05-03-2012, 01:51 PM | #3991 |
Went ahead and shipped my knuckles to PSM for the pro knuckle mod, in the mean time I'll be modifying my LCAs. Right now my tire rubs the frame rail in the back side of the wheel well at full lock, and all I have are rack spacers. While I box my LCAs in I also plan on extending them a bit, possibly only 10-15mm. Has anyone had experience with how far I should extend them? I'm going to measure everything to see how far out I have to go in order to not rub, but if someone has found a sweet spot I'll just go for that.
05-03-2012, 02:24 PM | #3992 |
I extended mine 1.5".
I extended them to get the wheel away from the TC rod and swaybar. Getting the tire away from the frame rail was a bonus.
05-03-2012, 02:31 PM | #3993 |
What tie rods are you using? I'm running Megan inners, 11.5" end to end. Not sure if those will be long enough to deal with the knuckle and an extended lca, and I don't want to run into issues when putting everything back together. Since I'm running s14 inners I can probably extend to the length of stock s14 lcas and be fine, I'm just wondering how much further I can go.
05-03-2012, 03:54 PM | #3995 |
how far to extend the LCA maybe depends on the amount of negative camber you want to add
05-03-2012, 04:23 PM | #3997 |
I pushed the camber plates all the way to the outside. Although I still gained a bit of camber, I didn't want to add camber so much as I wanted my wheel to stop hitting my TC rod and sway bar. And I didn't want to add spacers (scrub too) because then the wheel hits front and back in the wheel well.
05-03-2012, 04:29 PM | #3998 | |
05-03-2012, 06:17 PM | #4000 | |
05-03-2012, 07:25 PM | #4002 |
I still don't understand that. There are drift teams running them without issue. It's not like they can afford to replace their rack mid-event all the time.
05-03-2012, 08:39 PM | #4003 |
Drift teams also use modified crossmembers to fit oil pans(can't move the rack because you now have an oil pan there). Using the offset spacers is a way around this... and while bent racks have happened I doubt they happen easily.
05-03-2012, 09:47 PM | #4005 |
Everything I've read says they're 10mm longer than s13 arms, so around 380mm.
Turns out there's not enough thread engagement on the Megan tie rods for me to feel safe extending my lcas, so until I get SPL outers or Ikeya inners I won't be extending the control arms. On the topic of lengths, anyone know the length of Ikeya inner tie rods? The length of Megan tie rods is 11.5", I'll measure the length of stock s14 inners this weekend. Think cutting a stock tie rod end where the threaded portion starts and welding a longer female standoff to it to account for the length difference would work? I'm assuming the tie rod ends are cast, would welding an attachment to it be safe since it sees so much stress? |
05-04-2012, 01:36 AM | #4006 |
I switched S13 FCA to S14 FCAs (and now adjustable FCAs). I was told the difference was 8mm for each arm... if i find my previous OEM LCAs i can measure that. Drop me a PM sunday evening so i remember to do that. Will take pics with measurements.
05-04-2012, 02:53 AM | #4007 |
You must be measuring the entire arm... I got 416mm for the entire S14 FLCA and 362mm from center of ball joint to center of bushing.
Tein S14 inners are 262mm and Ikeya inners are 286mm (Ikeyas are double adjusted.... this was with 25mm of thread engaged) not including the threads that screw into the rack. Tein S14 outers are 102mm measuring to center of ball joint... used to have the length for SPL outers but lost that somehow |
05-04-2012, 10:58 AM | #4008 |
I got 330mm from center of ball joint to center of bushing for the s13.
Megan inners are 266mm from end to end, not including rack threads. SPL outers: turnbuckle is 82mm, rod end is 70mm from center of heim to end of the threads. Last edited by Chris28; 05-04-2012 at 03:52 PM.. |
05-04-2012, 12:33 PM | #4009 |
I dont think they move 35mm forward. I thought it was 25mm. But yes its an easy way to move it forward more, I don't agree with them because there more feasible to damaging the rack, but you still shouldn't be hitting curbs anyways.
05-04-2012, 05:29 PM | #4010 |
Trader Rating: (22)
Feedback Score: 22 reviews
Maybe this will help you guys understand how to measure correctly, from center of bushing on left, to center of pivoting point of ball joint, the center of the ball.
05-04-2012, 08:16 PM | #4012 |
Trader Rating: (29)
Feedback Score: 29 reviews
Az you are right...I am using an inch tape and converting it. I am between 13.375-13.50 which converts to 339-343mm. I had burned an inch and forgot to subtract it.
05-05-2012, 05:36 PM | #4013 |
Why in the world did you keep the stock bushing? That's the 2nd worst bushing on the whole car for performance (1st being the tension rod). Put a rod end there.
05-06-2012, 09:11 PM | #4015 |
The Era1 website is up in case anyone wants their drop knuckles. They're certainly not a deal though. Basically the same price as driftworks. I thought knockoffs were supposed to be cheaper? Hahahah.
PSM has pretty much got the deal of the century in comparison. www.era-one.com
05-07-2012, 03:20 AM | #4020 |
