Old 03-30-2009, 01:06 AM   #3961
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
Originally Posted by jimmytango00 View Post
that is a pretty crazy stagger , im assuming it'll give you some bad understeer if you plan to track these wheels. plus im sure you're probably planing to run like a 225 or 215 on the 9" rim correct? and then a 295 rear...seems a little bit crazy, i had 18x9 18x11 and ditched them for some 18x10 18x11.5 cause of the crazy stag.
I had the same issue with my 18x9 18x10.5 running stretched fronts, gave mad understeer. had trouble at the last track event
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 03-30-2009, 08:06 AM   #3962
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
going to run 245/35/18 fronts and 295/30/18 rear . not a big fan of neg camber. thats why i got the 40mm and 70mm
not planning on track this wheels. got the TE's for that
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 03-30-2009, 08:12 AM   #3963
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
Originally Posted by ROIDMONKEY View Post
im gonna be doing (waiting for it) 18x9-7 front(40mm fenders) and 18x11.5-21 rear(70MM fenders) soon. cant wait
Are you going to run Koguchi fenders?
C. Anderson is offline   Reply With Quote
Old 03-30-2009, 08:18 AM   #3964
ROIDMONKEY
ROIDMONKEY's Avatar
rear yes ........DMAX D1 40mm front
Old 03-30-2009, 01:14 PM   #3965
FusionR240sx
FusionR240sx's Avatar
FusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond repute
Send a message via AIM to FusionR240sx
rear
front
18x9.5 -4 235/40 595's front and rear in those pics. but those will both be in the rear.
will have same wheel specs up front but with 215/40's.
gona trim the over fender a lil.
raise the rear a little and do a bit more camber.
camber is unknown in those pics.
and all i did was take my old 17's off, sell em, and throw these 18's on.
so i'll play around with ride height a little bit. i actually like the stance now... just more camber up front when i get the 215/40's and i'm good.
Originally Posted by Wreckless35 View Post
still be flush dropped on KYB AGX struts & s-tech springs
WUT?
FusionR240sx is offline   Reply With Quote
Old 03-30-2009, 03:22 PM   #3966
kafanylovesme
kafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfection
Send a message via AIM to kafanylovesme
Are you going to space the fuck out of the TE's to fill that gap when you "track" it?
kafanylovesme is offline   Reply With Quote
Old 03-30-2009, 03:23 PM   #3967
Pink Slut
Pink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud of
17x10 et22. 205/40/17
stock fenders
dont like it, needs to poke out more, will add a 20mm spacer and a roll
Pink Slut is offline   Reply With Quote
Old 03-30-2009, 04:07 PM   #3968
PoorMans180SX
PoorMans180SX's Avatar
stock fenders
Ummmmm, no? You're already almost mexi-flush man.
Get a bigger tire (235) and roll it.
Old 03-30-2009, 04:11 PM   #3969
ROIDMONKEY
ROIDMONKEY's Avatar
LOL I KNOW RIGHT . SUCKS BRO. i hate spacers. im actually running a 10mm rear with the TE's right now with 50mm . so with the 70mm im gonna need like a 25 . FUCK NO (every time i think about selling them i get stupid ) but im going to have to sell them.
or i can use the Gramlights 57s tit lip. they are 17x9-3 and 18x10-6 with a 10 spacer
Old 03-30-2009, 05:54 PM   #3970
drftwerks
koguchi uses spacers on his wheels to fill in that 70mm
giantroboteyes.wordpress.com/
Old 03-30-2009, 06:11 PM   #3971
FusionR240sx
yea... leave it.
lower it a lot.
WUT?
Old 03-30-2009, 06:15 PM   #3972
silviaguy240
silviaguy240's Avatar
uhh. car is off the ground. there is like zero or positive camber in that pic.
Old 03-30-2009, 07:06 PM   #3973
ROIDMONKEY
ROIDMONKEY's Avatar
they got to be!!! those wheels look like CR kai's or something. they must be using 25mm or more
Old 03-30-2009, 07:21 PM   #3974
200SXCA18DET
200SXCA18DET is an unknown quantity at this point
Sup guys need some help on which spacers i might need to go with, right now im just on tein s techs/kyb agx and still 4 lug,:-( ,its my daily so i cant slam it just yet. I have 17x7.5s +35 all around with 215/45s up front and 225/45s rear so i was wondering which spacers to go with to look better than sunken in and not stick out too much.......
200SXCA18DET is offline   Reply With Quote
Old 03-30-2009, 09:16 PM   #3975
silviaguy240
yea his one red car he has gramlights 57 optimise, i saw he was running a 265/35 upfront though. probably a 9.5 +12 in the rear with a 295.
like 50mm's
Old 03-30-2009, 09:30 PM   #3976
200SXCA18DET
haha........
Old 03-30-2009, 09:34 PM   #3977
beastka101
Trader Rating: (31)
beastka101 will become famous soon enoughbeastka101 will become famous soon enoughbeastka101 will become famous soon enoughbeastka101 will become famous soon enough
Feedback Score: 31 reviews
he is serious.
beastka101 is offline   Reply With Quote
Old 03-30-2009, 10:25 PM   #3978
SlideAlliance
SlideAlliance's Avatar
SlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond repute
Sell your wheels to some civic kid, get some MUCH wider wheels front and rear with lower offsets.
Battle Idol Works 2015
SlideAlliance is offline   Reply With Quote
Old 03-30-2009, 11:59 PM   #3979
boostdd
boostdd is an unknown quantity at this point
for the honda haters, not my car
boostdd is offline   Reply With Quote
Old 03-31-2009, 01:43 AM   #3980
GabeS14
GabeS14's Avatar
still always gonna be a girl's car, no matter how they look!
Old 03-31-2009, 10:08 AM   #3981
200SXCA18DET
Originally Posted by beastka101 View Post
he is serious.
I've always been on the side of engine performance and this is the 5th s13 ive owned and maybe last but im looking at focusing on the suspension. I do want coils but im working with what i have for now. Its hard to find an answer since everyone is mostly on coils now with nothing less than 8" wheels. I might just sell them and convert to 5 lug and go from there. I hate being flamed but its the only way i'll learn. I was thinking since most owners of s13s that are only dropped 1.5" and have the 2003 350z wheels which are 17x7.5 front and rear with a +33 offset, I was thinking since im at +35 i would go with a 10mm spacer and it would take it to +25 but are you saying i would need bigger because of neg camber??
Flamesuit on.............
Old 03-31-2009, 10:42 AM   #3982
ChristopherL
ChristopherL is an unknown quantity at this point
Seriously, 25mm spacers all around. Then lower and adjust fender as per needed.
ChristopherL is offline   Reply With Quote
Old 03-31-2009, 01:02 PM   #3983
SlideAlliance
You would need wider because your car isn't low, you are rocking 17's and the wheels will never be spaced out far enough unless you are rocking like a 25mm or bigger spacer. You can also get 25mm 4 to 5 lug conversion spacers to run different wheels.
You seriously should bail on the 7.5" wide wheels, even sportmax has some 17x9's and I think they even have 4 luggers.
Old 03-31-2009, 06:41 PM   #3984
PoorMans180SX
Oh, haha, didn't notice that. Still though, a 10in rim with a +22 offset is about perfect with a roll on stock fenders. Whatever works for him though.
Old 03-31-2009, 06:55 PM   #3985
PoorMans180SX
Here's Koguchi fenders (not mine) with 17x9.5+17 XD9's. Looks like more than 25mm to me?
Old 03-31-2009, 08:18 PM   #3986
sb253
sb253's Avatar
sb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud of
Send a message via AIM to sb253
I got to step my game up.
17x9 0 w/ 235/40 fed SS. Works for my daily
sb253 is offline   Reply With Quote
Old 03-31-2009, 09:36 PM   #3987
icedsole
icedsole's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
^ sean wheel look good black! its dan
we should swap wheels soon
Old 03-31-2009, 10:02 PM   #3988
Z33dori
Z33dori's Avatar
can get better tire shot of the 235/40 fit on the 9 plz
Old 03-31-2009, 10:20 PM   #3989
sb253
sb253's Avatar
ya, ill get pics up in a sec. Feds run wide just to warn you if you're looking to stretch on a 9
Old 03-31-2009, 10:25 PM   #3990
FusionR240sx
and they have 50mm 4-5lug spacer/adapters.
my friend just got them.. 180 shipped all 4.
235/40 feddys on my 9.5's are barely stretched.
so on a 9 i would think it would ALMOST be squared.
i'm gona get 215/35 up front i think.
WUT?
