS is offline   Reply With Quote
Old 08-14-2018, 07:52 PM   #4039
1jzjoey
1jzjoey's Avatar
1jzjoey is an unknown quantity at this point
Will 18x12 -1 fit on the front of an s13?
Originally Posted by 180 drifter View Post
2700 for a non running crashed up car. sounds like a steal.
1jzjoey is offline   Reply With Quote
Old 08-14-2018, 09:41 PM   #4040
deolio
deolio's Avatar
sure, if you wanna look like a massive tool. not gonna be able to turn for shit, but with those specs i assume you’re building a fuckboy hardpark car so it doesn’t matter.
Old 08-14-2018, 11:35 PM   #4041
1jzjoey
1jzjoey's Avatar
Well id like to be able to turn. You seem butthurt what happened?
Old 08-16-2018, 09:44 AM   #4042
cwk
cwk is an unknown quantity at this point
Maybe someone here will know, sorry if this has been answered before! Does anyone know if MB Battles (+15) will clear CTS-V calipers?
cwk is offline   Reply With Quote
Old 08-16-2018, 10:01 AM   #4043
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
if you don't get your answer here im sure the ctsv caliper guy will know.
jumpman2334 is offline   Reply With Quote
Old 08-16-2018, 10:20 AM   #4044
cwk
Sorry I’m new to the forums, who would that be?
Old 08-16-2018, 11:29 AM   #4045
brokeboi01
brokeboi01's Avatar
brokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enough
The guy who designed them
brokeboi01 is offline   Reply With Quote
Old 08-16-2018, 12:21 PM   #4046
cwk
for some reason I interpreted it as a guy who specializes in them on here lol
Old 08-27-2018, 11:54 AM   #4047
Doc KA24DE
Doc KA24DE is an unknown quantity at this point
Will 17x8.5 +20 fit stock body s13 on coils? (still on 4 lug hubs) My wheel options are very limited, everything else in 17x9 require a fender roll except for MST MT07 17x9 +20 & Aodhan AH03 17x9 +25 which i'm not interested in.
Doc KA24DE is offline   Reply With Quote
Old 08-27-2018, 12:02 PM   #4048
brokeboi01
brokeboi01's Avatar
Yes depending on your camber set. I run 17x9 +28s on a stockbody with r: -3 camber and f: -2 ish
Old 09-21-2018, 04:31 AM   #4049
Superfly
Superfly is an unknown quantity at this point
Would a 10.5 in the rear fit with just a roll and pull? Thinking +25 offset? And 255/40 or 245/40 if I must dont want too much stretch.
Superfly is offline   Reply With Quote
Old 09-26-2018, 03:57 PM   #4050
theStig880
theStig880's Avatar
theStig880 is on a distinguished road
Yes but it will require a little camber and patience to pull the fenders. @epicbabybee on Instagram had 18x10.5 +15 LMGT4s with 245/35s on the rear of his hatch with a roll and pull.
Follow me on Instagram or don't @cason880
theStig880 is offline   Reply With Quote
