#3993 | |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
#3994 | |
#3997 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Talking about the flange on the bottom
Just us ea drill to slot the lower holes, and the redtop oil drain will work just perfectly. Same with GT series turbos.
#3999 |
![]() Join Date: May 2009
'Sup guys. I just installed a "new" exhaust on my s13. In reality, its a super ghetto 2.5" straight pipe to muffler from the catback which was originally fitted on an s14. I had to mod it to get it to fit, but the muffler sits less than 1 inch from the gas tank.
Can I get away with covering the gas tank with heat wrap? Or should I add a sort of metal heat shield as well to avoid going BOOM ![]() |
#4000 | |
Trader Rating: (58)
#4001 |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
I'm looking to paint my strut bar. What should I go by. Not the whole bar just the plates. Thank you. If I do it today I will post a vid
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
#4002 |
Im planning on getting a s14 and i want to stuff some massive tires under it i was thinking 17" or 18" by f 9/r 10 0+ offset all around.
Will this be a good setup or can i go wider without having major issues, front tires 255+ and rear 275+ Pictures will be helpfull. Thanks in advanced.
s14 grip monster=2011-2012 |
#4003 |
![]() Join Date: Dec 2010
alright, i have searched and searched and i cant seem to find any talking about this or asking this question...i just bought an entire s13 subframe assembly which includes the differential...all in wonderful condition...
MY QUESTION: is an s13 automatic differential the SAME as a manual? my car is manual and my spare subframe assembly came out of an auto... EDIT:SORRY, I FOUND MY ANSWER...THEY ARE THE SAME |
#4004 | |
Trader Rating: (58)
Primer them Rustoleum them. or just get them powdercoated for the 15-20 bucks it costs.
#4006 | |
![]() anyway I know thats the jist of it. But I was looking more for what grit, how many coats, etc. Thanks again. I want to do it you know. Want to do a vid in case anyone else iswondering how to do it. i youtubed "how to paint a strut bar" and nothing came out. So if you can give me some pointers, that would be great!
#4007 |
cause there isn't one out yet
![]() well that and youtube doesn't have enough trivial videos. imho
#4008 | |
Trader Rating: (58)
You're looking pretty far into it haha. Not that it's a bad thing, but it's a simple paint job. Just scruff the surface of them, primer them, and then give them a final coat with color of choice. If you are pront to lay tools in that area, they can chip and look funky. This is why powdercoat is such an attractive option.
#4010 | |
Trader Rating: (58)
275's on a 10" wide wheel with 0 ofset will NEVER fit without some serious bodywork/over fenders. Same with the front, fitting a 255 on such a wide and huge offset will be almost impossible on stock stuff. If you're looking for a real grip monster you could probably go with a 8.5 front and 9 rear, and fit those size tires and be closer to fitting with something in the 25ish offset range all around. I currently run 8" front and 8.5" rear Z33 Track 18's (i think both are like +30) with a 245 up front and a 265 out back (NT05's, big wide square sidewall) and they required a little roll front and rear. I actually had to run a 10mm spacer up front to help bring it away from the koni's haha.
#4011 |
ok so based on sand, primer, paint. looks like these are the things i need....
first. should I just use one type of sandpaper? or should i use a coarse then fine, or just fine? Advance Auto Parts: Search Results for sandpaper I'll use this primer : Advance Auto Parts: Brite Touch Gray Primer by Brite Touch - Part BT49 and color it with this: Advance Auto Parts: Rust Tough® by Krylon - Part RTA9202 AM I on the right path? thanks again.
#4012 | |
#4013 | |
I like duplicolor products for rattle can jobs, they make a good product...always match primer to paint to ensure compatibility...since primer acts as an adhesion layer between surface and paint, you need to ensure that the proper chemical reaction between primer and paint occurs... Another trick is make hangers out of clothes hangers (I usually use a length hanger wire to make a line of wire with a j hook at either end) that way you can shoot in a full 360 around the part without having to shoot, wait, flip, then shoot the part... You can apply this method to anything you paint, though doing a good high grit staged process 300ish grit to 400ish grit to 600 grit wet sand finishing on primer will result in smoother paint, but what you're doing shouldn't require this method |
#4014 |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Making a hydraulic ebrake and need some help on bore size.
Z32 rear calipers hawk hps pads wilwood cylinder - 5/8 or 3/4"?
http://essencegarage.wordpress.com/ |
#4015 | |
And as for parts i plan to replace everything, nothing will remain stock with the suspension.
#4016 |
i know this is stupid question but i gotta ask you guys if i can use same gear oil/fluid in my transmission and differential? like the amsoil transmission and transaxle gear or like the lucas oil syn 75/90 trans & diff lube? thanks
#4017 | |
AFC #1
![]() Join Date: Oct 2003
AMSOIL - Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 (MTG)
#4018 | |
you mean i can use Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 in my tranny and diff? |
#4019 | |
The transmission, however, uses these metals in the synchros i believe, again don't quote me i might be wrong, and these will eventually be corroded with the GL-5 fluid, so we need to strictly use GL-4 gear fluid, not a blend. Synthetic or not doesn't matter, as long as it isn't GL-5 of GL-4/5 blend. Companies that make GL-5 is Redline (amazing) AMSOIL (just as good) Royal Purple (meh) and a few other "performance" oil companies.
street dancer. GLEAM |
