Old 02-06-2018, 01:02 PM   #3991
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
SR
Alrighty guys quick question: I found a deal on some 18x8.5 +30 wheels I couldn't pass up. I've looked on rimtuck and in the wheel-whore threads without much luck. Just looking for some suggested tire sizes (Wheels are a square set up.) Spacer(s) if any?
I don't mind running a little stretch but nothing super agressive.
Wheels will be going on my 95 zenki. Car has FF type 2 coils, RUCA, rolled fenders, car is low but not on it's nuts...
Thanks in advance!
EFITTZY is offline   Reply With Quote
Old 02-06-2018, 01:14 PM   #3992
deolio
deolio's Avatar
^you might need spacers. 205/40 all around, maybe 215/40 rear. those wheels are pretty narrow.
Old 02-06-2018, 01:19 PM   #3993
EFITTZY
EFITTZY's Avatar
Thanks for the quick reply. I'll continue looking around to see what else I can find for optimal spacer sizes. They are narrow, but not a deal breaker for me... Thanks again
Old 02-07-2018, 07:47 AM   #3994
burgerboy78
burgerboy78 is an unknown quantity at this point
Just got a sweet deal on some new Work d9r’s in 18x10.5 et15 flavour. Will the fronts work with a fender roll and a small slip on to clear th coilover?
Also was going to attempt to put my pair of 225/40/18 ad08’s on the front. Anyone stretched these before?
burgerboy78 is offline   Reply With Quote
Old 02-10-2018, 08:41 AM   #3995
humancola
humancola is an unknown quantity at this point
Stock body S13 on coils.
17x9.5 -18 RPF1's all around.
235/40R17 fit without drama?
General searching seems that it should work, may need some rolled fenders?
Welp, fingers crossed.
humancola is offline   Reply With Quote
Old 02-10-2018, 02:05 PM   #3996
derass
Thanks in advance!
8.5 isn't that narrow.
I ran 18x8.5 +35 w/ 235/40R18 in the front with about 10mm to the rolled fender. So you could run the same tire size with about 5mm clearance. Or even go up to a 245/40. Those would give you a meaty fitment.
If you want to go with the stretched camber look, go with the 205/40 (215 won't be enough). But you'll need 15-30mm spacers, since 18x8.5 +35 is not very aggressive and will look very sunken with those small, stretched tires and no spacers.
That will fit with a moderate pull of the front and rear fenders.
Old 02-17-2018, 01:57 PM   #3997
azsr20det
azsr20det is an unknown quantity at this point
So I just got my 5 lug hubs today, waiting on brake stuff before I put em on, and have a set of brand new 5 lug wheels getting powdered right now and was wondering what tire sizes you guys reccomend for the wheel sizes I got
Wheels are
Front - 18x9+25 iirc
Rear - 18x10.5+20
On my other car ive got 18x8 in the front wrapped in 205/40/18
And 18x9 in the rear wrapped in 215/40/18
The 215/40 on the 9 is somewhat stretched so was thinking about doing a 215/35 or 215/40 on the fronts of my s13 and possibly 225/40 or 225/35 on the 10.5
My rear fenders are rolled & pulled/flared and the fronts are rolled flat, car has ksport coils and I just put on brand new adjustable rear camber arms and brand new rear adjustable toe rods so I can dial in fitment as needed. Im not looking for super crazy stretch on rubber bands, but I do want the rears somewhat stretched and rounded off so it sits nicely under the pulled quarter. Worst case im prepared to buy and install fender flares or rear overs if need be but would prefer to avoid it if possible.
Any suggestions or pictures with similar fitment? I havent had time to go through the thread and look yet but plan to.
Any help would be greatly appreciated
azsr20det is offline   Reply With Quote
Old 02-17-2018, 04:43 PM   #3998
derass
^^ S13 or S14?
Old 02-17-2018, 07:09 PM   #3999
azsr20det
Its a S13 sorry
Old 02-19-2018, 10:47 PM   #4000
azsr20det
Ended up ordering 215/40 for the 9s and 225/40 for the 10.5s
Old 02-28-2018, 05:44 PM   #4001
brokeboi01
brokeboi01's Avatar
brokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enough
Sup goys, I'm looking into a set of 17 x 9 +35mm offset Gramlight 57s all around. Planning on 215-225 in the front and 235-245 in the rears, whichever tire widths work out best. Was wondering if there'd theoretically be any clearence issues on a stockbody s13 fastback w/ s13 silvia front (not a zilvia favorite). I'm trying to avoid rolling/pulling the fenders so if +35mm dont cut it i could opt for +22mm. Thanks
Sent from my SM-G950U using Tapatalk
brokeboi01 is offline   Reply With Quote
Old 02-28-2018, 05:53 PM   #4002
brokeboi01
brokeboi01's Avatar
And yes its on teins, moderately lowered 3-4 inches, open to adjustment if i have to
Old 02-28-2018, 05:54 PM   #4003
brokeboi01
brokeboi01's Avatar
Ignore 3-4 inches i have no idea what im talking about its just lowered moderately
Old 02-28-2018, 10:58 PM   #4004
derass
+35 will fit in the rear, but might hit the coil overs in the front.
+35 is also a pretty weak offset. especially in the front. and the 215 would look terrible all sunken.
you can fit +22 and decent tires all around, but at a higher ride height. so +35 might be better for you if you're really low.
I personally would run the +22 with 235/40 or 245/40 all around and raise the car up a bit. Or do +22 in the front with 235 and +35 in the rear with 245/255.
Old 03-03-2018, 09:53 AM   #4005
Chittabangbang
Chittabangbang is an unknown quantity at this point
Hey guys,
I have a S13 hatch. I have 18x8.5 +35 wheels (not mounted), what size tire should I run? And would this fit flushed or would it poke? I’m fine with rolling fender. Right now I’m slammed on stock se wheels with pbm coils, but I’m fine with raising it.
Chittabangbang is offline   Reply With Quote
Old 03-03-2018, 03:56 PM   #4006
derass
I used to run 18x8.5 +35 w/ 235/40R18 on the front of my S13. They needed a 3mm spacer to just barely clear my coilovers, and were sunken in about 10-20mm from the fender.
So I would run at least a 235. But a 245 or 255 would be better. And at least a 10mm spacer.
If you want poke, you'd need a stretched tire like a 205 or 215 and large spacer, like 20+mm.
Old 03-03-2018, 06:04 PM   #4007
Chittabangbang
3mm spacers all around just to clear the coils? If I were to run 245, it would be what.. 245/40/R18? I apologize I’m new to this and I’m trying to learn.
Old 03-06-2018, 04:34 AM   #4008
DriftingBrandon
DriftingBrandon's Avatar
DriftingBrandon is an unknown quantity at this point
Will Work O disk (vskf specifically) clear S13 stock brakes?
Also, can someone confirm that work vskf o disk spokes have less of a curve to them then a/r disk?
Thanks!
DriftingBrandon is offline   Reply With Quote
Old 03-09-2018, 08:50 PM   #4009
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
Does anyone know the size difference on the hub size comparing A disk to O Disk?
Thanks!
For rears 0 disc Yes they deffinetly clears calipers. They even clear z32 rears.
As for fronts I do not know.
I do know that the spokes between 0 disc and A disc are actually the same,
Just the rear mounting pad thickness is much thinner on the 0 disc compared to A. Like if you mounted a lug nut on an A disc the lug would sit more in the lug pocket with less lug exposed and with an 0 disc there is very minimal of a pocket for the lug to sit in so its pretty much all exposed.
I hope that makes sense.
Renelovesnike is offline   Reply With Quote
Old 03-10-2018, 12:16 AM   #4010
derass
3mm spacer just in the front. I had 18x9.5 +35 in the rear with no spacer.
Yes, 245/40R18 is a common size. There's also the less common 245/35R18.
Old 03-17-2018, 12:55 AM   #4011
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
I'm a little embarrassed to make this post, but hell this is a the wheel fitment questions thread, so here goes. Currently starting the build on my car and need the wheel gurus to help me out. It's an 89 hatch, and I will be running the Spirit Rei kit, which runs 40mm fenders up front and 65mm out back. My brakes are STI Brembo's front and back. I will be on air suspension, running D2 air struts. The owner of Spirit Rei is running 18x10 -3 in the front and 18x11.5 -14 in the rear, which sits quite nicely. Here is the link, showing the fitment and the build: http://www.stancenation.com/2014/04/...-nissan-180sx/
So, here's what I need help with; I'm wondering if I can get more aggressive on my fitment, without running an extreme amount of camber, and without the use of spacers. Also, I don't want to run extremely stretched out tires, as I like the look of some decent meat on my wheels, just adds to the aggressiveness imo. I know I'm being picky as hell, but I would appreciate any input you guys may have.
speedgod^s13 is offline   Reply With Quote
Old 04-04-2018, 06:35 PM   #4012
Mintyboy
Mintyboy's Avatar
Mintyboy is an unknown quantity at this point
Hey guys,
Would 18x9.5 +22 (245/40/18) clear the front? I have a feeling it will be close to the coilovers. I have 12mm front fenders so I can get spacers, but just wanted to know if I could get away without using spacers. Thanks!
Mintyboy is offline   Reply With Quote
Old 04-04-2018, 08:51 PM   #4013
derass
Originally Posted by Mintyboy View Post
Hey guys,
It'll be close. It depends on the coilover, some lower brackets have more clearance that others. Tell us what coilovers you have, that will help get you an answer.
Old 04-04-2018, 11:10 PM   #4014
DriftingBrandon
I'd love to know how much thicker the A disk pad is than the O disk on work vskf.
Old 04-05-2018, 11:39 AM   #4015
Mintyboy
Mintyboy's Avatar
I'm running Fortune Auto coilovers!
Old 04-12-2018, 03:34 PM   #4016
sharad909
sharad909's Avatar
sharad909 is an unknown quantity at this point
Thinking about running 255-40 On 17x8. Any got pix? S13 rolled and slightly pulled
sharad909 is offline   Reply With Quote
Old 04-18-2018, 07:50 PM   #4017
yomisiu
yomisiu's Avatar
yomisiu is making a name for him/her selfyomisiu is making a name for him/her selfyomisiu is making a name for him/her self
revisited the wheel fitment picture thread recently and went through a couple hundred pages (lots of dead pics) and i'm hooked again. went out and got some SSR's that were well-priced and local and test fit the rears on my S14 today.
18x10.5 +30 (SL) 235/40 Bridgestone Potenza Sports
i don't like how much rear camber or stretch you need for your typical 10.5 +12 sized wheel to fit under an un-pulled fender so i figured this size would give me the look i want.
low, wide and flush with minimal rear camber and tire stretch. it's almost exactly what i wanted.
i have, however, ran into a few clearance issues.
i "notched" my frame for ruca clearance when i put in subframe risers but it's still hitting, actually it's pretty much resting on the ruca when the wheels are on the ground. i guess i could make a little more room by bending the metal back the other way but i plan on lowering it more so it may not be enough. they are old fortune auto ruca and i may need something else. any ideas? i know they make bent toe rods for more clearance, but what about ruca's? also, the wheel is super fucking close to the rLca. like, i can't fit a finger between the two. should i worry about that? does that distance ever change when driving, under compression, etc? i bought a 5mm slip on spacer if i need it.
yomisiu is offline   Reply With Quote
Old 04-18-2018, 08:35 PM   #4018
Bnr32gtr
Bnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enough
The notch in the pinch weld on frame looks like it needs to be wider
Bnr32gtr is offline   Reply With Quote
Old 04-18-2018, 10:03 PM   #4019
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
The RUCA issue you're having seems to be the part itself. For my set-up, I have V2 PBM ruca's installed and that part is angled rather than, being straight. As for the RLCA, as long as the inner barrel does not rub under compression, you should be fine. However, if you want to prevent any future issues, I would slap on the 5mm spacer.
instagram
1on1 is offline   Reply With Quote
Old 04-19-2018, 06:41 AM   #4020
Bnr32gtr
I have veodoo 13 and gk tech ruca my gk tech are not the newest ones but both have clearance issues and both need the frame notched for the low life. I have found u gain more clearance when they are flipped like other have said. It's still damn close like to cunt hairs. The newest GK tech is supposed to be better but I have yet to seen one in person
